raphoudu57 Posté(e) 17 mai 2014 Share Posté(e) 17 mai 2014 (modifié) Bonjour tout le monde, je vous présente la rom que j'ai actuellement sur mon samsung Galaxy S5. C'est une rom Fluide, personnalisable , autonomie au top, performance nickel. Je vous laisse la découvrir... Donnez moi vos avis! Caractéristiques Lien de téléchargements Installation CARACTERISTIQUES ( 16/05/14 ) Rom v3 ( XXU1ANE2 Base ) Version: Android 4.4.2 Changelist:1539356 Product Code: BTU PDA: G900FXXU1ANE2 CSC: G900FOXA1ANE2- Added kids mode installer in setting - Added torchlight function in setting/display- Added pagebuddy function in setting/display- Icreased up to 12 app max in toolbox- Included in aroma the choice for Sfinder and Quickpanel button*****All mods and tweaks from previous versions updated to latest base***** ( 03/05/14 ) Rom v2 ( XXU1ANCF Base ) 1. Updated to G900FXXU1ANCF Base Changelist: 1186806Build date: Mon, 31 Mar 2014 10:55:18 +0000 - 2. Added the Amazing OG Battery Mod with the ability to choose over 85 beautiful battery iconson the fly without needing to reboot or restart your SystemUI (CREDITS: Osama Ghareeb) - 3. Enabled Call Recording - 4. “Abused” the SecMms.apk resulting in the following mods (CREDITS: jovy23 for prob the BEST GUIDE on XDA). No SMS to MMS conversion for messages. No SMS to MMS conversion for emojis. Enabled Group Messaging. Show sent (real) time instead of time received. Enabled Save/Restore function of your Messages to your SD Card. Enabled split view mode on landscape screen. Enabled the Screen on/off toggle. Enabled Folder View Mode. Enabled the ability to send a message to more than 1000 recipients at the same time. Increased the SMS hour limit to 1000. Increased the Max MMS size to 2048000 bytes. Increased the MMS Image size to 4096x2048 [8.4MP]-5. Added More Options In Aroma- Keyboards:a.Stock b.Echoe- SystemUI:a. Stock, Stock with OG, SystemUI with OG and Quick Panelb. Choose Lock Screen and/or Home Icon on your status bar if you wantc. Choose from 10 Amazing Curtain Backgrounds- Frameworka. Stockb. Transparent-6. Implemented by default up to 7 apps in toolbox-7. Every mod, app, tweak and Aroma Option from v1 still apply!! LIENS DE TELECHARGEMENTS Lien pour trouver les roms : http://echoerom.com/galaxy-s5-g900f/ Lien pour le modem XXUANE2 https://mega.co.nz/#!dIdjjDIY!8G-jJQr9Ycf-R15DbJjk611Kfk_mTgOy6FsSOAxZck8 Lien pour les recovery http://goo.im/devs/philz_touch/CWM_Advanced_Edition/klte http://forum.xda-developers.com/showthread.php?t=2753661 :excl: :excl: Pour certains recovery , il faut prendre odin 3.04 ou 3.07. Si vous passez par Odin. ( fichier tar à mettre dans Pda ) Lien du Super Wipe Ce script permet de nettoyer le téléphone de l'intérieur. :excl: :excl: Attention :excl: :excl: http://forum.xda-developers.com/showthread.php?t=2742887 Lien des roms officielles https://forum.frandroid.com/topic/191439-roms-officielles-samsung-galaxy-s5-sm-g900f/#entry3019749 INSTALLATION :excl: :excl: Votre téléphone doit etre Rooté ! Je ne suis pas Responsable si vous avez un soucis ! :excl: :excl: Avoir un Recovery fonctionnel Eteindre votre téléphone et démarrez sur le recovery ( Power + Home + Volume Haut ) Pour ma part, j'utilise le script super wipe avant Factory reset / Wipe cache / dalwik cache Install zip / Flash Rom v3 ( Aroma ) Reboot system Profitez ! Modifié 17 mai 2014 par Raphouille! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
