[ROM][JB][ALL BL] uniQue 2 (release 29/9/13) sk-cz xperia team (xda)
Invité Américo Da Silva
présente
____________________________________
screenshots
détails et téléchargement
● ROM basée sur le firmware 9.1.A.1.140 skyfall edition.
● pour bootloader bloqué ou déblocable (merci Sony)
● all apps updated 16.05.2013
● rapide, stable et sans erreurs (avec le kernel stock avec boot déverrouillé)
● darkui theme (complete gui + full dialler + sms + email + taskswitcher) and (googleplay + gmail + youtube THX RootzWiki)
● with own customization of some dully`s79 buttons (thx dully79)
● phone dialer (more modifications will be in addons) suivre le lien source pour les addons
● optional onscreenbuttons (will be in addons)
● optional launcher (adw launcher 1.3.3.8 and xperia launcher 2.0.5b)
● no xperia z applications !!!
● superuser included
● mobile bravia engine 2 (works only locked BL, encore merci à Sony pour ceux qui ont leurs boot bloqués)
● batter battery consumption (25% less battery drain during common use and 70% during deep sleep -> night consumption max 1% for 6h.)
● pureaudio 14 full from zerofinity (purexhifi, purexintenseblast, s-force front surrond 3d) (thx zerofinity)
● integrated skip-track-volume-long-press based from xposed installer and modules (thx rovo89) (don`t run xposed, but you can damage rom)
● modified statusbar from peetr_ (18 switches + circle battery, 1% indicator) (thx peetr_) (in ADDONS)
● modified stock statusbar (circle battery, 1% indicator)
● reworked lowmemorykiller for 1gb ram
priority tweak (important apps are persistently stored in ram)
● fstrim – better response i/o of internal memory (thx chrone)
● overclockinkg, underclocking, undervolting (with custom kernel doomkernel5)
● init.d support sqllite3
● enabled gpu ui rendering
● full root with working nfc
● onscreenbuttons 30px/36px (portrait/landscape)
● advanced reboot menu (thx nurij)
● without bloatware
● speed dial mod
● modified settings (dock, power widgets)
● modified themes + skyfall (fully reworked background and wallapers) (THX danisariandi for his idea)
● modified control and notificaton of full data storage from 75% to 90%
● modified taskswitcher with close all button
● new and original shutdownanimation
● ui sounds from nexus
● ultra clear sound output through headphones and speaker
et plus... À la source: forum.xda-dev ;)
ATTENTION:
l'installation d'une ROM efface toutes infos de l'appareil, faite toujours une sauvegarde car vous seul êtes responsable en cas de problème ou de mauvaise interprétation et manipulation.
Installation avec CWM:
  • télécharger ● unique V1 ●
  • démarrez en mode recovery (éteindre le XT, lorsque le logo Sony apparaît, restez appuyé sur le volume +.
  • naviguez avec les boutons du volume et confirmer avec le bouton on/off
  • faire une sauvegarde (backup to SD card)
  • sélectionnez -> instal zip from sd card --> choisir: zip from sdcard ---> select .zip (sk-cz_xperia_team_uniQue-XT_final ) ----> yes
  • Redémarrez le téléphone, laissez le système s'amorcer, faire ses réglages de base et redémarrer une nouvelle fois.
  • et voilà la jolie ROM.
NOTE: (si vous n'avez pas CWM)
source, retour et remerciement: forum.xda-dev :)
