[XU][Rom][KitKat] CyanogenMod 11
Post original XDA : ici
Pré-requis:
  • Bootloader déverrouillé (attention perte de la garantie définitive)
  • Recovery installé (ClockWorkMod)
Ce qui ne fonctionne pas:
  • Radio FM
  • A2DP (connexion audio via bluetooth)
  • OMX buggé
Instructions:
  • Télécharger la rom (et les gApps, optionnelles)
  • Démarrer sur le recovery (CWM)
  • Faire une sauvegarde (on ne le dira jamais assez ...)
  • Faire un "full wipe"
  • Flasher la rom (et les gApps)
  • Redémarrer
Liens de téléchargement:
Rom  /  gApps
Changelog (en anglais, non traduit, n'hésitez pas à demander si quelque chose vous échappe):
Build 10 (2014-06-15):
- Improve Audio effects
- Allow EGL hibernation
- Fix bootanimation stutters
- Add 1024 free extra kbytes (RAM)
- Enable zRAM (64MB)
- Read only 1 page cluster at a time
- Enable option to wake device using volume rocker
- Start Dalvik with a low memory footprint
- Re-enable JIT cache
- Decrease minimum brightness avalaible
- Updated CM 11 Sources to 2014/06/15
Build 9 (2014-06-08):
- Android 4.4.3
- CWM 6.0.4.9
- Fixed video recording
- Reduced animation scales to 0.75
- Adapted RIL to STE
- Added stereo widening effect
- Improved rotation time
- Restored original autobrightness speed
- Deferred KSM timer enabled
- Built with Google GCC 4.8
- Patches from AOSX
- New OTA Updater Logo
- Updated CM 11 Sources to 2014/06/08
Build 8 (2014-06-01):
- Fixed games Force Close
- Updated ArchiDroid Optimizations to V3
- Changed build type: eng to userdebug
- Updated BlueZ to 5.19
- OMX updates
- Added initial F2FS support
- Made keyboard service persistent
- Added Battery LED control in Settings
- Tuned ActivityManager & LMK to allow more memory to be used by processes
- Fixed LED on boot
- Fixed Reboot to Recovery
- Updated CM 11 Sources to 2014/06/01
Build 7 (2014-05-21):
- System compiled with Linaro GCC 4.8
- Kernel compiled with Linaro 4.9.1 toolchain (optimized for Cortex A9 - Thanks @Christopher83)
- Optimized flags (Thanks @JustArchi)
- Updated CM 11 Sources to 2014/05/21
Build 6 (2014-05-17):
- Fix memory leaks
- Xperia STE bootsplash
- Updated cm-11 Sources to 2014/05/17
Build 5 (2014-05-13):
- SystemUI hangs fixed
- Updated cm-11 Sources to 2014/05/13
Build 4 (2014-05-08):
- Less memory leaks
- Some new video/audio codecs
- Updated CM 11 Sources to 2014/05/08
Build 3 (2014-05-06):
- Device tree, kernel and vendor updated from AOSX (thanks to AOSX team)
- Adapt gralloc, copybit, hwcomposer, stelpcutils, memtrack from sources
- BlueZ updated to 5.18 (Full Stable FTP)
- Fix call via bluetooth
- CWM touch Recovery 6.0.4.8 (updated)
- Updated cm-11 Sources to 5/6/2014
- OTA integrated in Settings > About (and deleted from launcher)
Build 2 (2014-05-02):
- Updated CM11 sources
- Fixed status bar reboots
- RAM management and performance improved
- WiFi passwords keeped after reboot
- App2SD working after reboot
- OTA Updater added
Build 1 (2014-04-29):
- CWM Recovery 6.0.4.8
Retour perso:
Je l'utilise depuis un moment, c'est vraiment un régal.
Kitkat sur des appareils n'ayant pas beaucoup de ram tient ses promesses et on retrouve la fluidité qu'on connaissait avec gingerbread.
La version actuelle est vraiment stable et peut être utilisée au quotidien, bref, je conseille.
Modifié par Dunexus
  • 3 weeks later...
Le WiFi Direct permet de connecter deux appareils compatibles entre eux via WiFi pour s'envoyer des fichiers. En gros, du bluetooth mais avec la vitesse de transfert bien meilleure du WiFi.
Je l'utilise sur xperia GO et elle est géniale, c'est le jour et la nuit avec tout ce que j'ai testé jusque là (bon avant je me limitais avec un bootloader verouillé...) ! Il y a eu une maj d'ailleurs !
Et pas besoin d'avoir CWM à la base, il suffit de flasher le fichier boot fourni dans le dossier de téléchargement en mode fastboot.
  • 3 weeks later...
La rom n'intègre pas les modules permettant de décoder la radio fm par contre les applications qui sont légion et qui permettent d'écouter la radio par internet, elle devrait fonctionner sans soucis.
  • 2 months later...
  • 1 month later...
Hello,
Voilà presque un an que je n'ai pas bidouillé mon téléphone et j'ai envie de m'y remettre.
Je me rappelle que j'avais installé deux ou trois roms différentes pour au final retourner sur un build officiel (6.1.1B.1.89) légèrement modifié par mes soins parce que je n'étais pas convaincu.
Bref, en jetant un œil sur les forums xda et celui-ci, je suis tombé sur cette fameuse rom qui m'a l'air sympathique.
Cependant, vu que ça fait un petit moment que je n'ai pas modifié mon téléphone, j'ai quelques questions:
Actuellement, mon bootloader est verrouillé et je ne l'ai jamais déverrouillé (mais normalement je peux).
J'ai jeté un coup d’œil au tuto pour l'unlock, en le déverrouillant, je perdrai toutes mes données ? y compris le CWM ?
En parlant de CWM, j'en ai un, il s'agit de la version 5.5.0.4, si ce CWM n'est pas supprimé après l'unlock du bootloader, je dois le mettre à jour ou ça n'a pas d'importance ?
Si j'ai bien compris, le déverrouillage du bootloader permet de mettre un kernel custom or, dans cette rom, je ne vois pas l'étape où on doit l'installer. Ça se fait tout seul lorsqu'on flash le zip ? Autrement quel kernel faut-il mettre ? Comment faut-il faire ? Ai-je loupé quelque chose à ce niveau-là ?
Voilà voilà, je paraît sûrement un peu parano, mais je préfère tout d'abords me renseigner, bien comprendre ce que je fais afin de ne pas me retrouver avec un téléphone brické !
Merci d'avance pour vos réponses !
