keygen1gggg Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 Which v4 beta ???? Only v3 for me.This one https://docs.google.com/file/d/0B9Xy2GDF0is9dEphNVBiMC1JVWM/edit?usp=sharing&pli=1Then what is so awesome about it if it is not fully stable :huh:It's awesome because I dont own a wcp I own an everclassic, it is a wcp with only 512ram. A non lagging 4.2 ROM for 512 MB RAM ils awesome ^^ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
frankee Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 This one https://docs.google.com/file/d/0B9Xy2GDF0is9dEphNVBiMC1JVWM/edit?usp=sharing&pli=1 It's awesome because I dont own a wcp I own an everclassic, it is a wcp with only 512ram. A non lagging 4.2 ROM for 512 MB RAM ils awesome ^^ that ROM is an old beta version. Try the latest version instead. From beta 22 to v3.0 On these ROMs, BT works great. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 May be keygen1gggg is talking about old v4 beta. Because, in those beta versions, BT didn't use to work.No BT patch for v4 beta ? Cuz I seriously dont want to change it that ROM is an old beta version. Try the latest version instead. From beta 22 to v3.0 On these ROMs, BT works great. No BT patch for v4 beta ? Cuz I seriously dont want to change it Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
frankee Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 Look at the french post too. Maybe you'll find what you search... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 Look at the french post too. Maybe you'll find what you search...French post is not updated. Btw I tried the v22, it's la gging soo much Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 Try the above mentioned v3.0 by qus1. It is the latest and fully functional ROM. Try the above mentioned v3.0 by qus1. It is the latest and fully functional ROM. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 18 octobre 2014 Share Posté(e) 18 octobre 2014 Try the above mentioned v3.0 by qus1. It is the latest and fully functional ROM. Try the above mentioned v3.0 by qus1. It is the latest and fully functional ROM. I tried it, it's laggy, go back to old rom, btw my phone has only 512mb RAM. No patchs to fix just the BT issue ? It's the only bug I found. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 I tried it, it's laggy, go back to old rom, btw my phone has only 512mb RAM. No patchs to fix just the BT issue ? It's the only bug I found. there is no such BT patch sadly :( V3.0 is not laggy at all. Firstly, you need to do a clean install by wiping dalvic cache, cache, data, android secure and system. On first start, their will be plenty of RAM. Carry out some installations and try not to keep social app widgets on home screen and also limit your social app usage to minimum. Further, you need to install Battery doctor and give it root permissions for CPU optimization and allow it to kill apps. Now, open the ignored apps list and keep allowed apps to minimum. If you want to do the battery doctor thing the hard way then install Ultimate Backup by jrummy from Playstore. Give it root permission and on its "Tasks" screen, open Minfree Manager and use preset "Strict or Aggressive" and check "Apply on boot" and save the settings. I hope that your phone will be super-lag-free now B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) Thx, I'll try it now ^^ a ram swap patch like in cink slim, doesn't exist for our peax ? Modifié 19 octobre 2014 par keygen1gggg Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 It does exist and I tried to use it once but couldn't implement it. qus1 or any other who has done it before could enlighten us about it. I also want to know how to do it because our phone is very much capable of handling complex apps but cannot do it due to lesser amount of RAM :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) Links if it does exist ? And i'll figure out how to use it and upload a tutorial. At least you have 1G RAM, me I only have 512 Modifié 19 octobre 2014 par keygen1gggg Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
kimo06 Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 RAM expander ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) RAM expander ?I was talking about custom recovery patch/flashable zip Modifié 19 octobre 2014 par keygen1gggg Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
frankee Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) Hello, I recommend that method. Expander RAM and other stuff like work on this principle: A SWAP partition RAM is created on the SD card, so that the total amount of RAM be RAM+ SWAP RAM on SD card.Well. except that there is a problem, physically things: reading/writing speed RAM is extremely matured (several thousands of operations per second) therefore a special magnetic memory (DDR 3) is used so RAM be capable of ensure the desired reading speed writing. Except that the SD card does not support such high speeds too, because physically, it's not possible. The result of RAM expander will be: it will look for a few days it works great. But after one week or more, the SD card will be physically botched, so that SD card -> bin, without the possibility of reformatting (formatting is software, the problem is hardware). and if we put the SWAP RAM to the internal SD card ... the consequences can be even worse ... So I strongly recommend the use of such methods. Bonjour,RAM expander et les autres trucs de ce genre fonctionnent selon ce principe: Une partition SWAP RAM est crée sur la carte SD, afin que le volume total de RAM vaille RAM + SWAP RAM sur carte SD. Bien. sauf qu'il y a un problème, au niveau physique des choses: la vitesse de lecture écriture sur la RAM est extrêmement elevé (plusieurs milliers d'opérations à la seconde) donc on utilise une mémoire magnétique spéciale (DDR 3) capable d'assurer la vitesse lecture écriture voulue.Sauf que la carte SD, ne soutient pas ces vitesses trop élevées, car physiquement, ce n'est pas possible.Le résultat de RAM expander sera : on aura l'impression, durant quelques jours que ça fonctionne à merveille. Mais au bout de 1 ou plusieurs semaine, la carte SD sera physiquement bousillée, de telle sorte que carte SD --> poubelle, sans possibilité de reformatage (le formatage est logiciel, le problème est hardware). et si on a mis le SWAP RAM sur la carte SD interne... les conséquences peuvent être plus graves encore... Donc je déconseille fortement l'utilisation de telles méthodes. Modifié 19 octobre 2014 par frankee Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) Links if it does exist ? And i'll figure out how to use it and upload a tutorial. At least you have 1G RAM, me I only have 512 Our My phone has also 512 MB of RAM same as yours because these are the same phones. However, I have just checked that our phone's kernel doesn't allow swappiness through app MemoryInfo Swap Checker. However here is a good tutorial that tells how to swap RAM through swapper if your phone's kernel doesn't allow swappiness. if it works as it is written in the tutorial then it will be a great boost for our devices. I will check it soon. Qus1 can do it because he has been playing with source kernel and he can enable the Swap support in the kernel. I hope that he could read it. Modifié 20 octobre 2014 par Ali Agha Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
keygen1gggg Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) Our phone has also 512 MB of RAM same as yours because these are the same phones. However, I have just checked that our phone's kernel doesn't allow swappiness through app MemoryInfo Swap Checker. However here is a good tutorial that tells how to swap RAM through swapper if your phone's kernel doesn't allow swappiness. if it works as it is written in the tutorial then it will be a great boost for our devices. I will check it soon. Qus1 can do it because he has been playing with source kernel and he can enable the Swap support in the kernel. I hope that he could read it. Wiko Cink Peax doesn't have 1gb RAM ? Modifié 19 octobre 2014 par keygen1gggg Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
frankee Posté(e) 19 octobre 2014 Share Posté(e) 19 octobre 2014 (modifié) Peax has 1Ghz RAM, actually. but @@Ali Agha has a peax clone, with only 512MB RAM, as yours. Modifié 19 octobre 2014 par frankee Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 20 octobre 2014 Share Posté(e) 20 octobre 2014 (modifié) My bad, I wrote "our" :emo_im_lips_are_sealed: Unless, a swap supported kernel is released for our phone, optimization through Minfree Manager is good for us. Modifié 20 octobre 2014 par Ali Agha Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 20 octobre 2014 Share Posté(e) 20 octobre 2014 KIT-KAT IS STARTING! :) all functions doesnt work now, because rom without changes, i think if i can start some function i will upload :) 5 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fallout81 Posté(e) 21 octobre 2014 Share Posté(e) 21 octobre 2014 That's a great new ! :) Thanks Qus for all your work ! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 21 octobre 2014 Share Posté(e) 21 octobre 2014 KIT-KAT IS STARTING! :) all functions doesnt work now, because rom without changes, i think if i can start some function i will upload :) Wow! great job qus1. Please, upload it soon. I am ready to try it. A little suggestion as discussed above. Please, activate swap support in both JB2 and KK so that phones having only 512 RAM could enjoy improved performance. Hats off to you for all the effort for all of us ^_^ 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
frankee Posté(e) 21 octobre 2014 Share Posté(e) 21 octobre 2014 (modifié) Such a great new!Thanks you so much @@qus1 for your hard work! Your work is really great! PS: When you'll upload the ROM, don't forget to create a new topic Modifié 21 octobre 2014 par frankee 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 21 octobre 2014 Share Posté(e) 21 octobre 2014 for jb2 3.0 last update doesnt good, because kernel 4.2 doesnt support some function from 4.4, its bad idea transport some function in kernel from 4.4 to 4.2 but i know how i can fix some bugs, late i will update 3.0 to 3.1 1st news by kk, too many problems with libs, modem, because if mediatek realised kk for amoi as 4.2, i will fix too fast some problems for kernel, but lg pro lite really hard phone... here phone use some pins for sound+another structure headphone(accdet drivers doesnt respond) + power really specification for lg in kernel(phone is hot) +camera(too many 6577 and peax have camera hardware drivers 0825-27 but here hard drivers with another name :) its main problems now but dont panic may be i will fix this problems in kernel i have some ideas for change peax codegen and add some functions :) 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ali Agha Posté(e) 21 octobre 2014 Share Posté(e) 21 octobre 2014 @qus1: Please, add swap support in kernel for v3.1. Everyone is anticipating eagerly for v3.1 and memory swap for our phone. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 21 octobre 2014 Share Posté(e) 21 octobre 2014 i will try, just need understand why swap is blocked... new drivers by mediatek blocked swap, because in kernel config swap activated :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
