[ROM] [5.1.1] NX Rom 9.6.4
Qu'est-ce que NX ?
"Nexus Experience Rom" est une rom basé sur l'AOSP, donc en gardant le look et le style d'Android pure mais en le rendant plus...puissant ;) C'est juste une rom personnalisé comme celle ci qui peu vous offrir cette puissance !
​Changelogs ( vous trouverez également les caractéristiques )
Release 9.6.4
*Fix a issue that bring incompatibility for some apps when change default DPI
*Option to select format of Call record file
*Smart Mute
*Fix Status bar SIM icon for Multi-sim devices
*Some fixes and improvements in system
Release 9.6.2
*Android 5.1.1 R3 merged
*Bring back LCD Density option
*Sync Tile
*Persist Power Profile after reboot if Per-app Profiles are disabled
Release 9.5.2
*Zen mode buttons on Power menu
*Option to hide Power menu on Lock screen
*PT-BR translations
*Fix status bar carrier alignment
*LCD Density option removed to fix some apps issues
Release 9.4
*Option to disable Superuser icon on Statusbar
*Fixed a bug that some applications can't be installed with successful
*Fix volume key music control with Ambient display
*Ambient display Tile
*Add 10% Battery Saver Trigger and expand options up to 30%
Release 9.3
*PIE Control
*Fixes in NX features for Multiuser
*Data Tile
*Heads Up Tile
*Allow/Prevent notification light in None Notifications mode
*Status bar carrier and custom name
*Custom Density setting
*Changes in FAB Clear all
Release 9.1
*Android 5.1.1 R1 merged
*Fixes in None notifications mode
*Return of Silent mode (enable or disable it in Interruptions menu)
*Remove Holo UI in Telephony apk
Release 9.0
*Android 5.1 R5 merged
*Use WebViewGoogle (can be updated from Play Store)
*CM Theme Engine
*Profiles
*Blacklist
*Expanded desktop
*Privacy Guard
*LiveDisplay
*Custom Quick Tiles
*Navigation ring targets
*Navigation bar customization
*Lock screen bottom shortcuts customization
*Option to auto-hide Status bar Network traffic
*Configurable Pattern size
*File Manager
*Some improvements and bugfixes
Release 8.0.2
*Android 5.1 R3 merged
*Attempt to fix Volume Rocker Seeker (Works with Ambient display disabled)
Release 8.0.1
*Android 5.1 merged
*All features of 7.2.4 Release
*Fix on HeadsUp for all notifications
*Play Services battery drain fixed
Release 7.2.3 / 7.2.4
*Ambient display time out in Settings > Display
*Fixes for Battery styles
*Materialize volume panel in-out animation
*Fixes and improvements for all devices
*In-call vibration features
Release 7.2.2
*Android 5.0.2 R1 merged
*Lock screen user configurable shortcuts
*Battery icon options and text mode
*Long pressing recent switch to last app
*Ability to change the color in battery saver mode
*Bring back stock MusicFX
*Fix in statusbar header weather
*Fix and improvements in System
Release 7.1
*Heads up for all fixed (No more issues with incoming call and no more Heads up at Lock screen)
*Back to Stock Kernel for Nexus 5 with D2W added (You can download 7.0 Custom kernel below ROM Download link
*Pin keypad shuffler
*Quick unlock
*Smoother Upload and Download Animation
*Volume rocker button seek on screen-off
Release 7.0
*Android 5.0.1 r1 Merged
*Fully merged my N5XPA KK Kernel for Nexus 5 into Lollipop Kernel with all features inside (Best battery life with best performance)
*Full Multirom support for Nexus 4 and Nexus 5
*OTG Support for Nexus 4 and Nexus 5
*Double-tap to wake integrated in Settings > Display on Nexus 5
*AppOps in Settings > Security
*New Interface menu in Settings (All from Display > Settings are on it)
*Option to disable Heads up notifications
*Option to enable Heads up notifications for all apps
*Option to enable Notification Ticker
*Option to disable Quick settings on secure Lock screen
*Option to add weather in Status bar header
*LockClock (cLock) widget with material interface by me
*Option to quick pull down from left side
*Smart pulldown
*LCamera app with 4K recording capabilities for Nexus 5 and Nexus 6 (Thanks to PkmX)
*DSP Manager with material interface by me
*Status bar header clock and date clickable
*Battery percentage beside of battery icon
*Don't block Home button if incoming call is a Heads up
*Clear all recents button now close all apps again
*Fixes in Center clock
*Updated translations
Release 6.2
*FAB clear all recents with Fade in and Fade out effect
*Navigation bar clear all recents
*Option to disable Search widget on Recents screen
*Recents screen settings on Settings > Display where you can manage these options
*Both Clear all recents now close only visible apps (Foreground and non visible cards still open)
*Per app controls for lock screen notifications
*ROM now comes rooted! Don't need to flash SuperSU. Superuser is built-in in Settings. If you want to flash SuperSU, flash this on recovery and Superuser gone from Settings. If you want to DISABLE Root access, go to Developer Settings and disable it
Release 6.1
*Fix Google Play Services wakelocks
*Fix navigation bar back ime button in landscape
Release 6.0
*Clear All Recents button
*Battery and Notification lights control
*Double-tap to sleep on Status bar
*Status bar brightness control
*Option to disable Quick pull down
*Decrease Quick pull down area
*Improve scrolling cache
*Volume key adjust sound
*AdvancedReboot enabled by default
*Fix boot animation delay
Release 5.6
*Based on tag android-5.0.0_r6 (LRX21T) from AOSP sources
*Full Nexus Experience from Google Factory images including GAPPS
*Permissive Kernel (Just flash Latest Chainfire SuperSU to get Root)
*Ambient Display Option in Settings > Display
*Reboot, Airplane mode and Sound options in Power menu
*Quick Settings panel pull down with one finger on Status bar extreme top right
*Native battery percentage in >Display > Status bar
*Network traffic in Settings > Display > Status bar
*Navigation bar height in Settings > Display > Navigation bar
*Status bar Clock and date customization in Settings > Display > Status bar
*Timeout and instant lock options in Swipe screen lock
*0.75 and 0.25 animation transition modes
*Show application's package name in the "App info" screen
*SuperSU in Settings if SuperSU is installed
*Filter spam notifications in Settings > Battery > Battery saver
*Advanced options for Input methods in Settings > Language and input
*Volume rocker wake up in Settings > Display
*Wake up device if charger is plugged/unplugged in Settings > Display
*Safe headset volume, Less annoying sound notification and Option to use volume keys to control media volume anytime in Settings > Sound > Advanced options
*NX features translations in over 10 languages
ROM
GAPPS
Modifié par Teoandro
J'ai tournée un peu sur cette rom(c'était au moment de la version 5.0 ), qui avant était pas top en autotomie avec le kernel intégrer a la rom,mais très fluide et bien personnalisable, je vois que sur le changelog de la 9.3 il a intégré le PIE, cela me plait bien  :)
@@Teoandro, elle est comment en autonomie,maintenant?
Avec Code Blue, l'autonomie est bonne, je tiens à peu près entre 8h30 et 9h en utilisation normal ( wifi allumé, messages, internet,... ) :)
  • 1 month later...
