aegidius Posté(e) 27 juin 2016 Posté(e) 27 juin 2016 (modifié) Bonjour, J'ai besoin d'aide concernant un échec de sauvegarde de partition TA. Merci.Impossible de sauvegarder la partition TA (Xperia SP rooté, bootloader verrouillé et déverrouillable, Super SU installé, mode debugging, drivers installés, antivirus fermé, PC companion fermé, câble USB Sony, windows 10): que ce soit avec flashtool dernière version ([Advanced] > [Trim Area] >[Raw devices ] > [backup]message d'erreur : 27/020/2016 19:20:50 - INFO - <- This level is successfully initialized27/020/2016 19:20:51 - INFO - Flashtool Version 0.9.22.3 built on 08-06-2016 22:30:0027/020/2016 19:20:51 - INFO - Executing search strategies to find proxy selector27/020/2016 19:20:51 - INFO - No proxy found for IE. Trying next one27/020/2016 19:20:51 - INFO - No proxy found for firefox. Trying next one27/020/2016 19:20:51 - INFO - No proxy found for java. Trying next one27/020/2016 19:20:51 - INFO - Syncing devices from github27/020/2016 19:20:51 - INFO - Opening devices repository.27/020/2016 19:20:51 - INFO - Scanning devices folder for changes.27/020/2016 19:20:57 - INFO - Pulling changes from github.27/020/2016 19:20:58 - INFO - Quietly closing devices repository.27/020/2016 19:20:58 - INFO - Devices sync finished.27/020/2016 19:20:58 - INFO - Loading devices database27/020/2016 19:20:58 - INFO - Loaded 91 devices27/020/2016 19:20:58 - INFO - Starting phone detection27/021/2016 19:21:04 - INFO - Device connected with USB debugging on27/021/2016 19:21:04 - INFO - Connected device : Sony Xperia SP27/021/2016 19:21:04 - INFO - Installed version of busybox : BusyBox v1.22.1-Stericson (2014-01-25 17:27:18 CET) multi-call binary.27/021/2016 19:21:04 - INFO - Android version : 4.3 / kernel version : 3.4.0-perf-g4c8352f-00775-g89dacae / Build number : 12.1.A.1.20527/021/2016 19:21:05 - INFO - Checking root access27/021/2016 19:21:05 - INFO - Root Access Allowed27/021/2016 19:21:30 - INFO - Begin backup of /dev/block/platform/msm_sdcc.1/by-name/TA27/021/2016 19:21:30 - ERROR - Erreur when doing raw backup ou que ce soit avec Backup-TA-9.11 (MAJ : problème résolu (voir post #8): message d'erreur : ======================================= FIND TA PARTITION=======================================Partition found!======================================= BACKUP TA PARTITION=======================================dd: can't open '/sdcard/backupTA.img': No such file or directory======================================= INTEGRITY CHECK=======================================FAILED - Backup does not match TA Partition. Please try again.*** Backup unsuccessful. *** J'ai essayé avec et sans carte SD, mais je n'ai pas encore trouvé la cause, ni la solution. Modifié 29 juin 2016 par aegidius Citer
mrskyou Posté(e) 28 juin 2016 Posté(e) 28 juin 2016 Ok .... j'ai fait une petite recherche sous google avant de te répondre sur l'autre post, la solution est dispo sur un forum concurrent (dont je n'ai pas le droit d'évoquer le nom içi ^_^ ^_^/modopastapper) .... Je te donne la solution sur le message qu'il a posté, et il avait exactement les mêmes erreurs que toi :) Il suffit donc dans les scripts "Backup" et "Restore" de remplacer tout les "sdcard" par "sdcard1" Voilà normalement si tu suis sa solution tu seras à même de pouvoir sauver la TA et ensuite de déverouiller le BL puisque dans ton cas il est déverrouillable. :) Citer
aegidius Posté(e) 28 juin 2016 Auteur Posté(e) 28 juin 2016 (modifié) Merci.Mais cela fait malheureusement partie des solutions que j'ai déjà essayées. Je suis entrain d'en essayer une autre, je partagerai ici si c'est concluant.En tout cas merci, toute idée est la bienvenue. Mise à jour : Pour ma part, il a fallu que je modifie le script backup.bat de la méthode Backup-TA-9.11 de la façon suivante : j'ai retiré ma carte sd remplacé sdcard/backupTA.img par /storage/emulated/0/backupTA.img ça a permis de franchir une étape supplémentaire (en vert) jusqu'à ce que (en rouge) : Waiting for USB Debugging...OK======================================= FIND TA PARTITION=======================================Partition found!======================================= BACKUP TA PARTITION============================================================================== INTEGRITY CHECK=======================================OK======================================= PULL BACKUP FROM SDCARD=======================================remote object '/storage/emulated/0/backupTA.img' does not exist*** Backup unsuccessful. *** Alors que le fichier existe bien sur le téléphone, le srcipt a bien créé ce fichier et il n'est pas vide (environ 2Mo) L'erreur survient à l’exécution (je suppose) de la ligne suivante dans le script backup.bat : tools\adb.exe pull /storage/emulated/0/backupTA.img tmpbak\TA.img y aurait-il un problème avec la commande 'pull' de l'outil adb ? Je ne sais pas... voilà où j'en suis Je pense dans la prochaine étape, si je ne règle pas ce problème de 'pull', supprimer cette ligne, récupérer à la main ce fichier backupTA.img et le copier à la main dans le répertoire adéquat (c'est ce que la commande est normalement sensée faire je pense) afin que le script se poursuive (jusqu'à la prochaine erreur... -_- ) Modifié 28 juin 2016 par aegidius 1 Citer
mrskyou Posté(e) 28 juin 2016 Posté(e) 28 juin 2016 Apparemment tu as aussi posté sur x d a :) :p Citer
aegidius Posté(e) 28 juin 2016 Auteur Posté(e) 28 juin 2016 (modifié) :ph34r: oui mais pas dans le thread que j'aurais souhaité, car réservé aux membres éminents et/ou plus anciens ;) PS : message précédent mis à jour Modifié 28 juin 2016 par aegidius Citer
mrskyou Posté(e) 28 juin 2016 Posté(e) 28 juin 2016 Essaie ca :http://forum.xda-developers.com/showpost.php?p=65243525&postcount=2045 Citer
aegidius Posté(e) 28 juin 2016 Auteur Posté(e) 28 juin 2016 J'ai déjà fait aussi, je te le dis j'ai épluché ce thread :'( Citer
aegidius Posté(e) 28 juin 2016 Auteur Posté(e) 28 juin 2016 (modifié) Alors, ne me demandez pas pourquoi ça marche, mais en faisant ceci : remplacer tools\adb.exe pull /storage/emulated/0/backupTA.img tmpbak\TA.imgpar tools\adb.exe pull /sdcard/backupTA.img tmpbak\TA.img le processus a abouti !! Donc je suppose que les commandes : tools\adb.exe shell su -c "%BB% dd if=!partition! of=/storage/emulated/0/backupTA.img et tools\adb.exe shell su -c "%BB% md5sum /storage/emulated/0/backupTA.img n'interprètent pas les chemins de la même façon que : "tools\adb.exe pull /sdcard/backupTA.img tmpbak\TA.imgProblème en partie résolu seulement, car reste le problème flashtool ! Juste pour être sûr, voici le contenu du fichier zip de sauvegarde obtenu, vous paraît-il correct ? Modifié 28 juin 2016 par aegidius Citer
mrskyou Posté(e) 29 juin 2016 Posté(e) 29 juin 2016 Le backup obtenu semble correct, voici ce que j'avais obtenu dans mon cas , tu peux constater que c'est pareil; de toute façon garde bien en tête que ca te sauvera si ton portable a besoin de retourner en sav pour garantie,pas plus... car moi depuis que je suis sous rom custom j'ai jamais restaurer la TA et relocker le BL...surtout que la 6.0.1 est tellement mieux que la stock en 4.3 ^^ : 1 Citer
