[ROM] CyanogenMod pour le Moto X Play
je ne suis pas l'auteur de cette ROM. Tout le mérite revient à Squid2, @@Shreps et @@Vache qui ont collaboré pour compiler cette ROM.
Le sujet original de Squid2 se trouve ICI.
Comme toujours avec une custom ROM, vous flashez à vos risques et périls !
Il est indispensable d'avoir déverrouillé son bootloader et d'avoir flashé TWRP.
Historique:
October 24, 2015:- RIL configuration updates
- Speakerphone mic config updates
October 21, 2015:
- Refixed speakerphone
- Fixed encryption
- Reverted commit causing WiFi keep awake
October 18, 2015:
- Fixed high impedance audio line out
October 17, 2015:
- Added support for Australian "vfaus" variant
- CM updates
October 12, 2015:
- Switched to stock-ish kernel planned for official support
- Switched back to source built HALs with h2o64 fixes
- Added support for Brazilian "tefbr" variant
October 11, 2015:
- Fixed call audio issues (speakerphone mic etc.)
- Fixed GPS reboot issue
- Kernel fixes and updates
- CM updates
October 1, 2015:
- Kernel updated with proper Motorola changes
- Other kernel updates
- CM updates
September 27, 2015:
- Enabled multistream zRAM compression
- Updated kernel to Linux 3.10.89
- CM updates
September 21, 2015:
- Dual SIM Brazilian XT1563 support
- Vendor blob cleanup
September 20, 2015:
- Single SIM XT1562 support
- Miscellaneous smaller fixes
September 19, 2015:
- Initial release for general public consumption
Téléchargement:
Procédure:
  • Téléchargez la build la plus récente
  • Téléchargez les GApps
  • Copiez le zip sur votre carte SD ou la mémoire interne du téléphone
  • Bootez en recovery
  • Pour la première installation faites un wipe data / factory reset
  • Flashez la ROM
  • Flashez les GApps
  • Rebootez
Sources:
Device tree : https://github.com/boulzordev/android_device_motorola_lux/tree/cm-12.1
Vendor tree : https://github.com/boulzordev/android_vendor_motorola_lux/tree/cm-12.1
Kernel : https://github.com/sultanqasim/android_kernel_motorola_msm8916/tree/cm-12.1
Modifié par themadcow
Whaou déjà CM 12.1 sur le Moto X Play c'est du rapide dis donc. Après le Moto G 2015 a très vite était soutenu officiellement (pas juste portage) par Cyano avec une 1ere buil le 24 spet (http://download.cyanogenmod.org/?device=osprey) tout comme le Moto E 2015 (http://download.cyanogenmod.org/?device=otus) donc le Moto X Play devrait suivre le même exemple
Mise à jour du 1er Octobre, la ROM intègre maintenant le kernel de Squid2 basé sur les sources officielles de Motorola. En revanche le bug du GPS dont parle Jean-seb est toujours présent, en attendant pour l'éviter il est recommandé de passer le GPS en mode économie d'énergie (celà aura bien sur une grosse incidence sur la localisation).
  • 4 weeks later...
  • 6 months later...
Bonjour
Le bug du GPS est il toujours présent ? Même sur le version CM 13 ?
D'autre part, si je copie la rom et les GApps sur la mémoire interne ( j'ai pas de carte sd ext), comment se fait il qu'elle ne soit pas effacée en cas de factory reset ?
Envoyé de mon XT1562 en utilisant Tapatalk
  • 1 month later...
  • 4 weeks later...
