Impossible d'écrire vers un périphérique USB ?
Hello !
Avec ES Explorer, je ne peux pas écrire sur un périphérique USB, juste lire.
Si je comprends bien ça
https://code.google.com/p/android/issues/detail?id=67570#c4444
We heard loud and clear that developers wanted richer access beyond these directories, so in Lollipop we added the new ACTION_OPEN_DOCUMENT_TREE intent.  Apps can launch this intent to pick and return a directory from any supported DocumentProvider, including any of the shared storage supported by the device.  Apps can then create, update, and delete files and directories anywhere under the picked tree without any additional user interaction.  Just like the other document intents, apps can persist this access across reboots.
This gives apps broad, powerful access to manage files while still involving the user in the initial selection process.  Users may choose to give your app access to a narrow directory like “My Vacation Photos,” or they could pick the top-level of an entire SD card; the choice is theirs.
Il faut rooter la tablette avec ça ?
http://droidbasement.com/db-blog/?p=3671
Quelqu'un a fait ? confirme que ça résouds cette hérésie ?
Merci :)
Modifié par stef33560
