Nabster Posté(e) 15 novembre 2013 Share Posté(e) 15 novembre 2013 (modifié) Bonjour ce mod a pour but d'améliorer la qualité de vos photos et vidéos prisent avec votre Nexus 5 B) JE NE SUIS PAS L'AUTEUR DE MOD ET EN AUCUN MOI OU LE DEVELOPPEUR NE SERA TENU POUR RESPONSABLE DES PROBLEMES RENCONTRES AVEC CE MOD. Installation : Flashez le zip avec votre Custom recovery Voici une vidéo de techfanatic9 qui montre comment installer et les avantages que ça a. http://www.youtube.com/watch?v=pYvoC770gWM Updates :V1 :1)Stock Bitrate are as follows:720P@12 Mb/s.1080P@17 Mb/s.Modded are as follows:720P@20 Mb/s.1080P@26 Mb/s.2) Audio Bitrate quality :Stock = 96000 Kb/s Modded =192000 Kb/s3) Image Encode Quality : Stock = 90.Modded = 99.4) JPEG Encode Quality : Stock = 80.Modded = 99.5) Modified hammerhead.camera.so for better sharpness of the pictures. Increased the Sharpeness to 90 from 75. V1.1 :1) Sound Recording now in Stereo with the secondary Mic. 2) Faster Focusing for the camera.3) Front Camera also records 720P Videos@ 20 Mb/s. 4) Front camera Audio Bitrate@ 192000 Kb/s.5) AntiBanding default set to 50Hz6) Focus Range Adjusted.7) Enhanced Smooth Zoom .8) Turned Edge Enhancement ON.V1.1 WO Noise Cancellation :1) Everything same as V1.1 except the secondary mic kicking in for Noise cancellation.V1.2 :1) Decreased the Bitrate of the Videos as follows: 1080P @ 22Mb/s.720P @ 18Mb/s. *This is the Optimal Bitrate for all the Device* 2) Adjusted the Mic's Treble Enhancer to a lower value. *Less Chirpness*3) Audio Bitrate Set to 216000kb/s from 192000kb/s . Should Follow Nokia Lumia 1020 Audio Quality Almost. 4) Enhanced the Noise Cancellation Mic for better/ a bit lower Cancellation .5) Enhanced Skin Tone Color Hue. Tends to be a little lighter fro stock.6) Increased the Memory Cap to 30Mb so that cache is not filled up if the Bitrate shoots higher by chance.7) Exposure Compensation adjusted for compensating for lower exposures when overbright. V1.2 WO Noise Cancellation:1) All of the Above.2) No Noise Cancellation Mic Kicking in. [Removed]V1.3 :1) Set JPEG Quality to 100 % .[Max Possible]2) Set JPEG Compression to NIL (Zero Compression, should come out almost RAW [Though processed] ).3) Set Medium Quality JPEG's to 100. 4) Set Low Quality JPEG's to 100. 5) Increase Picture Color tune to warmer side. 6) Color Reporduction should be even better because of modded libJPEGhw.so. 7) Audio Bitrate Set to Max possible i.e 288000kbit/s. [Highest Value]8) Fixed Low memory error in libJPEGhw.so .9) Fixed, MAYBE the LOW FPS Problem. [DOUBT]V1.3 WO Distortion:1) All of the Above.2) No Noise Distortion [Removed]V1.3 WO Noise Cancellation:1) All of the Above.2) No Noise Cancellation Mic Kicking in. [Removed]V1.4 [TEST] In this Version the main work is done on the Video stabilization. If I understand correctly, the FPS drop is due to this in low light. Please Try it out, if bootloops please flash any of the previous versions. Version conseillée : V1.3 DOWNLOAD : V1 : http://forum.xda-developers.com/attachment.php?attachmentid=2376792&d=1383814276V1.1 : http://forum.xda-developers.com/attachment.php?attachmentid=2377016&d=1383823796V1.1 Suppression du bruit : http://forum.xda-developers.com/attachment.php?attachmentid=2377153&d=1383827890V1.2 : http://forum.xda-developers.com/attachment.php?attachmentid=2380050&d=1383942085V1.3 : http://forum.xda-developers.com/attachment.php?attachmentid=2384349&d=1384116459V1.3 Distortion du bruit : http://forum.xda-developers.com/attachment.php?attachmentid=2388261&d=1384280379V1.3 Suppresion du bruit : http://forum.xda-developers.com/attachment.php?attachmentid=2388262&d=1384280379V1.4 EN TEST : http://forum.xda-developers.com/attachment.php?attachmentid=2388345&d=1384284032 Merci à Jishnu Sur pour travail :P . Source : http://forum.xda-developers.com/showthread.php?t=2516061&nocache=1 Modifié 21 novembre 2013 par Nabster 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
phil2nice Posté(e) 21 novembre 2013 Share Posté(e) 21 novembre 2013 J'ai pas encore reçu mon N5, mais pour ceux qui l'ont et qui ont essayé ce mod, quel retour en avez vous? c'est effectivement mieux? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nabster Posté(e) 21 novembre 2013 Auteur Share Posté(e) 21 novembre 2013 Le 21/11/2013 à 08:38, phil2nice a dit : J'ai pas encore reçu mon N5, mais pour ceux qui l'ont et qui ont essayé ce mod, quel retour en avez vous? c'est effectivement mieux? Voilà des retours :) . Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
maxou88 Posté(e) 21 novembre 2013 Share Posté(e) 21 novembre 2013 C'est des photos que tu as prise ? Ca viens de toi ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nabster Posté(e) 21 novembre 2013 Auteur Share Posté(e) 21 novembre 2013 Le 21/11/2013 à 09:37, maxou88 a dit : C'est des photos que tu as prise ? Ca viens de toi ? Non ce sont des retours de topic source :) . Je suis déjà en 1.3. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
maxou88 Posté(e) 21 novembre 2013 Share Posté(e) 21 novembre 2013 D'accord ? tu pense que ça vaut le coup ? Je vais le faire alors ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nabster Posté(e) 21 novembre 2013 Auteur Share Posté(e) 21 novembre 2013 Le 21/11/2013 à 10:26, maxou88 a dit : D'accord ? tu pense que ça vaut le coup ? Je vais le faire alors ;) J'ai comparé avec le nexus 5 d'un ami il y a bien de la netteté dans les images. Tu peux le faire :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
maxou88 Posté(e) 21 novembre 2013 Share Posté(e) 21 novembre 2013 Okay ;) Je suis en stock rooter mais je suis pas fan des [MODS] ^^ J'ai juste mis le mod reboot recovery :p Mais je vais essayé le kernel franco aussi :p Et je vais crée un topic pour le [MOD] pour avoir un volume plus élevé Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nabster Posté(e) 21 novembre 2013 Auteur Share Posté(e) 21 novembre 2013 Le 21/11/2013 à 10:49, maxou88 a dit : Okay ;) Je suis en stock rooter mais je suis pas fan des [MODS] ^^ J'ai juste mis le mod reboot recovery :P Mais je vais essayé le kernel franco aussi :P Et je vais crée un topic pour le [MOD] pour avoir un volume plus élevé Je viens de changer de kernel pour aller cher elemental mais le double tape to wake fonctionne pas ni le s2w. Je vais réinstaller. Je viens d'installer le mod pour pour le son aussi :) . Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
maxou88 Posté(e) 21 novembre 2013 Share Posté(e) 21 novembre 2013 (modifié) Pour le mode son: Tu as rien besoin d'installer , juste à modifier la valeur dans un fichier system ;) http://forum.xda-developers.com/showthread.php?t=2532788&page=13 fichier \system\etc\mixer_paths.xml Modifié 21 novembre 2013 par maxou88 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nabster Posté(e) 21 novembre 2013 Auteur Share Posté(e) 21 novembre 2013 Oui mais mais j'ai flashé le zip avant de voir qu'on pouvait directement modifier ^^. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
