aminosmas Posté(e) 8 avril 2014 Share Posté(e) 8 avril 2014 voila mon code android : class envoi_doc_entete extends AsyncTask<String, String, String> { protected String doInBackground(String... args) { doc_dao = new Document_entete_DAO(context); JSONObject object = new JSONObject(); List<NameValuePair> params = new ArrayList<NameValuePair>(); for(Document_entete doc : doc_dao.selectionner_Document_entete() ){ params.add(new BasicNameValuePair("ID_DocVente",doc.getiD_DocVente())); params.add(new BasicNameValuePair("Souche", doc.getSouche())); params.add(new BasicNameValuePair("ID_client", doc.getiD_client())); params.add(new BasicNameValuePair("Date", doc.getDate())); params.add(new BasicNameValuePair("Type_DocVente", Integer.toString(doc.getType_DocVente()))); params.add(new BasicNameValuePair("ID_Agent_commercial", doc.getiD_agent_commercial())); params.add(new BasicNameValuePair("Date_livraison",doc.getDate_livraison() )); params.add(new BasicNameValuePair("iD_depot", doc.getID_Depot())); } JSONObject json = jParser.makeHttpRequest(url_envoi_doc_entete, "POST", params); // verifier les données dans params Log.d("Create Response", params.toString()); try { int success = json.getInt(TAG_SUCCESS); if (success == 1) { Log.d("Create Response", "enregistrement OK"); } else { Log.d("Create Response", "enregistrement echoué ! "); } } catch (JSONException e) { e.printStackTrace(); } return null; } } code "JSONParser ": public class JSONParser { static InputStream is = null; static JSONObject jObj = null; static String json = ""; // constructor public JSONParser() { } // function get json from url // by making HTTP POST or GET mehtod public JSONObject makeHttpRequest(String url, String method, List<NameValuePair> params) { // Making HTTP request try { // check for request method if(method == "POST"){ // request method is POST // defaultHttpClient DefaultHttpClient httpClient = new DefaultHttpClient(); HttpPost httpPost = new HttpPost(url); httpPost.setEntity(new UrlEncodedFormEntity(params)); HttpResponse httpResponse = httpClient.execute(httpPost); HttpEntity httpEntity = httpResponse.getEntity(); is = httpEntity.getContent(); }else if(method == "GET"){ // request method is GET DefaultHttpClient httpClient = new DefaultHttpClient(); String paramString = URLEncodedUtils.format(params, "utf-8"); url += "?" + paramString; HttpGet httpGet = new HttpGet(url); HttpResponse httpResponse = httpClient.execute(httpGet); HttpEntity httpEntity = httpResponse.getEntity(); is = httpEntity.getContent(); } } catch (UnsupportedEncodingException e) { e.printStackTrace(); } catch (ClientProtocolException e) { e.printStackTrace(); } catch (IOException e) { e.printStackTrace(); } try { BufferedReader reader = new BufferedReader(new InputStreamReader( is, "iso-8859-1"), 8); StringBuilder sb = new StringBuilder(); String line = null; while ((line = reader.readLine()) != null) { sb.append(line + "\n"); } is.close(); json = sb.toString(); } catch (Exception e) { Log.e("Buffer Error", "Error converting result " + e.toString()); } // try parse the string to a JSON object try { jObj = new JSONObject(json); } catch (JSONException e) { Log.e("JSON Parser", "Error parsing data " + e.toString()); } // return JSON String return jObj; } } Mon code PHP : <?php $response = array(); if (isset($_POST['ID_DocVente']) && isset($_POST['Souche']) && isset($_POST['ID_client'])&& isset($_POST['Date'])&& isset($_POST['Type_DocVente'])&& isset($_POST['ID_Agent_commercial'])&& isset($_POST['Date_livraison'])&& isset($_POST['iD_depot'])) { $ID_DocVente = $_POST['ID_DocVente']; $Souche = $_POST['Souche']; $ID_client = $_POST['ID_client']; $Date = $_POST['Date']; $Type_DocVente = $_POST['Type_DocVente']; $ID_Agent_commercial = $_POST['ID_Agent_commercial']; $Date_livraison = $_POST['Date_livraison']; $iD_depot = $_POST['iD_depot']; mysql_connect("localhost","root","mysql"); mysql_select_db("mediasoftadistance"); // inserer une ligne $result = mysql_query("INSERT INTO Doc_entete(ID_DocVente, Souche, Date,ID_client,Type_DocVente,ID_Agent_commercial,Date_livraison,iD_depot) VALUES('$ID_DocVente', '$Souche', '$Date','$ID_client','$Type_DocVente','$ID_Agent_commercial','$Date_livraison','$iD_depot')"); // verifier l'insertion if ($result) { // succée $response["success"] = 1; $response["message"] = "document successfully created."; echo json_encode($response); } else { // echoué $response["success"] = 0; $response["message"] = "Oops! An error occurred."; echo json_encode($response); } } else { $response["success"] = 0; $response["message"] = "Required field(s) is missing"; echo json_encode($response); } ?> lorsque j’exécute mon application le script PHP insère la dernière ligne (la dernière document) . aidez moi svp ! aucune réponse :/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chpil Posté(e) 9 avril 2014 Share Posté(e) 9 avril 2014 Bonjour, Merci - d'être un peu plus précis dans ta question/explication de ce que tu essaies de faire (erreurs rencontrés ? traces de logs ? ...) plutôt que de presque se contenter d'un simple "aidez-moi" ... - d'utiliser les balises [ code ] dans ton post pour délimiter tes extraits de code, pour une meilleure lisibilité du post Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
