[ROM] 4.4.2 | MoKee Opensource | 12.18.2013 | CM & AOSP
Bienvenue sur MokeeOS Opensource Project
#include <std_disclaimer.h>
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
About MoKee OpenSource:
MoKee OpenSource is based on the Google AOSP and CyanogeMod project. We update our source code frequently to keep up with the latest development, and not forgetting to merge in special features of our own at the same time.
The Mfunz Forums launched this project on the 12th of December 2012, and is committed to make this ROM better and better.
Since this project is open source, anyone interested can participate in the development. Newcomers are always welcomed!
Official website: http://www.mfunz.com
C'est ma première rom compilée à partir des sources
Je n'ai pas encore le téléphone donc je ne peux pas la tester pour le moment.
Vous pouvez appuyer sur le bouton merci   :)
Fonctionnalitées
  • Basée sur CM11
  • CM Kernel
  • Deodexée
  • Rootée
  • Les thèmes de CM fonctionnent
  • Mokee apps
  • Amélioration de la team Mokee
  • init.d support
  • nano support
  • Bien plus à venir
Fonctionnel
  • Dites moi
Bugs
  • Dites moi
Changelog
  • [18.12.2013] Première version
Téléchargements
MokeeOs
Gapps:
Installation
  • Télécharger les fichier zip (ROM & Gapps)
  • Redémarrer en recovery (CWM / TWRP)
  • Faites un backup de votre rom avec Nandroid Backup !
  • Wipe/Factory Reset
  • Wipe Dalvik/Cache
  • Flash Gapps
  • Redémarrez !
Merci à:
  • Google pour les sources et le kernel
  • CyanogenMod
  • La team MoKeeOS
