[Kernels Preview] Kernel Faux123
/!\ Pour les quelques Personnes qui tournent sur la Preview de Google (Android L) /!\
Kernel Faux dispo pour la version Preview (Android L)
Lien de téléchargement:
- http://faux.romhost.me/hammerhead/l/
Par contre à utilisé cette version ci "hammerhead-faux123-lpv-xxx.zip" l'autre version j'ai eu le droit à de beaux bootloops, à voir hasard ou pas...
Installation:
- Reboot recovery (CMW, TWRP)
- Direction répertoire ou se situ le kernel télécharger
- Install du kernel
- Wipe cache
- Reboot
Pour le Multirom
- Paramètres avancé
- Multirom
- Liste rom
- Trouver votre rom dans la liste
- Install Zip
- Wipe cache
- Reboot.
Changelog:
u - ultimate CPU up to 2.8GHz (turbo boosted!)
- release xxx (07/03/2014)
* intelliplug - fix minor suspend/resume bug
* updated to L preview baseline ;)
- release 019 (06/28/2014)
* re-introduce intelliplug 3.7 with:
! built-in profiles
! auto thread capacity calculations
! more intelligent algorithms for smoothness and battery life
! completely cross platform
! automatic dual core detection
- release 018 (06/04/2014)
* kitkat mr2 release (aka 4.4.3)
- release 017 (05/25/2014)
* fix CVE-2014-0196
* intelliplug 2.6
* add intelliplug screen off control
* add intelliplug touchboost control
* add intelliplug wakeup kick
* fixed gamma issues with LCD color control
* updated powersuspend driver to 1.3
- release 016 (04/04/2014)
* oom updated to linux 3.14+
* lowmemorykiller optimization
- Release 015 (04/01/2014)
* clean up intelli_plug
* made touch boost generic for intelliactive
* core sched optimization
* oom updated to linux 3.12+
* intelli-thermal reduce sampling overhead
* kswapd patch from mainline
* huge improvement 47.40% of core kernel scheduler efficiency!
- Release 014 (03/26/2014)
* fixed reboot issues
* add LG G2 LCD calibration
* add KGSL GPU fixes
* add official f2fs kernel support
- Release 013 (03/25/2014)
* tuned kernel page_alloc for better multitasking
* tuned LMK for better multitasking
* CAF bus and misc patches (bug fix)
* Compiled with Linaro 4.8.3 toolchain
* kernel random gen driver updated to Linux 3.14+
- Release 012 (03/13/2014)
* mainline is NO longer necessary with new built-in snake charmer
* lower GPU voltage range
* lower CPU retention volage
* cpufreq limit (aka snake charmer) is now built-in to kernel
* intelli-thermal use its own workqueue to relieve the shared global queue
* intelli_plug 2.2: better touch boost, uses its own high priority queue
* turbo boost: fix a logic error
* ksm optimzation to reduce daemon scan overhead, this with fauxclock's
intelli-ksm will improve memory performance without heavy battery penalty
- Release 011 (03/05/2014)
* add always on LED
* reduce min brightness
* add turbo boost for ultimate (up to 2.8 GHz)
* add f2fs drivers for future F2FS support /data partition on some ROMs
- Release 010 (02/15/2014)
* fix race condition with intelliactive
* add new gamma control code from myfluxi
* fix kernel NEON warning during early init
- Release 009 (02/11/2014)
* add brand new intelliactive governor!
- Release 008 (01/15/2014)
* add kexec support
* add kernel NEON support
* remove unaligned access
* add crypto lib optimization
* add ext4 fixes
* add more zswap fixes
* update to latest gamma driver from myfluxi
- Release 007 (01/04/2014)
* futex backport from Linux 3.13+
* increased fastcharge charging rate
- Release 006 (01/03/2014)
* sync'ed gamma interface to latest driver
* USB mtp/gadget optimizations
* zswap/frontswap/vnswap added
* core scheduler optimizaitons
* cortex-a15 flags added for krait cpus
* ARM LoUIS cache API added
* fastcharge driver added (working)
* zswap use lz4
- Release 005 (12/07/2013)
* updated to latest kitkat mr1 release
* reverted cpu touch boost to fix mpdecision issues
- Release 004 (12/04/2013)
* add intelldemand 5.0
* add fauxsound driver 3.2
* add async fsync
* add Qualcomm's cpu/gpu touch boost
* add myfluxi's final Gamma control driver
* add s2s controls
- Release 003 (11/24/2013)
* fixed FauxSound Drivers (fix reset issues)
* add sweep2wake, dt2wake (showp1984)
* add vertical sweep2wake
* fix simple GPU governor bug
* added latest Google WiFi driver updates
* intelliplug 2.0 performance tune up
- Release 002 (11/13/2013)
* intelliplug 2.0 (touch boost)
* exFAT support (for OTG)
* dynamic fsync is back
* snake charmer is back
* patches to reduce kernel latencies for network, fs
* selinux update
- Release 001 (11/04/2013)
* added new power management mode "PowerSuspend"
* intelliplug 1.9 (added dynamic loading boost)
* intellidemand optimization for 8974 SOC
* VFAT, MM tweaks
* over 350+ patches!
* added AIO update
* added core scheduler update
* added epoll updates frol Linux 3.12+
* slab/slub forward ported to Linux 3.8+
* fixed CIFS issues
* backported 3.12+ kernel scheduler features
* fixed old cpufreq bug
* added LZ4 compression (faster than LZO)
* compiled with GCC 4.7
* added intelli-thermal kernel thermal driver
* added various minor kernel bug fixes from CAF/kernel.org
* more accurate load calculations (better battery/performance)
* added simple GPU governor for better GPU controls! (battery/performance)
* added mutex optimization (better multi-tasking)
* boost voltage slightly (for better stability)
* scheduler optimization (smoother multi-tasking)
* SELinux optimization (faster SELinux!)
* enbled kernel AIO optimization from Linux 3.8+
* enabled touch boost for intellidemand governor
* enabled XZ compression (reduce kernel size)
* ROW I/O scheduler added
* kernel freezer updated (better power savings)
* "random" number generator updated to Linux 3.8+
* Intelli_plug (complete replacement of mpdecision)
* intellidemand (a better ondemand governor)
* UV control
* BFQ/SIO/FIOPS I/O schedulers added
* ARM unaligned access enabled
* updated LZO algorithms (used by many including crypto, zram/zcache etc)
* updated libraries with optimized kernel functions
Modifié par Kitkatdroid
Hello ! Merci pour le post !
Ca serait possible de faire un retour sur l'autonomie et la fluidité avec ce kernel ?
Je suis en train de tester la dernière version du Code Blue, je pense tester celle ci après quelques jours ;)
Je suis en train de tester la dernière version disponible du 15 Juillet.
Je ferais un retour demain après une journée complète d'utilisation.
Nexus 5 sous Android L
Bonne Nuit.
PS :
Déjà pas besoin d'avoir le téléphone en Anglais pour avoir une charge correct.
Modifié par Taken.94
Bon moi je passe pour mon retour!
1ere chose que je confirme le bug de la charge a disparu et qui est un bon point!
Niveau fluidité ça reste très correct et qui en même temps le contraire m'aurait étonné lol et pour finir niveau autonomie à vous d'en juger ;)
Allumé ce matin, environ 5 heures de screen actif
Avec ça deux envoi de mails, quelques SMS, un appel en soirée, bien entendu tapatalk et pour finir flipboard.
Toutes ces applications ouvertes et non fermés par la suite (toutes en arrière plan multitâche) et avec une luminosité de 50%.
Sent with Miui on my Nexus 5
J ai essayer la version du 16 car celle du 15 j avais des fermetures des processus. Le bug du chargement ne c est pas representer et plus de fermeture de processus. Autonomie par contre impecable deja la rom nativement avais une autonomie plus que correct par rapport a la version 4.4.4
KitKatdroid, tu as laissé les options du kernel d'origine ou t'as UC et UV un peu ?
Pour le bug du chargement c'est le changement de kernel qui a résolu le problème ? O_o
Sinon en parallèle, le Kernel Blue est aussi plutôt pas mal, 55% après une journée et plus de 2h de screen,30-40 mins d'appel avec en grande majorité du surf, des sms, FB (et messenger)...
Là ce matin, 35mins de screen (dont 20 mins de youtube) et 5% de perdu.
J'ai oublié de précisé, je n'ai rien toucher au fréquences et au tensions lors de mon essais ! Et pour le bug ce kernel le corrige bien et pour toute les langues ;-)
Edit: Ah j'oubliais aussi gros avantage la modifications des couleurs de l'écran comme le screen du premier post avec Trisker
Envoyé de mon Nexus 5 en utilisant Tapatalk
Le lien est fonctionnel du premier post je viens de vérifier !
Pour ce qui est xda faut voir si il y a un post pour je suis tombé sur ce kernel par le biais d'une autre recherche!
Je recherchais une appli permettant de corriger le soucis de micro lors de l'enregistrement vidéo (saturation du son) et j'avais trouvé Fauxsound.
Du même coups avec les liens qui sont sur l'application je suis tombé sur ce kernel :-)
Sent from my Nexus 5 using Tapatalk
  • 4 weeks later...
Je suis en stock 4.4.4 avec le kernel 020u , pas mal niveau autonomie , je passe la journée les doigts dans le nez comme ont dit , j'ai perdu 2% cette nuit c'est tout , j'ai utiliser les réglages que paul préconise : https://plus.google.com/app/basic/stream/z13juzchlkvqenjtt225edernyneht15b04?cbp=cq1kjx86jrcc&sview=27&cid=5&soc-app=115&soc-platform=1&spath=%2Fapp%2Fbasic%2F%2BPaulReioux%2Fposts&sparm=cbp%3D19yrphyz23mf%26sview%3D25%26cid%3D5%26soc-app%3D115%26soc-platform%3D1
Modifié par ovme
