JIAYU G5 Battery Drain
Pilot300
Hi,
Over the last couple of days my JIAYU G5 battery has been lasting just 6 hours with very low use. Before this the battery would last a full day.
Can anyone help with settings as to why my battery is now only lasting 6 hours?
you can verify than an application is not running continuously -> downlaod from playstore "Taskmanager" for exemple... and kill all process running
GPS running indoor consumme a lot of battery so... turn it off when not using it. same thing for wifi and bluetooth...
and if that is not enough, drains the battery quickly (using Gps for example) and then, recharge it completely to 100% several times to recalibrate it
you can also download an application to recalibrate the battery
-> https://play.google.com/store/apps/details?id=com.ignisoft.battery.calibration&hl=fr
hope this should solve the problem
