Erreur sur un insert Sqllite no column named..
Je vous contact car j'ai un gros soucis.
Je n'arrive pas à accéder aux tables créer ou celle-ci ne se créer pas bien.
Bdd_manager
public class Bdd_manager extends SQLiteOpenHelper {
    public static final String lentus = "lentus";
    public static final String Morning_before = "morning_before";
    public static final String Morning_after = "morning_after";
    public static final String Morning_insu = "morning_insu";
    public static final String Midnight_before = "diner_before";
    public static final String Midnight_after = "diner_after";
    public static final String Midnight_insu = "diner_insu";
    public static final String EndDay_before = "enday_before";
    public static final String EndDay_after = "enday_after";
    public static final String EndDay_insu = "enday_insu";
    public static final String Night = "night";
    public static final String CommentofDay = "commentofday";
    public static final String tdate = "date";
    public static final String TABLE_NAME = "Diabhelp_CDN";
    public static final String TABLE_CREATE = "CREATE TABLE " + TABLE_NAME + " (" + tdate + " TEXT, " + Morning_before + " DOUBLE, " + Morning_after + "DOUBLE," + Morning_insu + "DOUBLE," + Midnight_before + "DOUBLE," + Midnight_after + "DOUBLE," + Midnight_insu + "DOUBLE," + EndDay_before + "DOUBLE," + EndDay_after + "DOUBLE," + EndDay_insu + "DOUBLE," + Night + "DOUBLE," + CommentofDay + "TEXT," + lentus + "DOUBLE);";
    public static final String TABLE_DROP = "DROP TABLE IF EXISTS " + TABLE_NAME + ";";
    public Bdd_manager(Context context, String name, SQLiteDatabase.CursorFactory factory, int version) {
        super(context, name, factory, version);
    @[member=override]
    public void onCreate(SQLiteDatabase db) {
        db.execSQL(TABLE_CREATE);
    @[member=override]
    public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
        db.execSQL(TABLE_DROP);
        onCreate(db);
le fichier DAO :
public class DAO extends DAOBase {
     * @param m le métier à ajouter à la base
    public DAO(Context context)
        this.mHandler = new Bdd_manager(context, NOM, null, VERSION);
    public void AddDay(DayofCDN m) {
        ContentValues value = new ContentValues();
        value.put(lentus, m.getSlowInsu());
        value.put(Morning_before, m.getGlycMorning(0));
        value.put(Morning_after, m.getGlycMorning(1));
        value.put(Morning_insu, m.getInsuMorning());
        value.put(Midnight_before, m.getGlycMidDay(0));
        value.put(Midnight_after, m.getGlycMidDay(1));
        value.put(Midnight_insu, m.getInsuMidDay());
        value.put(EndDay_before, m.getGlycEnDay(0));
        value.put(EndDay_after, m.getGlycEnDay(1));
        value.put(Midnight_insu, m.getInsuEndDay());
        value.put(Night, m.getNight());
        value.put(CommentofDay, m.getCommentofDay());
        value.put(tdate, m.getDate());
        mDb.insert(DAO.TABLE_NAME, null, value);
     * @param // l'identifiant du métier à supprimer
    public void deleteDay(String _date) {
        mDb.delete(TABLE_NAME, tdate + " = ?", new String[] {_date});
     * @param m le métier modifié
    public void Update(DayofCDN m) {
        mDb.update(TABLE_NAME, value, tdate  + " = ?", new String[] {String.valueOf(m.getDate())});
     * @param //id l'identifiant du métier à récupérer
    public DayofCDN SelectDay(String mtDate) {
        DayofCDN m = null;
        Cursor c = mDb.rawQuery("SELECT * from " + TABLE_NAME + " where " + tdate + " = '" + mtDate +"'", null);
        String[] i = c.getColumnNames();
        c.moveToNext();
       if (c.getColumnIndex(tdate) == 0)
           return null;
       double morning_before = c.getDouble(c.getColumnIndex(Morning_before));
       double morning_after = c.getDouble(c.getColumnIndex(Morning_after));
       double morning_insu = c.getDouble(c.getColumnIndex(Morning_insu));
       double midDay_before = c.getDouble(c.getColumnIndex(Midnight_after));
       double midDay_after = c.getDouble(c.getColumnIndex(Midnight_after));
       double midDay_insu = c.getDouble(c.getColumnIndex(Midnight_insu));
       double night = c.getDouble(c.getColumnIndex(Night));
       double endDay_before = c.getDouble(c.getColumnIndex(EndDay_before));
       double endDay_after = c.getDouble(c.getColumnIndex(EndDay_after));
       double endDay_insu = c.getDouble(c.getColumnIndex(EndDay_insu));
       double mlentus = c.getDouble(c.getColumnIndex(lentus));
       String tCommentodday = c.getString(c.getColumnIndex(CommentofDay));
       m = new DayofCDN(mtDate);
       m.setCommentofDay(tCommentodday);
       m.SetSlowInsu(mlentus);
       m.setNight(night);
       m.setGlycMorning(morning_before, morning_after);
       m.setInsuMorning(morning_insu);
       m.setInsuMidDay(midDay_insu);
       m.setInsuEndDay(endDay_insu);
       m.setGlycMidDay(midDay_before, midDay_after);
       m.setGlycEndDay(endDay_before, endDay_after);
       return m;
DAOBASE (Abstraction)
package fr.diabhelp.carnetdesuivi;
import android.content.Context;
import android.database.sqlite.SQLiteDatabase;
 * Created by Damien on 11/02/2015.
public abstract class DAOBase {
    // Nous sommes à la première version de la base
    // Si je décide de la mettre à jour, il faudra changer cet attribut
    protected final static int VERSION = 2;
    // Le nom du fichier qui représente ma base
    protected final static String NOM = "dh_db.db";
    protected SQLiteDatabase mDb = null;
    protected Bdd_manager mHandler = null;
    public DAOBase(Context pContext) {
        this.mHandler = new Bdd_manager(pContext, NOM, null, VERSION);
     public DAOBase() // pas sur de ça
        this.mHandler = new Bdd_manager(null, NOM, null, VERSION);
    public SQLiteDatabase open() {
        // Pas besoin de fermer la dernière base puisque getWritableDatabase s'en charge
        mDb = mHandler.getWritableDatabase();
        return mDb;
    public void close() {
        mDb.close();
    public SQLiteDatabase getDb() {
        return mDb;
J'avoue commencer à désespérer après avoir vérifier 1 millions de fois mes requêtes et mon code..
l'erreur :
03-11 13:04:14.417      938-938/fr.diabhelp.carnetdesuivi E/SQLiteLog﹕ (1) table Diabhelp_CDN has no column named enday_before
03-11 13:04:14.457      938-938/fr.diabhelp.carnetdesuivi E/SQLiteDatabase﹕ Error inserting enday_before=0.0 morning_insu=0.0 morning_after=2.0 commentofday= enday_after=0.0 diner_after=0.0 lentus=0.0 morning_before=1.0 night=0.0 date=11-Mars-2015 diner_insu=0.0 diner_before=0.0
    android.database.sqlite.SQLiteException: table Diabhelp_CDN has no column named enday_before (code 1): , while compiling: INSERT INTO Diabhelp_CDN(enday_before,morning_insu,morning_after,commentofday,enday_after,diner_after,lentus,morning_before,night,date,diner_insu,diner_before) VALUES (?,?,?,?,?,?,?,?,?,?,?,?)
le soucis serais qu'il n'y a pas de colonne nommée enday_before (mais c'est la première valeur de l'insert, donc je suppose qu'aucune colonne n'est crée).
Je vous remercie par avance,
Naqued
Bon j'était sur se soucis depuis 6h, d'ou ma frustration...
je ne trouve pas le moyen d'effacer le poste. Donc la solution est que :
Mes tables sont bien créer comme il faut (c'est pour ça que ma requete de CREATE passe).
Malheuresement.. j'ai oublié un espace dans ma requete de CREATE avant tout mes typages. càd que mes tables s'appelaient : enday_beforeDOUBLE et non enday_before.
Sujet Clos...
