[ROM] SE7EN v3.8/EMUI 3.0/4.4.2/B602 BETA
ROM trouvé sur xda
Forword this is a development Rom and a beta rom!
When you flash this it was your'e decision!
when you bricked your phone or anything is not working right , you flashed youre device and not i !
So follow the step correctly and check that you did the steps right!
this Rom is working so far for me as a dayli , it has some small bugs but for me all is OK
THIS ALL WAS HARD WORK AN TRIAL AND ERROR SO IF YOU WANT TO INTEGRADE ANYTHING OF THIS IN YOURE ROM ASK BEFORE DOING !
Features
Stock-Kernel with init.d support by me
Build.prop Tweaks
ext4 tweaks
BusyBox
pre rooted
Antivirus activated
Autostartmanager activated
Permissions-manager activated
Fixed Small View-Cover
Changed icon Size to from 180 to 168 (desktop look's more clear (l07/l05 standard))
FULL-ROOT 100%
removed set_immutable.list
external SdCard write fix
debloated (Gapps/Customer Apps)
Build in Fly-On Mod Alpha 3
Apps
Lenovo Compass
SuperSU
Adobe Flashplayer
Adaway
Apollo
OTA Updater
Shafta123Apple Sauce 7.0 keyboard
Xposed (pre-enabled) XDA Page
Viper4Android (pre-enabled) XDA Page
Changelog
V3.8 19/12/2014
+ New Stock B602 Kernel with init.d support by me
+ added DSP Manager
+ added Apollo with modified Widget by me (EMUI 3.0 look)
(it works with all equalizer)
+ optimized sqlite
+ AirSharing Cast
+ Android L Keyboard (latest)
+ Selectable equalizer in settings
+ Modified Logo in about phone by me
+ New Bootanimation created by me
+ Call Recorder enabled thx to revery0
+ modified In Call UI thx to gregysk & Razziell
+ Enabled Ring unlock with modified Stock Theme by me
( you have to re enable stock theme and cancel to hold the magazine unlock)
+ re enabled OTA Updates
maybe more i have forget
Screens
V3.7 11/12/2014
Small Update
-Slimmed down the rom
-Removed Huawei Swype, and other apks that was duplicate in CUST
+ Changed icon Size to from 180 to 168 (desktop look's more clear (l07/l05 standard))
more to come...
After Update Wipe CACHE/DALVIK and when CWM ask for fixing ROOT select YES!!! (this will do the 100% Root)
(if any error is coming with su binary not installed from SuperSu flash the SuperSu CWM.zip)
How to install
Make sure you are on the B602 L10 Version!
For this Rom you must have an unlocked Bootloader!
If your'e Bootloader is locked, you must downgrade to EMUI 2.3
and than Roo/Unlock Booloader with Roogenius!LINK
Than Update back to B602!
Revert back to P7-L10 ROM for Se7en-Rom 3.4 Users ( L07/05 Base Rom see Post #2)
1. Flash Emui 3.0 CWM via Fastboot (fastboot flash recovery recovery.img)
2. Boot into CWM and install Seven-Rom ( i recommend to make a fullwipe before installing)
3. Wipe CACHE/DALVIK!
4. Reboot. When CWM ask for fixing Su select YES! (for 100% ROOT!)
Enjoy Se7en-Rom
BUGS/SOLUTUIONS
If you have no Motion Control reboot, when this not helped do nothing just wait for me it took 1 day and than
it was there!? In this time i had done nothing! But this is a Beta-Rom so Bugs are present.
Credits
XDA
Huawei
Oxalis
4pda.ru
Chainfire
Slaid480
surdu_petru
Shaftamle
Tim Scarborough
ROM-HUAWEI
zhuhang
Cyanogenmod
and all that i have forgot
Download
ROM http://forum.xda-developers.com/devdb/project/?id=6739#downloads
CWM and other Files
XDA:DevDB Information
Se7en-Rom V3, ROM for the Huawei Ascend P7
Contributors
natorus87
ROM OS Version: 4.4.x KitKat
ROM Kernel: Linux 3.0.x
ROM Firmware Required: B133-B138
Version Information
Status: Beta
Current Stable Version: -
Stable Release Date: 0000-00-00
Current Beta Version: V3.7
Beta Release Date: 2014-12-11
Created 2014-11-18
Modifié par Maxens63
Pour ma par cette version nécessite emotionUI 3.0 que je ne parviens pas a installé a cause de TWR qui fait planté la mise a jour via le téléphone, j'ai tenté de remettre le recorvery de base sans réussite puis CWM qui ne fonctionne pas lui aussi...
Si quelqu'un pouvais faire un backup de sa version en 3.0 via le recorvery ça serais cool de sa par de l'uploader ici, merci d'avance :)
  • 3 months later...
