Teoandro Posté(e) 20 août 2015 Share Posté(e) 20 août 2015 (modifié) Caractéristiques:Memory leak fixes and other fixes from AOSP.Layers 2.1 Support [Latest].Notification Ticker.Statusbar Brightness Control.Show Notification Count.Double-tap Statubar or Navbar to sleep.Clock Customization [Left,Center,Right].Headsup Swipe.Battery Status Style.Privacy Guard.Blacklist.Filter Notifications.Smart Call.Smart Mute.Detailed Caller Information.Phone Number Lookup.Quick Pin Unlock.Gesture Unlock.Quick Settings.Quick Pulldown.Show Weather [it will be removed soon].Ability to disable Heads up.Force Expanded Notification.Advanced Reboot.Screen Record.Clear All Recents [Top right, Top left, Top center, Bottom right, Bottom left, Bottom center].Show Search Bar in Recents Menu.LCD Density.Navbar Customization.Navrings Customization.Re-Orient Volume Buttons.Expanded Desktop.Ambient Display Customization.Silent Mode.Battery Light Customization.LED Notification Customization. Vidéo de la rom en action Téléchargement : http://click.xda-developers.com/api/click?format=go&jsonp=vglnk_144008086584617&key=f0a7f91912ae2b52e0700f73990eb321&libId=idkaigst01000n4o000DLjbzaca49&loc=http%3A%2F%2Fforum.xda-developers.com%2Fgoogle-nexus-5%2Fdevelopment%2From-minimal-os-nexus-5-t3155283&v=1&out=https%3A%2F%2Fbuilds.hubdroid.com%2Fminimal%2Ffinal%2Fhammerhead%2F&ref=https%3A%2F%2Fwww.google.fr%2F&title=%5BROM%5D%5BOFFICIAL%5D%5B5.1.1%5D%5BLAYERS%5D%5BUBER%5D%20Minimal%E2%80%A6%20%7C%20Google%20Nexus%205%20%7C%20XDA%20Forums&txt=HubDroid Changelogs ( delta update par ota ) 17/08/2015 Revamped DocumentsUI (You'll love it) Add cLock Settings (Settings > Minimal tweaks)That's all for now 08-15-2015 LATEST STAGEFRIGHT FIXES 08-14-2015 Changelog is huge, check the link above 08-06-2015 BUILD LMY48I. DO NOT ASK IF STAGEFRIGHT IS FIXED BECAUSE IT WAS ALREADY FIXED LONG BACK. FIXED THE ANNOYING NOTIFICATION BUG DURING INCOMING CALL. NOTIFICATION TICKER IS BACK. LOCKSCREEN WALLPAPER CAN NOW BE CHANGED. FOR MORE DETAILED CHANGELOG VISIT GITHUB, THE CHANGELOG SCRIPT SOMEHOW FAILED FOR THIS BUILD. 2015-08-04 * Fixes to Power menu Dialog * RRO: idmap: fix sorting of overlays.list * Screen pinning improvements * Revert "Revert "Fix Heads-up tile transparency in off state"" * Lets take it a little deeper Define an adjustable category border * Track the common color name to stay consistant with layers and define corner radius in dimen to allow the control or corners * Allow images to be used on dashboard This is somethin Branden M and myself have been working on Now we can allow themes to use images in dashboard without altering the way a basic theme works backwards compatible Modifié 20 août 2015 par Teoandro Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
3vilo Posté(e) 21 août 2015 Share Posté(e) 21 août 2015 Hello, Tu l'as essayé ? Tu en es satisfait ? ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 21 août 2015 Auteur Share Posté(e) 21 août 2015 (modifié) Hello, Tu l'as essayé ? Tu en es satisfait ? ;) Oui je l'ai essayé :) alors elle est très très stable, les maj sont régulière et envoyé par ota sous forme de delta ( à la manière de l'omnirom ) la seul chose que je regrette : layers ... Je ne suis pas fan de ce système de thème ... Voilà voilà sinon les options de personnalisation sont celle classiques, la batterie tiens très bien avec le kernel d'origine :) Modifié 22 août 2015 par Teoandro Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
3vilo Posté(e) 21 août 2015 Share Posté(e) 21 août 2015 Merci pour ton retour. Je vais essayer à mon retour de vacances. Effectivement, je préfère les thèmes aux layers également... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
carlito Posté(e) 23 août 2015 Share Posté(e) 23 août 2015 Hello Y a pas besoin d'installer de gapps ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 24 août 2015 Auteur Share Posté(e) 24 août 2015 Hello Y a pas besoin d'installer de gapps ? Nan il faut les installer .. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
carlito Posté(e) 24 août 2015 Share Posté(e) 24 août 2015 Nan il faut les installer .. Merci. Par contre j'ai cru comprendre sur le forum XDA qu'il faut mettre à jours les gapps après chaque mise à jour OTA et donc reconfigurer tout à chaque fois. Ca me semble pas pratique Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Teoandro Posté(e) 24 août 2015 Auteur Share Posté(e) 24 août 2015 Merci. Par contre j'ai cru comprendre sur le forum XDA qu'il faut mettre à jours les gapps après chaque mise à jour OTA et donc reconfigurer tout à chaque fois. Ca me semble pas pratique Pas la peine de tout reconfigurer juste installer les gapps, la config' ne ce fait qu'une fois ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
