jeyy Posté(e) 17 septembre 2013 Share Posté(e) 17 septembre 2013 (modifié) source du tuto caractéristiques: HTC base: 3.17.401.2 - credits LlabTooFeR for the base (Link) Stock Kernel: 3.4.10 with s-on kernel flasher by xhausx ElementalX Kernel - By Flar2 (optional) (link) myHUB - Fully Sensed HUB – by Microsmile (link) OTA support via native updater – By m0narx (link) Instant Power Off in Notification bar By ♀Mivahe (link) Blinkfeed removal (optional) first M7 rom without Blinkfeed (link) two roms in one zip: 1 slightly customized stock and 1 Colored version via vrtheme Transparent Notification and Navigation Bar (Optional) PureXAudio (Optional) props ZeroInfinity (link) Viper4Android support (optional) Props ViPER520 & Zhuhang (link) CRT-off animation (optional) Props mwilky Several different Weather Icon MODs (optional) Prop Basil3 (link) Camera Volume key mods (optional) By Matt (link) Google 4.3 Camera (optional) Xposed Framework (optional) Sony's Xreality (optional) Multi language (FULL WWE) busybox and init.d support Rooted with latest Superuser by koush persistent ADB enabled sysro / sysrw binaries openvpn / sqlite support disabled logging & removed bloatware advanced power menu - credits Dunc001 for the original mod (link) mail.apk with disabled security by default battery % mod - credits shnizlon (optional) disable 3-dot black bar (via Settings) lower autobrightness values - credits he_stheone64 (optional) wake via volume buttons (optional) to remove grid from contact pic in dialer – credits Ponidkos (optional) power save persistent notification (optional) disable exchange security (optional) NFC on when screen off (optional) NFC Notification Icon (optional) launcher grid sizes (optional) enhanced mms (optional) center clock in notificationbar (optional) custom window transition animations (optional) Custom fonts (optional) Lagfix on every reboot Cyanagon LockClock (optional) Ramdisk improvements Battery life, performance and memory improvements Optimized with latest sdk Stable and many more modifications under the hood éléments requis: Bootloader dévérouillé dernier recovery TWRP (pour profiter au mieux des OTA ) S-OFF recommandé (mais non obligatoire) screenshots (version stock): (version blue) : la team: ♥ Chef Dev: V6-Maniac♣ Team Member : Seriously Crazy♠ Recognized Contributor: Dublinz♠ Recognized Contributor: Prinz069♠ Recognized Contributor: Juancubo♠ Recognized Contributor: Ty5982♠ Recognized Contributor: Mdpgc♠ Team B Member: Saugbaer♠ Team B Member: Hd2neuling♠ Team B Member: Tantin75♥ Team Members: All Elegancia Users téléchargements: site du dev lien du serveur xda lien profil du dev "Android File Host" mise a jour par SVN customiser les quick settings pour faire un don: mes impressions: rom très fluide . a 1ère vu elle a l'air d'avoir une bonne autonomie . un petit bug (connu) rencontré : dans l'appli "messages" dans options>générales si l'appli FC, il vous faut installer titanium backup et vider les données de l'appli "message" pour plus d'explications sur les éventuels bugs rendez-vous au post 3 sur xda >> http://forum.xda-developers.com/showpost.php?p=43263935&postcount=3 Modifié 19 septembre 2013 par superjey Lien vers le commentaire Partager sur d’autres sites More sharing options...
themandans Posté(e) 28 mars 2014 Share Posté(e) 28 mars 2014 (modifié) Hello, Sortie de Elegancia SithSense 1.0.0 http://forum.xda-developers.com/showthread.php?t=2694215 Modifié 28 mars 2014 par themandans 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 13 avril 2014 Share Posté(e) 13 avril 2014 (modifié) La rom n'est plus suivie, le dev rejoint la team InsertCoin... - Lien - Modifié 13 avril 2014 par W4R Lien vers le commentaire Partager sur d’autres sites More sharing options...
