Leufeudedieu Posté(e) 16 août 2010 Share Posté(e) 16 août 2010 (modifié) : Cool Installation: 1)Télécharge le firmware et de-zippe le a la racine de la SD après l'avoir formaté en Fat32 2)Démarre la M001,le flash se lance 3)Une fois démarré,aller au menu calibrage dans paramètres et calibrer son écran 4)Effacez le dossier script a la racine de la SD avec l'explorateur ou sur support SD avec le PC avant de re-demarrer (sinon re-flash) Change log : v2.0.4 : Based on the latest Android_2.0_M001_0915 Kernel by projectgus Swap fixed Compcache fixed Oc fixed at 466 (you can overclock at 533Mhz with SetCpu) Root Automatic Google search transparent (Helix) Helix Launcher / ADW Launcher Google apps (Market works) Superuser Better terminal File Browser Cache Cleaner Spare Parts Adhoc Other little details I forgot ...... [ROM]EKEN Relax v2.0.4 DARK ÉDITION : http://www.4shared.com/file/bjU_v0j_/lefeudedieu-Relax_v204-Dark-sc.html Pack applications : Relax-applications.zip Options : For the underclock/overclock by setcpu : 1) create a text file "setcpu.txt" with the following values and copy it to the root of the SD:66001,99001,133001,166002,200002,233002,250002,266002,300002,333002,333003,366002, 400002,433002,466002,500003,533003 2) Download Setcpu (thank to coolbho3000): SetCPU for Root Users [2.0.3] It's over nine thousand 09/03/2010 - xda-developers 3) Open setcpu and choose the last option down by "txt", always allow root To change the sensor in reverse for games (merci a pm2lp) : 1. Open better terminal. 2. Type: setenv gsensor_axis 0,1,1,-1,2,1 3. Reboot 4. Set G-sensor game mode on To read SPB-tv: decompress the RAR file "SPBTV-lib" and dragged in the window 7-zip file "libmediaplayerservice.so" in: android_fs.tar / system / libSPBTV-lib.zip - 4shared.com - online file sharing and storage - download For pay me a little French Ricard lol mikelkeal31@gmail.com I can not be held responsible in case of damage to your EKEN. Modifié 30 mars 2011 par lefeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 16 août 2010 Auteur Share Posté(e) 16 août 2010 (modifié) Anciennes versions : [ROM]EKEN Relax v1.9.3 : [ROM]EKEN Relax v1.9.2 : [ROM]EKEN Relax v1.9.1 : Modifié 13 décembre 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 16 août 2010 Auteur Share Posté(e) 16 août 2010 (modifié) reservé :cool: Modifié 22 août 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 19 août 2010 Share Posté(e) 19 août 2010 dommage ca a marcher m003 implécable juste un problème écran Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 20 août 2010 Auteur Share Posté(e) 20 août 2010 (modifié) dommage ca a marcher m003 implécable juste un problème écran Salut dv33, logiquement marche très bien avec le M003. Pour l'écran,dés le 1er boot il te faut le calibrer,il y a un petit décalage,il suffit de taper juste au dessus des icônes,ca marche,le temps d'accéder au menu pour calibrer l'écran et après chez moi tout est nikel :cool: Est-ce de cela dont tu parle concernant ton souci d'écran ? A plus Modifié 20 août 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 20 août 2010 Share Posté(e) 20 août 2010 (modifié) non quand tu installe sur la m003 ta le haut de l'écran en bat une coupure et le rest de l'écran attend je vais mettre une photo Modifié 20 août 2010 par dv33 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 20 août 2010 Auteur Share Posté(e) 20 août 2010 @dv33 OK merci pour les screens,je pense avoir trouvé,rien de grave je t'explique : Dans le dossier script,tu as un fichier nommé : update.sh Tu l'ouvre avec le bloc note et en haut tu remplace ceci : height=22 pointX=30 pointY=100 par cela : height=20 pointX=30 pointY=50 Et tu enregistre et re-flash,tiens moi au courant que je puisse le mettre en page 1 pour les M003. Merci a toi ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 20 août 2010 Share Posté(e) 20 août 2010 (modifié) je fais ca et je te dit ;) Modifié 20 août 2010 par dv33 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 20 août 2010 Share Posté(e) 20 août 2010 a première vue le problème vient du fichier update car dans la rom m003 c'est height=20 pointX=30 pointY=50 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 20 août 2010 Auteur Share Posté(e) 20 août 2010 a première vue le problème vient du fichier update car dans la rom m003 c'est height=20 pointX=30 pointY=50 re, peu tu stp me confirmer que cela fonctionne correctement car,je ne peu tester sans M003 :( merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 20 août 2010 Share Posté(e) 20 août 2010 en modifiant le update ca marche pas bloquer au flash préparation update mais pendent le flash écran et quand même séparer en 2 j'ai directement mis le fichier update de la rom m003 la ca marche le flash mais écran et quand même en 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 23 août 2010 Auteur Share Posté(e) 23 août 2010 (modifié) Salut a tous, bon une évolution de la Relax,Swap ok et ROM Rootée :cool: Ici Toulouse lol Modifié 29 août 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 24 août 2010 Auteur Share Posté(e) 24 août 2010 (modifié) Un nouveau thème a venir :cool: avec mise a jour de la ROM issue du dernier SDK pour EKEN A plus ;) Modifié 1 septembre 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 27 août 2010 Auteur Share Posté(e) 27 août 2010 (modifié) MAJ Ajout : v1.9.3 Base 1.9.0-888 Dark thème by Me Root Swap ADW/Helix Launcher FreeMemoryRoot Modifié 27 août 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 28 août 2010 Share Posté(e) 28 août 2010 toujours que pour la m001? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 28 août 2010 Auteur Share Posté(e) 28 août 2010 (modifié) toujours que pour la m001? Salut dv33, promis ce W-end je te fait une M003,bon pour Lundi avec le mm caractéristiques que la Relax ;) Un p'ti apercu : - root (juste tape su) - Youtube mid-res - swap (via console) - Keychanges pour le Fullscreen apps * Power = Power * Volume up = back * Volume Down = Menu * Round Button = Home J'ai reçu mon APAD IROBOT "7" en Metal et que tu bonheur,une fois rootée et installé une ROM cookée (noyau ARCHOS 7) ca tourne grave et la qualité dépasse de loin la EKEN M001,seul Hic Android CupCake 1.5 Market bridé :( Modifié 28 août 2010 par Leufeudedieu Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 28 août 2010 Share Posté(e) 28 août 2010 ok merci ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 28 août 2010 Auteur Share Posté(e) 28 août 2010 P'ti message (dv33) MAJ 1.9.1 OFFICIELLE EKEN M00/1/2/3 ici : http://www.ekengroup.com/en/download/index.asp Demain retour complet sur la MAJ,puisque deja une nouveauté on peu lire les medias sur USB (hubbs ipod). Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 28 août 2010 Share Posté(e) 28 août 2010 (modifié) je peux pas télécharger ca m'envoie sur un lien chinois Modifié 28 août 2010 par dv33 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 28 août 2010 Auteur Share Posté(e) 28 août 2010 je peux pas télécharger ca m'envoie sur un lien chinois D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 28 août 2010 Auteur Share Posté(e) 28 août 2010 je peux pas télécharger ca m'envoie sur un lien chinois Oups,tous les autres liens fonctionnent M00/1/2 youtubes sauf le tien pas de bol :( Allez :cool: demain je m'occupe de cooker pour le M003 lol Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 28 août 2010 Share Posté(e) 28 août 2010 pas grave je me consol avec ma zt 180 c'est juste pour aidé que je garde la m003 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 29 août 2010 Share Posté(e) 29 août 2010 (modifié) j'ai réussi a réglé le problème d'écran en remplaçant le fichier scriptcmd mais le problème c'est que maintenant le flash plante a upgraded logo Modifié 29 août 2010 par dv33 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Leufeudedieu Posté(e) 29 août 2010 Auteur Share Posté(e) 29 août 2010 j'ai réussi a réglé le problème d'écran en remplaçant le fichier scriptcmd mais le problème c'est que maintenant le flash plante a upgraded logo dw33, ai trouvé ca : "My M003-1.91 Youtube playing "normal picture "and better quality than "low res." youtube Bon GP a tous ,still under testing so far" Flash ta M003 avec le firmware M001 c'a a l'air de marcher Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
dv33 Posté(e) 29 août 2010 Share Posté(e) 29 août 2010 (modifié) je vais testé sa ci non j'ai trouvez une rom m003 1.9.0 le truc c'est que avec ta rom j'ai jamais vue la tablette marcher aussi bien Modifié 29 août 2010 par dv33 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
