TrustNo_1 Posté(e) 29 août 2013 Share Posté(e) 29 août 2013 (modifié) FONCTIONS : Based on 4.18.401.2 Android 4.2.2 Sense 5.0 Final. Require's Hboot 1.36 Multi-language (WWE). ROM is build with the Latest Dsixda's Android Kitchen. Deodexed, Recompressed & Zipaligned. Some Fixes and removed some unnecessary Stuff. Unsecured boot.img. Persistent ADB enabled. SuperSU, Busybox and Sysro/sysrw commands support. Init.d scripts support. All Add-ons and Mods can be installed tru Aroma Installer. Aroma only system Partition format for Updating."]This option does not install the data/apps again[/color]). Aroma restore's now your selected settings(Don't work if you format the data partition before you run aroma installer). Widget Scanner script Seb's Wipe script Beautiful BugX Bootanimations Choose between 21 different battery mods Choose between 3 different Seb's HighDef connectivity mods CHANGELOG : BugX 6.0.3: Sense 5 - 4.2.2 - Build from scratch again- CRT off as default- Removed Transition Animations from 4.3- Removed Font from 4.3- Add new Home Menu (thanks to lyapota)- Add new APM (thanks to lyapota)- Add 30 pos. media volume control (thanks to lyapota)- Removed weather mods(to much difference in the weather widgets)- Added Optional removal Horizantal EQS- Added Optional All Transparent (Folder - Navbar - Weather)-(thanks to ckpv5)- Fixed LiveWallpapers (you never guess which files caused it)- Fixed Smartdial- Add Optional to Disable 3-Dot Menu- Made the Backlight Brightness a little lower then normal (a little bit)- Disable signature checks....BugX 6.0.2: Sense 5 - 4.2.2- Fixed bad Wifi ...Finally.. (thanks to RichmondoUK)- Removed some system/apps (now in data/app)- Added / Updated data/apps- Added Gps to EQS- Reorderd EQS- Added Horizantal EQSBugX 6.0.1: Sense 5 - 4.2.2- Fixed Battery % (so all battery and connectivity mods are still in)- Added Home screen menu (thanks to baadnewz)- Added default one press recent apps for home menu- Added Optional android Lock-Appdrawer icon- Added TaskManager to system/appBugX 6.0: Sense 5 - 4.2.2- Changed rom to base 4.18.401.2 (Sense 5 4.2.2) (thanks to mike)- Removed apps removal (if you want apps removed then do it manually)(not much time to figure out what is what)(maybe some day if i have time)- Removed also Desense (it is a sense rom no aosp rom,always hated that option)- Added Optional CRT OFF animation (thanks to Baadnewz)- Added Optional Sense and Weezle Weather Icons (thanks for Basil)- Added Optional Sebs Signal and Connectivity icons- Added Advanced Power Menu- Added Transition Animations from 4.3 (thanks to baadnewz)- Added Font from android 4.3 (thanks to baadnewz)- Added Optional Center Clock- Added Optional Odex rom on first boot TELECHARGEMENT : http://click.xda-developers.com/api/click?format=go&key=f0a7f91912ae2b52e0700f73990eb321&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D2063556&v=1&libId=8fcf38f6-76f1-40f3-af03-e3c27b9a3c90&out=http%3A%2F%2Fsourceforge.net%2Fprojects%2Fbugx%2Ffiles%2FROM%2FBugX_6.0.3-4.18.401.2.zip&ref=http%3A%2F%2Fforum.xda-developers.com%2Fforumdisplay.php%3Ff%3D1536&title=%5B27-08%5D%5BROM%5D%20BugX%206.0.3%20%5BSense%20%7C%20HTC%20One%20X%20%3E%20XDA&txt=&jsonp=vglnk_jsonp_13778000463757 --- MD5 : 623F8E69A72ADADCFAEDF7BDB8DD83C2 --- Modifié 30 août 2013 par nicolas@LOVE.android/4 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
boisdulait Posté(e) 29 août 2013 Share Posté(e) 29 août 2013 Hu², bien vu ;) Tu veux des screens ? je suis dessus actuellement 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 30 août 2013 Auteur Share Posté(e) 30 août 2013 Ça serais sympa merci ^_^ tu peut me les envoyés en mp pour que e les mettent dans le post ou alors tu les met dans ton message comme tu veux Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
