Invité Posté(e) 18 août 2014 Share Posté(e) 18 août 2014 (modifié) Citation Infos sur la version Version OS de la Rom : KitKat 4.4.XROM Kernel : Linux 3.4.XBasée sur : HTC Sense 6.0Statut : Stable Source : XDA Citation CARACTÉRISTIQUES Basé sur la ROM 1.54.401.5 du HTC One M8, Android 4.4.2 sense 6 Kernel Stock HTC avec les droits d'écriture système Installateur AROMA totalement thèmé avec choix d'installation ROM complète ou Mise a jour Citation MODS Advanced Power Menu Added extended homescreen menu 3-in1 app drawer mod (choose from 3x4, 4x5 and 5x6 app drawer) lyapota's extended horizontal quick setting mod 1% increment battery mod - thanks to @dmonium for the trans battery images Increased maximum number of HTC Quick Settings tiles from 12 to 23 - thanks to @Digitalkarma for his helpful Sense 5.5 guide, which I used as a base for our Sense 6 version CRT screen off animation Native AppOps in Settings menu Xposed installer Long-press back to kill app Extended options in Message app Set max preview lines in Messages to 5 Increased max mms size Tweaked NFC to work while screen is off Completely removed HTC Quick Tips Removed all HTC logging APKs Re-enabled hardware info in Settings menu Unlocked Developer Settings by default Tweaked system wide animations, with extra system animation values (found in developer options) Plus others... Citation OPTIMISATIONS flar2's Write Protection MOD to allow S-ON users fully writeable /system partition 0% compression on all apks for improved performance Removed debugging info from all apks and jars Rooted, with SuperSU Init.d support Hardware accelerated multiple HTC Apps Cleaned the HTC important processes list and added HTC Launcher (Prism) for increased performance Disabled scrolling cache Disabled signature check /System & /Data zipalign at every boot Script to remove tombstones + unneeded files at every boot /Data/app cleanup on each flash Ext4 tweaks for better performance Cleaned RAM disk Option to odex/deodex when flashing Cleaned and tweaked build.prop for better performance Citation TWEAKS Statusbar Clock & date options AM/PM style Clock colour Date colour Battery options Battery text MIUI battery bar Hide statusbar icons Data traffic monitor CPU usage HEQS text colour Interface tweaks Landscape Prism AOSP lockscreen Carrier label text colour Menu button Enable 180 degree rotation Recent apps style PIE App tweaks Screen on with new messages SMS to MMS conversion Disable noise suppression Phone info Remove volume warning Buttons & Display Long-press back to kill app Volume key configuration Recent apps button configuration Navbar toggle CRT anim Autobrightness options Softkey brightness Tools Zipalign Wipe cache/dalvik Fix permissions Boot options Citation AROMA OPTIONS International / AT&T / Sprint Full wipe / Upgrade Stock / Inverted themes Odex / Deodex Statusbar battery options With % Without % No battery icon Clock options Normal Center clock No clock 4x4 / 4x5 Homescreen layout Widget transparency options Disable Exchange mail security Xposed framework User choice HTC / Google / 3rd party app removal User choice of additional language keyboards Odex / deodex Citation Renovate: Sixth Sense 2.3.0 Fixes Fixed default media key tweak value Fixed mismatching Sprint ID in SystemUI (blame HTC) Fixed HEQS from hiding after each reboot Fixed issues with HEQS for ATT/TMO users Fixed Aroma issues with clock/battery options Fixed Native tether for Sprint users Fixed issues with DotView Fixed incorrect names for Gallery themes Fixed issue restoring backups from Google account in Setup New features Added full support for Sprint Improved installation process Improved syscntl values Removed the widget limit on lockscreen Removed HTC minor quick settings, can now toggle between none or scrollable heqs Improved the layout of the clock/date in the statusbar pulldown Removed default cities in world clock app Added default bookmarks to browser Added Tweaks app back to Settings Restyled stock HTC themes to give a more unified look Added a new 5th theme to the theme picker Added all new inverted HTC themes New bootanimation - thanks to @pneuma1985 Modified SystemUI so Sprint users get their native spinning data icons but now hide when wifi is connected Readded myHUB Readded widget transparency options to aroma Readded the 4x5 homescreen option Added the option to enable/disable large sms messages being sent as MMS Added the option to choose the color of the carrier label on lock screen Readded option to show/hide CPU usage Added a new layout for the CPU usage tweak Added the option to change the color of the heqs labels Added the option to enable/disable the safe volume warning pop up Added the option to enable/disable 180 degree rotation Readded the option to change the am/pm style of the clock Readded the option to change the color of the clock Added the option to change the color of the date Readded PIE controls Other cleanups and fixes Updated all apps Citation Dernière Version: 2.3.0 - 18/05/2014 Renovate Sixth Sense 2.3.0 MD5 SUM *de7f331b380b8d74c341e60d76ba5bcf* MD5 SU Citation Télécharger la ROM depuis le lien au dessus Copier la ROM dans la mémoire du téléphone Redémarrer en mode Recovery Sélectionner "Install from .zip" et "Choose the ROM.zip" Suivre les instructions, le full wipe est recommandé si vous venez d'une autre ROM. Laisser la ROM démarrer et profiter! Modifié 9 octobre 2014 par HTC_Addict Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
