liste des revendeurs du one plus one
Teddy Du 84
salut je fait ce topic pour parler des revendeurs du one plus one
16 go blanc
dwi http://www.ebay.fr/itm/NEUF-5-5-034-ONEPLUS-ONE-4G-LTE-3GB-RAM-16GB-WHITE-SMARTPHONE-TELEPHONES-MOBILES-/331263728932?&_trksid=p2056016.l4276
mixeshop 275e http://www.mixeshop.com/oneplus-one-fdd-lte-4g-snapdragon-801-25ghz-quad-core-55-inch-gorilla-glass-fhd-screen-android-44-3gb-ram-16gb-rom-nfc-3100mah-battery-smartphone_p4588.html
lenteen 294e envoier depus hk http://www.lenteen.fr/smartphoneandroid/oneplus-one-telopone.html
lenteen 316e envoier de france http://www.lenteen.fr/smartphoneandroid/oneplus-one-hw-telopone-16g.html
aliexpress 279e http://www.aliexpress.com/item/OnePlus-One-LTE-Phone-in-stock-Snapdragon-801-Quad-core-2-5G-3GB-Ram-cyanogenmod-CM11S/1903073505.html?cn=null&PID=6149969&tp1=1cpxnyjmnfhxx&tracelog=null&src=ale&URL=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2FOnePlus-One-LTE-Phone-in-stock-Snapdragon-801-Quad-core-2-5G-3GB-Ram-cyanogenmod-CM11S%2F1903073505.html&cv=11032041&af=cj_6149969&vd=30
coolicool 265e http://fr.coolicool.com/oneplus-one-qualcomm-snapdragon-801-25ghz-quad-core-android-44-55-fhd-gorilla-glass-3-jdi-4g-lte-g-191983?gclid=CKHrxMH33b8CFeTItAodpBUAhQ
oppomart 293e http://www.oppomart.com/oneplus-one.html
64go noir
dwi http://www.ebay.fr/itm/NEUF-5-5-034-ONEPLUS-ONE-4G-LTE-3GB-RAM-64GB-BLACK-SMARTPHONE-TELEPHONES-MOBILES-/321464730676?&_trksid=p2056016.l4276
mixeshop 331e http://www.mixeshop.com/oneplus-one-fdd-lte-4g-snapdragon-801-25ghz-quad-core-55-inch-gorilla-glass-fhd-screen-android-44-3gb-ram-64gb-rom-nfc-3100mah-battery-smartphone_p4589.html
lenteen 346e (dispo en blanc)http://www.lenteen.fr/smartphoneandroid/oneplus-one-telopone-64g.html
aliexpress http://www.aliexpress.com/item/OnePlus-One-LTE-Phone-in-stock-Snapdragon-801-Quad-core-2-5G-3GB-Ram-cyanogenmod-CM11S/1903073505.html?cn=null&PID=6149969&tp1=1cpxnyjmnfhxx&tracelog=null&src=ale&URL=http%3A%2F%2Fwww.aliexpress.com%2Fitem%2FOnePlus-One-LTE-Phone-in-stock-Snapdragon-801-Quad-core-2-5G-3GB-Ram-cyanogenmod-CM11S%2F1903073505.html&cv=11032041&af=cj_6149969&vd=30
oppomart 356e http://www.oppomart.com/oneplus-one.html
Modifié par Teddy Du 84
16 go blanc
mixeshop 331e http://www.mixeshop.com/oneplus-one-fdd-lte-4g-snapdragon-801-25ghz-quad-core-55-inch-gorilla-glass-fhd-screen-android-44-3gb-ram-16gb-rom-nfc-3100mah-battery-smartphone_p4588.html
Le 16Go est a 275.71 Euro sur mixeshop et non 331^^
Modifié par ojirami
Salut , moi je vous propose Aliexpress , c'est un service que j'utilise pour absolument TOUT , prix très attractif , possibilité de parler avec le vendeur et de négocier etc...
Personnellement j'ai pris mon oneplus One chez ce vendeur :
Prix raisonnable , livraison DHL (envoyé la journée apres avoir passer ma commande) + coque offerte donc n'hésitez pas !
Modifié par mrsachou75
Suis tombé là-dessus :
Je ne connais pas du tout ce site niveau fiabilité sinon le prix est plus que correct pour le 16 Gb
  • Like 3
Salut. Attention à l'âchat du One version chinoise car en cas de probléme c'est très compliqué pour la prise en charge. Il faut patienter et le prendre sur le site officiel (version europêenne). Les invits commencent à bien circuler j'ai eu la mienne (et commandé dans la foulée) alors que je ne suis inscrit sur le forum officiel que depuis 5 jours: il faut simplement être très actifs sur le forum francophone. Bon courage à tous.
Modifié par FASAB
Si jamais  quelqu'un a peur des sites chinois ou est pressé  ; je vends un one plus one 16gb blanc reçu il y a une semaine , commander chez mixeshop ( gros bordel avec fedex pour recevoir le phone  , tres long mais a force de coups de telephones ça la fait .... (MP si intéréssé ).
Modifié par ojirami
Effectivement très bon prix. Merci pour le lien Pap0ose :)
Quelqu'un a testé ?
[EDIT] aliexpress a l'air pas mal non plus : bon prix, toutes les versions proposées, vendeur très bien noté, c'est presque trop beau...
Modifié par JuanMi
Je confirme pour Aliexpress , c'est trop beau :P j'ai commander le mien recu en 3j avec DHL :)
J'ai trouvé un site qui parle de Aliexpress (en bien). Mais par contre ils déconseillent DHL pour le transport, car le colis passe obligatoirement par la douane.
Par curiosité, combien as-tu payé de frais de douane ?
Il passe obligatoirement par la douane mais tu ne paye pas forcement , Sur ce coup la j'ai du payer 30€ de frais de douane , mais j'avais négocier avec le vendeur pour ne pas payer les frais DHL qui était de 30€ donc voila :)
Bien joué :)
Merci pour les renseignements.
L'avantage de mixeshop  c'est qu'ils font passer le colis pour des pieces de téléphones genre batteries etc , donc pas de douane a payer , mais par contre niveau suivit du colis je leur mets 5/20 :/
Modifié par ojirami
