[DEV][ROM][11.10] CyanogenMod 10.2 (Android 4.3.1)
This is my port of CyanogenMod 10.2 for ZTE Blade. It is unofficial and unsupported by the CyanogenMod team. This ROM is mainly for developers/testers/advanced users. I'm really not interested in hearing whining about non-working things (and questions when they will be fixed), actually I couldn't care less if you have issues with this ROM. wink.png There's instructions/sources in the third post to build CM10.2 yourself. If you must have something fixed right now - you better do it yourself.
post-834050-0-95739400-1379864610_thumb.  post-834050-0-44243600-1379864641_thumb.  post-834050-0-85732500-1379864655_thumb.  post-834050-0-03836600-1379864678_thumb.
cm-10.2-20131011-KonstaKANG-blade.zip (please don't mirror this ROM)
md5:4e3d5a2b1ae256486b900498c657fd38
gapps-jb43-20130924-KonstaKANG.zip
md5:e655452666f072f5a345b4c19bc33973
You'll need at least 180mb system partition for the ROM and gapps to fit. Both gen1->gen2 and G2 TPTs are available at Amphoras' site. Gen3 patch for CM7/9/10/10.1 available at my CM9 thread.
Working:
  • Wifi
  • RIL (mobile network & data)
  • GPS
  • Bluetooth (& bt-tethering)
  • Audio (playback/input/routing/headphones/etc)
  • Camera (photos, camcorder & panorama)
  • Hardware acceleration and OpenGL rendering
  • Hardware video decoding & encoding
  • SD card
  • USB-storage & adb
  • USB-tethering
  • Wifi-tethering
  • Touchscreen/multi-touch
  • Sensors
  • LEDs
  • FM radio
Not working:
  • few small things
Sources:
  • CyanogenMod team & everyone who's been working on CM10.2
  • AndroidMeda @androidarmv6 & plaguedbypenguins
11.10. changelog:
  • android 4.3.1
24.9. changelog:
  • fixed data indicator arrows in wifi/signal icons
  • added vibrator intensity tuning (Settings -> Device - More... -> Vibrator intensity)
  • updated to google apps package to fix initial device setup
22.9. changelog:
  • initial release
Sujet original : http://www.modaco.com/topic/365330-devrom229-cyanogenmod-102-android-43/#entry2159908
Modifié par ablackswan
je l'ai installé également, mais avant j'ai changé le TPT à 220 Mo, et finalement ça va pas trop mal, ça rame quand même un p'tit peu.
Il faut forcement faire le deuil de la super fluidité qu'on avait avec la CM7....
edit :
je viens de me reformater une partoche en ext sur ma SD avec Mount2Sd, et là, c'est le jour et la nuit, la fluidité s'est nettement améliorée
Modifié par Boostersnake
par acquis de conscience je viens de réessayer l'Eco CM7, et franchement y a pas photo ! je reste sous CM7 à partir de maintenant ! quelle fluidité et quelle rapidité !
de toutes façons pour le tel et les sms, c'est largement suffisant. Fini la course au dernier update qui ne fait qu'alourdir le bouzin !
  • 1 month later...
MAJ KONSTAT:
Most likely my last build for ZTE Blade. ROM + gapps from the first post do not fit 180mb /system anymore! If I did my math correct, ROM + gapps is 181.3mb now so you'll need to trim at least couple of mbs to be on the safe side. Or you can of course always do a TPT for bigger system partition.
cm-10.2-20131220-KonstaKANG-blade.zip (please don't mirror this ROM)
md5:11913723d5473145aa34176627337dc4
-CM 10.2.0 final
-WhisperPush (merged)
Gen1 TPT for optimised partition layout:
This will only work in european phones that were sold with gen1 layout (eclair) and/or updated to gen2 via TPT method. This TPT won't work if your phone was sold gen2/gen3 or you have used a windows tool to update.
Gen1-to-Gen2-TPT-KonstaKANG.zip
http://d-h.st/SmZ
md5:c5201d683b1b760f9b5dd94d3be4ef19
Gen2 TPT for optimised partition layout:
This will only work in european phones that were sold with gen2 layout (froyo) or if you have used a windows tool to update.
G2-TPT-KonstaKANG.zip
http://d-h.st/ZrB
md5:6b4f47c4c3784d1018a3d4daef0a7f98
TPT instructions:
  • Copy cm-9-xxxxxxxx-KonstaKANG-blade.zip and gapps-ics-medium-xxxxxxxx-signed.zip to your sdcard
  • Unpack Gen1-to-Gen2-TPT-KonstaKANG.zip or G2-TPT-KonstaKANG.zip to your phones sdcard so that you have 'image' folder on the root of your sdcard
  • Install AFV (Android File Verifier) from the play shop
  • Use AFV to check that MD5 matches. Use 'verify nandroid backup' option to check /sdcard/image/nandroid.md5.
  • Power off, pull battery out, put battery back in
  • Press and hold VOLUME UP and MENU keys while you power on
  • You should see green text on your screen. Installation is in progress and you can let go of the keys
  • It takes about a minute after which your phone will boot into ClockWorkMod
  • Install cm-9-xxxxxxxx-KonstaKANG-blade.zip in CWM
  • Install gapps-ics-medium-xxxxxxxx-signed.zip in CWM
  • Reboot
After completed installation, delete/move/rename 'image' folder so that you don't restart TPT by accident.
GEN3 support:
Converts this ROM to work in devices that were sold with gen3 layout (gingerbread) or if you have used an official package (image.bin) to update. Flash the patch in ClockWorkMod after installing the ROM.
CM9-KonstaKANG-GEN3.zip
http://d-h.st/FGn
md5:827b554fe54979c8d13dfd52767f7261
