Quentinover Posté(e) 25 décembre 2013 Share Posté(e) 25 décembre 2013 (modifié) Bonjour! Suite à de mauvaises manipulations, mon stockage internet et ma SD interne de ma tablette Polaroid Executive ne peuvent plus être utilisés. Selon Android, j'ai un stockage de 0.00 o Que faire pour les repartitionner, sachant que je ne peux plus rien mettre sur les deux ? Cordialement. PS: J'ai trouvé un solution, mais étant un noob d'Android, je ne comprend pas comment faire... Quelqu'un pour m'aider ? : Citation Here's the solution.The problem was that I managed to screw up the partitions on my internal storage card, so basically nothing would work properly. I could still get into recovery, though. That's key.Here's what you'll need: Working recovery, basic knowledge of adb & the shell Parted (download here) stock PB31IMG.zip Note also that I had run unrevoked forever (so my phone was S-OFF) ... I'm not sure if that's required or not.So, grab parted from the link above. Now you need to extract the individual binaries from the .zip (the 6 files in the sdparted folder within the zip), ideally to your android-sdk\tools directory. Now push all 6 files (adb push [file] /sbin/). Next, we need to make them useable, so go into the shell (adb shell). Change to your /sbin/ directory, and run: chmod 0755 <file> on each of the 6 files.Now, we need to fix the partitions. This is assuming that the partitions are there, just the wrong format (which is what happened to me .. I accidentally made them FAT32 instead of ext). So, run the following: parted /dev/block/mmcblk0 mkfs ext2. It will ask if you want to continue, hit yes. When it asks for the partition number, enter 1. Next, when it asks for the format, enter ext2. Let it do its thing. Now, once it's done, run parted again. This time, enter partition 2 (everything else is the same).Once all that's done, your recovery program should be able to mount both the /data and /cache partitions. If that's true, you're pretty much done! One thing I found was that I couldn't directly install a new OS (I tried both Cyanogen and Ultimate). In both cases, it would look for stuff in the davik-cache that it couldn't find, so something wasn't installing correctly I think. So, if that happens, flash back to the stock PB31IMG.zip (put it in the root of your /sdcard/ and let hboot install it), and then root your phone anew. That's what I ended up doing. Modifié 25 décembre 2013 par Quentinomino Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lannig Posté(e) 27 décembre 2013 Share Posté(e) 27 décembre 2013 Bonsoir, Cette demande n'a rien à voir avec la sécurité sous Android. Déplacé dans la section tablettes Polaroid. Pour la question : 1) il nous faut au strict minimum le modele exact de la tablette (MIDxxxx sans doute ?) 2) la "solution" n'est absolument pas applicable à une tablette Polaroid ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 30 décembre 2013 Auteur Share Posté(e) 30 décembre 2013 Le 27/12/2013 à 19:35, Lannig a dit : Bonsoir, Cette demande n'a rien à voir avec la sécurité sous Android. Déplacé dans la section tablettes Polaroid. Pour la question : 1) il nous faut au strict minimum le modele exact de la tablette (MIDxxxx sans doute ?) 2) la "solution" n'est absolument pas applicable à une tablette Polaroid ! Voici le modèle exact: MID0927PCE01.112 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 30 décembre 2013 Share Posté(e) 30 décembre 2013 Bonsoir, N'aurais-tu pas installé l'application Busybox depuis Google Play ? C'est le genre de problème qu'elle peut créer, ayant aussi pour résultat de remettre l'appareil à l'état d'usine à chaque redémarrage... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 30 décembre 2013 Auteur Share Posté(e) 30 décembre 2013 Le 30/12/2013 à 21:17, zrt22 a dit : Bonsoir, N'aurais-tu pas installé l'application Busybox depuis Google Play ? C'est le genre de problème qu'elle peut créer, ayant aussi pour résultat de remettre l'appareil à l'état d'usine à chaque redémarrage... si, mais ce n'est pas à cause de ça. Même si j'ai déja eu ce problème :< Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lannig Posté(e) 31 décembre 2013 Share Posté(e) 31 décembre 2013 Comment peux-tu affirmer que ce n'est pas à cause de ça ? moi je pense au contraire que ça l'est, parce qu'on a eu de nombreux exemples de gens qui avaient exactement ce problème suite à l'installation de Busybox depuis Google Play. Et qu'on sait exactement pourquoi, en plus :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 31 décembre 2013 Auteur Share Posté(e) 31 décembre 2013 Le 31/12/2013 à 06:51, Lannig a dit : Comment peux-tu affirmer que ce n'est pas à cause de ça ? moi je pense au contraire que ça l'est, parce qu'on a eu de nombreux exemples de gens qui avaient exactement ce problème suite à l'installation de Busybox depuis Google Play. Et qu'on sait exactement pourquoi, en plus :) Parce que après cette remise en état d'usine, je voulais tout enlever pour tout recommencer. Dans le menu de restauration, j'ai du appuyer sur "Wipe partition cache" une chose comme ça. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 31 décembre 2013 Share Posté(e) 31 décembre 2013 Le reset usine n'efface pas les modifications apportées au système. Le bug auquel on pense enlève le fichier system/bin/busybox et il faut le remettre à la main (ou y mettre un équivalent si on n'a pas l'original). Donc si tu veux vérifier : Mise en place d'adb si ce n'est pas fait : https://forum.frandroid.com/topic/143999-tutoinstallation-adb/ jusqu'à adb shell id et donne nous le résultat de cette dernière commande et de ces deux là : adb shell ls -l /system/bin/busybox adb shell ls -l /system/xbin/busybox Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lannig Posté(e) 7 janvier 2014 Share Posté(e) 7 janvier 2014 Il ne faut pas "supprimer" Busybox, au contraire. L'installateur buggé de la version Google Play supprime celui qui est d'origine sur la tablette dans /system/bin et qui est essentiel au montage des partitions quand la tablette démarre. Il en installe un dans /system/xbin qui ne le remplace pas, puisqu'il n'est pas au même endroit ! Il faut donc recopier l'un vers l'autre. D'où la procédure donnée par Zrt22, déjà pour vérifier qu'on est bien dans ce cas-là. Suivez-la tous les deux... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 8 janvier 2014 Auteur Share Posté(e) 8 janvier 2014 Bonsoir, et désolé de ce reatrd, j'ai eu très peu de temps ces derniers jours. Ayant voulu suivre la procédure, j'ai remarqué qu'il n'était pas possible de faire la manip sur Windows XP... Une idée ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 8 janvier 2014 Share Posté(e) 8 janvier 2014 Bonsoir, Qu'est-ce qui ne va pas avec Windows XP ? C'est celui qui pose le moins de problèmes généralement. Jamais eu de soucis pour utiliser adb avec. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 8 janvier 2014 Auteur Share Posté(e) 8 janvier 2014 Le 08/01/2014 à 18:07, zrt22 a dit : Bonsoir, Qu'est-ce qui ne va pas avec Windows XP ? C'est celui qui pose le moins de problèmes généralement. Jamais eu de soucis pour utiliser adb avec. Je n'ai rien contre Windows XP, au contraire ! ce qui va pas, c'est qu'il y a pas de tuto pour :/ J'ai essayé de trouver le "Gestionnaire de périphériques" mais aucun résultat. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 8 janvier 2014 Share Posté(e) 8 janvier 2014 Google t'aurait rapidement dit où se trouve le Gestionnaire de périphériques sur XP, je pense. :P Une façon parmi tant d'autres : Démarrer > clic droit sur Poste de Travail > Gérer > Il est dans la liste de gauche sous Outils système. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 10 janvier 2014 Auteur Share Posté(e) 10 janvier 2014 Le 08/01/2014 à 19:39, zrt22 a dit : Google t'aurait rapidement dit où se trouve le Gestionnaire de périphériques sur XP, je pense. :P Une façon parmi tant d'autres : Démarrer > clic droit sur Poste de Travail > Gérer > Il est dans la liste de gauche sous Outils système. Ah oui mince... Désolé >< Vu que j'ai une énorme malchance, j'ai ça dès que je veux installer les nouveaux drivers: http://puu.sh/6ghBI J'ai tout suivi, pourtant... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 10 janvier 2014 Share Posté(e) 10 janvier 2014 (modifié) Est-ce le bon périphérique que tu essaies de mettre à jour ? C'est celui qui apparaît en plus en activant le débogage USB, souvent il a "Android" dans le nom. Ou le pilote est-il déjà installé ? Il porte généralement le nom "Android [composite] ADB Interface", auquel cas continuer avec les commandes pour vérifier la connexion. As-tu fait une installation manuelle ? C'est-à-dire guider l'assistant jusqu'au dossier des pilotes, il ne le trouvera pas tout seul. (Pointer le dossier "32Bit_Win_7_Vista_XP" ou "64Bit_win_7_vista", pas un de leurs sous-dossiers) Modifié 10 janvier 2014 par zrt22 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 11 janvier 2014 Auteur Share Posté(e) 11 janvier 2014 Le 10/01/2014 à 20:49, zrt22 a dit : Est-ce le bon périphérique que tu essaies de mettre à jour ? C'est celui qui apparaît en plus en activant le débogage USB, souvent il a "Android" dans le nom. Ou le pilote est-il déjà installé ? Il porte généralement le nom "Android [composite] ADB Interface", auquel cas continuer avec les commandes pour vérifier la connexion. As-tu fait une installation manuelle ? C'est-à-dire guider l'assistant jusqu'au dossier des pilotes, il ne le trouvera pas tout seul. (Pointer le dossier "32Bit_Win_7_Vista_XP" ou "64Bit_win_7_vista", pas un de leurs sous-dossiers) J'ai bien tout fait: Il s'appelle Android ADB Interface, mais je ne peux pas inscrire de commandes. J'ai essayé l'installation manuelle mais toujours rien... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 11 janvier 2014 Share Posté(e) 11 janvier 2014 As tu aussi créé le fichier adb_usb.ini ? (Point 'autre cas' du tuto adb) Il le faut parfois. Si ce n'est toujours pas ça ensuite, désinstalle le pilote "Android ADB Interface" pour installer manuellement celui du ADB.zip à la place. Par "je ne peux pas inscrire de commandes", tu veux bien dire que adb devices ne t'affiche pas de périphérique détecté ? Tout le monde y est arrivé quels que soient leurs systèmes, pas de raison que cela n'aille pas pour toi. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 15 janvier 2014 Auteur Share Posté(e) 15 janvier 2014 Bonsoir, et encore désolé du retard. C'est bon, j'ai réussi : Voici ce que j'ai pour la première commande: /system/bin/busybox: No such file or directory Voici le résultat de la deuxième commande: -rwxr-xr-x root root 822080 2013-12-24 13:16 busybox Bonne soirée ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 15 janvier 2014 Share Posté(e) 15 janvier 2014 Bonsoir, Fichier manquant comme prévu donc. Si tu as eu uid=0(root) en réponse à adb shell id, tu peux faire ça : adb remountadb shell /system/xbin/busybox cp -p /system/xbin/busybox /system/bin/busyboxadb reboot 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 15 janvier 2014 Auteur Share Posté(e) 15 janvier 2014 YES ! J'ai enfin un stockage interne, MERCI ! Par contre, la SD interne est toujours à 0.00 octet... Une solution ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 15 janvier 2014 Share Posté(e) 15 janvier 2014 Essaie de la reformater ? Dans Paramètres / stockage, il y a une option pour ça normalement. Après je ne sais pas s'il y a un busybox-like qui fait perdre l'accès à la SD interne. :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 15 janvier 2014 Auteur Share Posté(e) 15 janvier 2014 Quand je fais ça, ça reste bloqué sur "Désinstallation de la carte SD en cours..." :/ Je pense que cela vient de moi: quand j"avait eu le problème de stockage interne, j'ai voulu réparer ça et j'ai du toucher à la carte SD interne en le formatant sur un mauvais format ._. Une appli android pour formater et changer le format de mémoire existe elle ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 15 janvier 2014 Share Posté(e) 15 janvier 2014 Qu'as-tu fait exactement quand tu as voulu "réparer ça" ? Aurais-tu touché au fichier /system/etc/vold.fstab par exemple ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Quentinover Posté(e) 16 janvier 2014 Auteur Share Posté(e) 16 janvier 2014 J'avais essayer de suivre un tutoriel, qui permettait de la formater et de le changer de format (par exemple NTFS, etc) J'ai crois avoir pris Ext1 ou un truc du genre lors du formattage. C'est à ce moment la que j'ai fait une gaffe :/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lannig Posté(e) 16 janvier 2014 Share Posté(e) 16 janvier 2014 Que donnent : adb shell mount adb shell df Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
