Vektrox Posté(e) 29 décembre 2015 Share Posté(e) 29 décembre 2015 Mise a jour du Firmware international en version 4.5.4 Voici le Change Note Highlight:This software update including enhancements and improvements for your device.Changelog:Notice: the international firmware stops supporting Themes(Personalize Center) and App Center from now on. Users of international versions who have purchased paid themes or apps can ask for refund via emails.MEIZU: cs@meizu.com.hk[system]Removed: App CenterRemoved: Contents related to Personalize Center/ThemesAdded: BurmeseOptimized: Translations of multiple languagesFixed: The drop-down status bar is stuck on the top occasionally when the middle of the notification bar is tappedFixed: The task manager is locked by applications when enabled in the portrait mode and lock icons on the applications are blocked when the task manager is switched to the landscape modeFixed: The mobile phone directly enters the host mode when the power button is pressed to light up the screen after the screen automatically dims in visitor modeFixed: The displayed battery left is 99% when the charger is plugged in the mobile phone but is 100% when the charger is unplugged[Communications]Optimized: Wi-Fi performanceFixed: No sound is heard on a call occasionallyFixed: Incoming calls occasionally fail to be connectedFixed: The issue of contacts might be deleted abnormallyFixed: The quantity of contacts is occasionally not displayed behind the title of the contact list[browser]Optimized: Transitional effects of portrait and landscape in some web pagesFixed: The browser is displayed abnormally when no image is displayed[Easy mode]Fixed: Multimedia SMSs can be received in easy mode but fail to be received after the mobile phone exits the easy modeFixed: The dialed number is displayed incompletely when the system language is set to English in easy modeFixed: The contact list is not ranked in numeric order in easy modeFixed: Two rings are played at the same time when a call is received during ring volume adjustment in easy mode[security]Fixed: Some strings are translated incorrectly in EnglishFixed: The traffic pool of SIM card 1 overlaps the traffic pool of SIM card 2[settings]Fixed: The setting of application rings fails when a user redirects to the application ring setting from a third-party application and then enters the settings to set the application ring[Phone]Fixed: Video is stuck or delayed after an incoming call is rejected[Camera]Fixed: Too much noise is displayed in the recording interface when video is shot in slow motion modeFixed: Photos are jagged severely and of poor quality when they are shot in slow motion mode using the main cameraOptimized: Photo shooting effects[Gallery]Fixed the issue of abnormally return to its previous picture after a picture is renamed Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jean-philippe Proux Posté(e) 10 janvier 2016 Share Posté(e) 10 janvier 2016 Bonjour, Lorsque je telecharge l'update, il est vu comme un fichier zip et pas comme un update (icone avec un nuage) Quelqu'un a une idée ? merci. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vektrox Posté(e) 10 janvier 2016 Auteur Share Posté(e) 10 janvier 2016 (modifié) Salut, c'est un .zip c'est pour ça :) Suivre la meme procédure que sur me M2 note ici Modifié 10 janvier 2016 par Vektrox Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jean-philippe Proux Posté(e) 10 janvier 2016 Share Posté(e) 10 janvier 2016 quelle est la différence de downloader le fichier via le M2 ou de passer par un PC ? je viens de faire le transfert via un mac ... idem le fichier est toujours vu comme un fichier ZIP Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vektrox Posté(e) 10 janvier 2016 Auteur Share Posté(e) 10 janvier 2016 Aucune, ça reste un fichier nommé "update.zip", ou est-ce que tu bloques ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jean-philippe Proux Posté(e) 11 janvier 2016 Share Posté(e) 11 janvier 2016 ben quand je clique dessus, il essaye d'ouvrir le zip et pas de faire l'installation :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vektrox Posté(e) 12 janvier 2016 Auteur Share Posté(e) 12 janvier 2016 Salut, Quelle rom actuellement sur le M2 ? stp Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jean-philippe Proux Posté(e) 14 janvier 2016 Share Posté(e) 14 janvier 2016 c'est la 4532A ... et que je mette des a ou des i impossible de les lancer ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Vektrox Posté(e) 17 janvier 2016 Auteur Share Posté(e) 17 janvier 2016 Je reviens sur ton histoire, j'ai mis un M2 a jour pour un copain en manuel car pas de détection en OTA pour son téléphone acheté sur AMAZON J'ai placer le fichier update.zip a la racine du téléphone, rebooter le téléphone en maintenant le bouton volume haut enfoncé… Suivre les instruction : Mise a jour avec possibilité de faire un reset des datas. (Attention ça efface tout) Mise a jour faite en 5 minutes chrono en 4.5.4i Info qui peut servir Après cette mise a jour l'application"Mémos" faisait que de planter, j'ai du prendre l'APK de la version 4.5.3i et lui re-installer et plus de soucis. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
