[ROM] 6.0 Android MarshMallow Pure AOSP for Google Nexus 7 2012 WIFI (TOPIC EN COURS DE CREATION)
[ROM] 6.0 Android MarshMallow Pure AOSP for Google Nexus 7 2012 WIFI CodeName Grouper Build 10/31
android_6_marshmallow_logo.jpg?x=648&y=3
- Ni moi, ni la communaute Frandroid ne peuvent etre retenu responsable en cas d un brick de téléphone ou d une carte SD qui ne fonctionne plus
- Faites des recherches sur le topic original, pour tout problèmes.
- N hésitez pas à rapporter des bugs.
- Faites très attention de bien lire et suivre les instructions sur ce topic, si celui-ci est trop vieux référé vous au topic original XDA
INSTRUCTIONS,
1. METTRE A JOUR LE RECOVERY en TWRP 2.8.7.0
2. FACTORY RESET full wipes
3. Download ROM Build 10/31
4. Gapps 6.0
5. Root (Facultatif) Direct Download
Warning Message
At this moment do not use any third part software or framework like xposed!!!Rom will be unbootable or unstable
CREDITS,
AOSP/Google,Dmitry Grinberg for great initial support on build
Bugs
During Google Account registration if you choose Restore device phone return to same screen.After that choose Configure as new device and restore start normally!!!
Stock rom browser generate random soft reboot if you enable Location sharing with device only mode in Location options!!!
Changelog
Beta Release 0.1 Build 10/15
Initial support for N7 2012 WIFI on AOSP MarshMallow
Kernel compiled with Christopher83 4.9 arm toolchain based on google asus 3.1.10 lollipop-mr1 and kernel patch of Dmitry Grinberg
Enable sparsemem option on kernel to optimize memory managemnt and free up memory quickly
Add some options to speed up first boot and dex2oat compilation
Beta Release 0.2 Build 10/19
Possible fix to random sound and autorotate issue
Beta Release 0.3 Build 10/29
Kernel 3.1.x compiled with last 4.9 toolchain
Possible fix to autorotate sound and GPS bug and random sensor problems (test needed!!)
Beta Release 0.4 Build 10/30
Kernel 3.1.x compiled with last 4.9 toolchain reworked to avoid random freezes after deep sleep
Compiled with latest commits of AOSP sources 6.0.0_r1
New BootAnimation based on Nexus factory Images MM
Beta Release 0.5 Build 10/31
Fix NFC lost on Settings--> Other
Sources
Google
Kernel tree
SOURCE
Modifié par LudoG4
  • 2 months later...
Bonjour çà à l'air de fonctionner plutôt pas mal mais il faut prendre la dernière ROM Build disponible sur le forum XDA en suivant la source du 1er post.
Les GApps ne fonctionnent pas selon le dernier commentaire du sujet.
J'ai pris finalement ce lien là : http://download.dirtyunicorns.com/files/gapps/banks_gapps/
J'avais déjà le PlayStore avec l'installation de base et là j'ai juste la recherche et la recherche vocale de Google.
Apparement on peut avoir Chrome, Youtube etc par le Play Store mais c'est étrange je pensais que c’était installé de base.
Le problème du son est réglé en branchant un casque audio puis en redémarrant la tablette.
Modifié par Fox5959
Bonjour @Fox5959@sibilance
Si vous cherchez une ROM fonctionnelle a % prenez celle-là
http://forum.xda-developers.com/nexus-7/development/rom-team-octos-oct-l-t3035425
Aucun problème de son ou de rotation écran, très fluide et autonomie batterie très bonne.
Si vous avez des questions, n’hésitez pas mais 2 nexus 7 tourne dessus ;)
Il n'y a pas de problème de son ni de rotation !
J'ai redécouvert ma tablette !
A l’occasion je testerais celle que tu présentes.
J'allais investir dans une nouvelle tablette avant de tiomber la dessus!
Un grand merci!!
Hello,
bon j'ai ressorti ma nexus du placard
j'ai deverouillé le bootloader & j'ai root la nexus
j'ai voulu mettre la rom que tu cite et là....
[color=red]qd[/color] je install la rom
j'obtient un message erreur dans les debut du script
E:error executing updater binary in zip '/scard/OCT-M-WEEKLY-20160305-0707-grouper.zip'
error flashing zip '/scard/OCT-M-WEEKLY-20160305-0707-grouper.zip'
as tu une idée ?
  • 2 months later...
bon en fait mon précédent message est à oublié ;)
tout fonctionne et effectivement c'est super fluide
Toi aussi tu avais pris un build au pif  :ph34r:
C'est vrai qu'avec le bon (grouper) ça marche quand même vachement mieux  :)
Sinon c'est clair que la ROM est top, quelques lag tout de même (on ne pourra pas changer le hardware)
Par contre depuis que j'ai cette ROM j'ai un problème de charge lente, je suis à 40%, branché sur secteur et me demande 5h pour une charge complète  :o
Salutations à tous
