[ROM] [5.0.0] [1.9] [i9300] BlissPop by Team Bliss [OFFICIAL]
Team Bliss Website
Bliss Roms now has a new website with several features.
Member sign-up, giveaways, weekly newsletter for members,
staff information, downloads and the option to open support tickets for issues
are just a few of the great features available on our website.
Huge thanks to [MENTION=5346868]pjgraber03[/MENTION] for developing and maintaining our website.
Team Bliss is a team consisting of developers and device maintainers that work on this project in our spare
time to be able to give Android users a custom rom packed with features that will make a lasting impression.
Team Bliss is pleased to present to you BlissPop Rom!
BlissPop is one of the most highly customizable roms that you can install on your mobile device,
and you will have a truly blissful experience.
BlissPop is CM12 based, with some features added in, and we will continue to update features as they become available.
A huge thanks to CyanogenMod for the source, and all the work and dedication their team puts in to keep us updated.
We will keep up to date with the latest CM code, and updates will be posted on a regular basis.
However, please do not ask for ETA's. We will update the links as soon as they become available.
We will not tolerate any rudeness or anyone being disrespectful in this thread.
We will do our best to answer your questions or concerns as soon as possible.
Personalization Options
CM12 Theme Manager (Early Development so there will be some bugs)
-Deep Darkness theme by [MENTION=5686358]_moelle[/MENTION] included
Status Bar
-Clock & Date Options
-Option to show seconds in time
-Battery Options (Portrait, Landscape, Circle, Text or Hidden)
-Battery Bar Options
-Mobile & Wifi Network IconsOptions
-Status Bar Header
-Notification & System Icon Options
-Traffic Monitor
-Brightness Control
-SuperUser Indicator
-Notification Count
-Weather
-Notification Ticker
-Carrier Label Options
Recents Options
-Clear All Button Tweaks
-Option to show Google search bar in recents Menu
-OmniSwitch (Option to replace recents menu with Omniswitch)
Notification Drawer
-Tile Options
-Quick Setting Options
-Quick & Smart Pulldown
-Brightness Slider Options
Lockscreen Options
-Disable Camera
-Disable Dialer
-Clock Widget Settings
Power Menu Options
-Power Off
-Reboot
-Screenshot (with delay option)
-Screen Record
-Profile Switcher
-Airplane Mode
-User Switcher
-Settings
-Device Lockdown
-Sound Panel
Buttons
-Power Button End Call Option
-Home Button Options
-Back Button Wake Up Option
-Menu Button Options
-Search Button Options
Pie Control
-Buttons Options
-Style & Dimension Options
-Trigger Options
-Visibility
Gesture Anywhere
-Location Options
-Trigger Regions
Animations
-Toast Animations
-Listview Animations
-System Animations
-Scrolling Cache
-Scrolling Modifiers
App Circle Bar
-Choose what apps you want to show on the App Circle Bar
-Trigger width, position and height
Device Control
-Control Kernel, CPU, GPU & Many Extra Settings
Bliss Download Section
-All current downloads for your convenience
AudioFX Equalizer
Display Options
-Wake Up on Charge
-Prevent Accidential Wake Up
-Double Tap to Sleep
-Density
-Reported Density
-Screen Recorder
-Color Calibration
Sound & Notification Options
-Media, Alarm & Ring Volume Options
-Increasing Ring Volume
-Call Vibration
-Interruption Options
-Notification Light Options
-Battery Light Options
-App Notification Options
-Notification Access
-Camera Shutter sound, Screenshot Sound, Safe Headset Volume
-Less Frequent Notifications
-Heads Up Notification with Snooze Timer & Time Out
-SuperSU - Huge thanks to [MENTION=631273]Chainfire[/MENTION]
Other Stuff Included
-User Profiles
-System Profiles
-Location Options
-Security Options
-Privacy Options
-Accounts & Sync
-Language & Input
-Backup & Reset
-Accessibility
-Printing
-Performance Control
-Developer Options
-Rom & Hardware Information
--Many other settings throughout the rom. Take some time to familiarize yourself with all the blissful options!
BlissPop Source
https://github.com/TeamBliss-LP
TeamBliss Devices Source
https://github.com/TeamBliss-Devices
We recommend using either PA GApps, which are available for download Here
OR
Banks GApps, which are available Here
A huge thanks to [MENTION=2777334]TKruzze[/MENTION] for maintaining PA GApps!
If you prefer another set of GApps, just make sure you use 5.0.
Samsung s3- i9300- BlissPop 5.0.2 V1.8
Team Bliss is not responsible in any way for anything that happens to your device in the process of flashing.
Please familiarize yourself with flashing and custom rom use before attempting to flash the rom.
Please make sure you download the correct version of BlissPop for your specific device. The links are labeled clearly.
-Make sure you are rooted.
-Make sure you have a custom recovery installed. (TWRP, CWM, Philz CWM)
-Download the latest Bliss Rom & the latest GApps package.
-Boot into recovery.
-Perform a FULL factory wipe and wipe/system and dalvik cache as a precaution
-Flash Bliss Rom
-Flash GAPPs package
-Reboot
-First boot may take up to 10 minutes
As you all know, Lollipop is new and there are going to be bugs.
Please bear with us while we work on getting things updated, and all errors fixed.
If you have a major bug to report that has not been reported already, and is not a known issue with CM,
please take the following steps to report it to us. It will save you time, as well as us.
-Bluetooth Streaming / Transfer issues on some devices.
-Camera locks up at times, and will cause a reboot.
-Download the Catlog app from the Play Store.
There is also a donate version which you can purchase to show appreciation.
-After downloading the Catlog app, go to the app settings, and change the log level to Debug.
-Clear all previous logs and take the exact steps to produce the error you are receiving.
-As soon as you receive the error (probably a force close), go straight into Catlog and stop the log recording.
-Copy and paste the entire log either to Hastebin or Pastebin
-Save the log, and copy and paste the link into the forum with a brief description of the error.
-You can also open trouble tickets on our website for bugs.
BPop.jpgBPop01.jpgBPop1.jpgBPop2.jpgBPop3.jpghttp://teambliss.x10host.com/BlissPop/ScreenShots/BPop.4jpg BPop5.jpgBPop6.jpgBPop8.jpgBPop9.jpg
If you would like to donate for further development of Bliss Roms,
(or to buy us a beer every now & again), visit this link:
PayPal Donate Link
Any & all donations are greatly appreciated.
The Bliss Team:
Thanks to [MENTION=4396647]skyliner33v[/MENTION] for the wallpapers & boot animations.
[MENTION=2490658]pimpmaneaton[/MENTION], [MENTION=5216756]jackeagle[/MENTION], [MENTION=5052522]nprev420[/MENTION], [MENTION=3987079]remicks[/MENTION], [MENTION=4442122]Deliberate[/MENTION], [MENTION=4003363]xboxfanj[/MENTION]
[MENTION=5159622]nerdyblonde[/MENTION], [MENTION=5168118]Vortex1969[/MENTION],[MENTION=5346868]pjgraber03[/MENTION], [MENTION=4279318]bracketslash[/MENTION],[MENTION=2975319]death2all110[/MENTION], [MENTION=928479]electrikjesus[/MENTION],
[MENTION=6026679]kornfed[/MENTION], [MENTION=5686358]_moelle[/MENTION], [MENTION=2089878]asianflavor[/MENTION], [MENTION=3367894]Jiggs82[/MENTION], [MENTION=5776465]genesixxbf3[/MENTION]
&& Thanks to a ton of other people who have contributed to the source that we used to build the rom!
Thanks to [MENTION=947981]Lord Boeffla[/MENTION] for his kernel http://www.boeffla-kernel.de/
  • 4 weeks later...
Je trouve que le portage sur le S3 est encore un peu trop "bancal" ...
Pas mal de force close et autre appli qui plantent, soucis sur l'appareil photo, souci avec le wifi et le BT sur mon tel ...
-> Les wipe/data, et cie ont tous été faits.
bref pas pour moi pour le moment...
As tu installé boeffla kernel ?
