GalaxyOnFire Posté(e) 4 novembre 2013 Share Posté(e) 4 novembre 2013 ◢ Features ◣- Android performances improved at 360°- Radically improved management ram on android (Lags...adios!)- Script lightweight and revised to be adapted to this engine- Improves a lot the graphics: of course Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 system tweaks- Scan multimedia time drastically reduced- Network Improvements, 3G experience even in 2G modality- All SQlite database optimized- Enable hardware features turned off by default for a better experience on entry level devices- Greatly increases the score AnTuTu: Try it to believe it!!- Reduces the startup time of Android- A version for stock rom and one for CM, to squeeze any roms!- Allows you to play ported games without lags- Cleans the system every 24 hours, thecache every week and the Dalvik every month (cronos easter egg)- Automatically Zipalign on each boot (sensitive to the user)Battery- Drastically decreased the drainage of battery- Check the activities that consume too much battery stop them with PureWakelocks™- When the phone is charging reduces system services for faster charging- The battery is calibrated on every boot- Disable animation of the system when the battery is nearly exhausted- Improvements in build.prop as regards the part of consumptionGraphics, Screen, Images- Enables a non-aggressive dithering to save CPU- When you lock the device, the engine makes sure that the GPU is turned off- Enables deep sleepalso in the bugged rom- Parts of bravia engine- Of course parts of CrossBreeder (credits to dev)- Of course parts of Adrenaline Engine (credits to dev)- Of course PureGraphics HD, even though I already told you - Of course V6 supercharger- Generates video entropy (like seeder)CPU, Governors, I/O Schedulers- Slightly improves the scaling of the frequencies (for better results you need a good kernel)- Lightens the load on the CPU switching the workload to GPU rendering- Enable the swap partition in Android (experimental) ◢ Compatibility ◣ This engine works on any devices with any rom, but there is a version for CM's rom and one for stock based firmwares. So, CMx.x, Lewa Os, MIUI, etc. Install the stock version only on your stock firmware of your phone.... if your device don't have gingerbread or ICS officially, install the CM version (This also applies to the AOSP) Downloads Stock Version: http://www.mediafire.com/download/q0..._Stock.1.4.zipCM Version: http://www.mediafire.com/download/62...A2X_CM.1.4.zipDésinstallateur: http://forum.xda-developers.com/show...6&postcount=62 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 4 novembre 2013 Share Posté(e) 4 novembre 2013 Salut :) C'est sympa de venir présenter des mods sur le fofo, mais ce serait mieux de traduire stp, tout le monde ici ne parle pas anglais ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KaporalZ Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Il faut prendre la version CM pour ta rom Probam ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 La ProBam est une AOSP alors oui il faut la version CM :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Si je comprend bien [color=red][b]sa[/b][/color] neva pas avec boeffla sur ROM stock Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Où as-tu vu ça ? Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Install the stock version only on your stock firmware of your phone.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Ça ne dit rien à propos du kernel ;) Ça dit juste que la version stock du mod est à installer uniquement si tu as un firmware stock Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Donc firmware boeffla faut prendre la version aosp du mod ? Sur une ROM stock ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 5 novembre 2013 Share Posté(e) 5 novembre 2013 Ah non Boeffla est un kernel, pas un firmware ! ;) Le firmware c'est le système, donc avec la ROM stock tu as le firmware stock :) Donc il faut que tu flashes le mod en version stock Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 6 novembre 2013 Share Posté(e) 6 novembre 2013 MDR je me suis rendu compte de mon erreur au travail est étant a l'étranger je n'ai pu me rectifié. J'ai honte Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 6 novembre 2013 Share Posté(e) 6 novembre 2013 Ah ça arrive à tout le monde de dire des bêtises ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 8 novembre 2013 Share Posté(e) 8 novembre 2013 Petite question est ce que ce mod fonctionnera toujours sous la 4.3 ? Merci d'avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Timal007 Posté(e) 9 novembre 2013 Share Posté(e) 9 novembre 2013 Bonjour, je suis sous android revolution hd, je dois bien prendre la version pour rom stock ? merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 9 novembre 2013 Share Posté(e) 9 novembre 2013 Hum il me semble que l'ARHD est dispo en version AOSP et en version TouchWiz... M'enfin c'est simple ! ROM AOSP : version CM ROM TouchWiz : version stock ;) Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
push29onRG Posté(e) 9 novembre 2013 Share Posté(e) 9 novembre 2013 (modifié) Pour un Galaxy S3 en version 4.1.2 rooté. Je doit prendre la version rom stock ou bien CM. je n' est pas installé de ROM Custom. Modifié 9 novembre 2013 par Push29 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 9 novembre 2013 Share Posté(e) 9 novembre 2013 Même root ton firmware reste stock en gros la seul raison de prendre le non stock c'est quand tu est en aosp (cm,revolt, etc...) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
APS Posté(e) 9 novembre 2013 Share Posté(e) 9 novembre 2013 (modifié) Bonsoir, J'ai un doute, j'ai la ROM PureLookHD et j'ai installé la version CM, j'ai bon ? :P Modifié 9 novembre 2013 par Tom'zs Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 10 novembre 2013 Share Posté(e) 10 novembre 2013 (modifié) pour ma part je pense que purelook et en firmwear stock donc prendre la version stock ! Modifié 10 novembre 2013 par deraiz12 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 10 novembre 2013 Share Posté(e) 10 novembre 2013 Bonsoir, J'ai un doute, j'ai la ROM PureLookHD et j'ai installé la version CM, j'ai bon ? :PNon la PureLook est une ROM TouchWiz ! ;) Envoyé depuis mon GT-I9300 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
push29onRG Posté(e) 10 novembre 2013 Share Posté(e) 10 novembre 2013 Même root ton firmware reste stock en gros la seul raison de prendre le non stock c'est quand tu est en aosp (cm,revolt, etc...)Donc je prend la Version stock ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ster97 Posté(e) 10 novembre 2013 Share Posté(e) 10 novembre 2013 (modifié) Oui, si tu n'as pas mis de ROM custom tu as toujours la ROM stock ! Envoyé depuis mon GT-I9300 avec Tapatalk Modifié 10 novembre 2013 par Ster97 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 17 novembre 2013 Share Posté(e) 17 novembre 2013 Bonjour, Je réitère ma question est ce qu'il est utile de l'appliquer sur une 4.3 ? par contre je souhaite signifier que sur rom AR HD seeder ne fonctionne plus une fois le mod appliquer! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 17 novembre 2013 Share Posté(e) 17 novembre 2013 Bon je me répond a priori cela diminue grandement les performances en 4.3 en tout cas sous rom AR HD . Merci d'avoir pensé au dèsinstallateur. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
