themadcow Posté(e) 19 septembre 2015 Share Posté(e) 19 septembre 2015 (modifié) Bonjour, Tout d'abord je précise que je ne suis pas le développeur de ce kernel, je ne suis d'ailleurs pas un développeur du tout :) Je me contente de poster ici le super boulot de Squid2 sur XDA-Developers. Features: LED notification support Moderately undervolted Updated to Linux 3.10.90 Includes the latest CodeAurora changes Optimized ARM crypto routines KCAL MDP5 colour control (by savoca) FIOPS and BFQ I/O schedulers Updated f2fs and WiFi drivers Improved zRAM backported from Linux 4.1 Stripped down and optimized configuration Compiled with Linaro GCC 4.9.3 and optimized for Cortex A53 Versions : r10d: October 26, 2015 - Fixed r10c SELinux regression on stock ROM r10c: October 24, 2015 - Fixed encryption support - Patches for Android 6.0 compatibility r10b: October 4, 2015 - Fixed move app to SD card issue - Cleaned up DTBs to reduce size r10: October 3, 2015 - Added KCAL colour control (by savoca) - Added optimized crypto routines for ARM - Updated to Linux 3.10.90 - Optimized memory performance - General cleanup and optimization r9e: October 1, 2015 - Fixed reboot to recovery r9d: October 1, 2015 - Fixed screen glitches r9c: September 30, 2015 - Updated to proper kernel sources - Updated to Linux 3.10.89 - Updated to LA.BR.1.1.3_rb1.32 - Small tweaks and optimizations r8b: September 18, 2015 - Fixed Moto Voice - Updated to Linux 3.10.88 r8: September 13, 2015 - Initial release for lux Sources : https://github.com/sultanqasim/android_kernel_motorola_msm8916 Téléchargement : r10d: http://forum.xda-developers.com/devdb/project/dl/?id=14907 r9e: https://www.mediafire.com/?0pzgeybooshp1yc r8b: https://www.mediafire.com/?ivvy7dp2x9h76yy =============================================== En plus du kernel ci-dessus, Squid2 propose également une version minimal de son kernel. Il s'agit d'un kernel qui ne garde que l'essentiel et reprend les optimisations indispensables pour bien fonctionner avec le X-Play et offrir le meilleur rapport autonomie/performances/stabilité. On y trouvera moins de possibilité de tuning que dans la version complète mais les essentiels sont là : - contrôle de la LED - améliorations des I/O - améliorations du scheduler - divers optimisations mémoire. Sources : https://github.com/sultanqasim/android_kernel_motorola_msm8916/tree/squid_minimal Téléchargement : http://www.mediafire.com/download/qsskxyp5xt8wprp/squid_kernel_mini-lux.zip Modifié 26 octobre 2015 par themadcow Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themadcow Posté(e) 2 octobre 2015 Auteur Share Posté(e) 2 octobre 2015 Mise à jour: ajout de la version r9e en date du 02/10/2015. Le Kernel est maintenant basé sur les sources officielles de Motorola. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themadcow Posté(e) 26 octobre 2015 Auteur Share Posté(e) 26 octobre 2015 Version r10d en ligne. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
milou Posté(e) 19 novembre 2015 Share Posté(e) 19 novembre 2015 Bonjour Je ne connais pas bien la différence entre un kernel, une rom stock ou autre rom. Je vois bien dans le changelog ce qu'apporte le kernel. Cela semble intéressant. Il y a le lien pour télécharger. Mais comment s'installe le kernel ? C'est un fichier ZIP Merci d'avance à vous Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themadcow Posté(e) 19 novembre 2015 Auteur Share Posté(e) 19 novembre 2015 Le kernel custom c'est comme le tuning du moteur d'une voiture. Ça ne se voit pas, c'est sous le capot, mais ça donne de meilleurs performances. Pour l'installation il faut passer par un custom recovery (TWRP) et le déverrouillage du bootloader qui fait sauter ta garantie. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
milou Posté(e) 19 novembre 2015 Share Posté(e) 19 novembre 2015 Merci pour cette reponse Pour installer un custom recovery, il faut etre root et aussi installer un recovery Avez vous un lien de tuto qui explique cela pour le play X? Merci encore Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themadcow Posté(e) 20 novembre 2015 Auteur Share Posté(e) 20 novembre 2015 (modifié) Salut, non le root n'est pas nécessaire et il n'est de toute façon pas possible sans ces étapes. La première question est de savoir si tu es prêt à faire officiellement sauter la garantie de ton téléphone ? Modifié 20 novembre 2015 par themadcow Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
milou Posté(e) 21 novembre 2015 Share Posté(e) 21 novembre 2015 (modifié) oui je suis tout à fait pret à ca juste 2 questions que je me pose : - comment il s'installe ce kernel et donc avant le TWRP - pourra t'on bénéficier d android 6 s'il y a eu mise à jour du kernel? Qui a fait la mise à jour dans la communauté? comment? Quel résultat recherché et obtenu ? Merci Modifié 21 novembre 2015 par milou Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
christw69 Posté(e) 23 mars 2016 Share Posté(e) 23 mars 2016 je regarde votre sujet l'utilisation de LED de notification (caché) m'intéresse. cela n'est pas tres simple cette histoire de kernel. je ne comprend pas l'intérêt de motorola d'avoir intégré une LED non fonctionnel si elle y est vraiment Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
