flash z5 impossible
bonjour a vous tous je n arrive plus a flasher mon e6653 toujours message d erreur voir ci joint
je veux installer la derniere rom orange que j ai telecharger deja 3 fois mais impossible !!
merci de votre aide a tous
26/025/2016 18:25:57 - INFO - Flashtool Version 0.9.21.0 built on 28-04-2016 22:00:00
26/025/2016 18:25:57 - INFO - Executing search strategies to find proxy selector
26/025/2016 18:25:57 - INFO - No proxy found for IE. Trying next one
26/025/2016 18:25:57 - INFO - No proxy found for firefox. Trying next one
26/025/2016 18:25:57 - INFO - No proxy found for java. Trying next one
26/025/2016 18:25:57 - INFO - Syncing devices from github
26/025/2016 18:25:57 - INFO - Opening devices repository.
26/025/2016 18:25:57 - INFO - Scanning devices folder for changes.
26/026/2016 18:26:03 - INFO - Pulling changes from github.
26/026/2016 18:26:04 - INFO - Quietly closing devices repository.
26/026/2016 18:26:04 - INFO - Devices sync finished.
26/026/2016 18:26:04 - INFO - Loading devices database
26/026/2016 18:26:04 - INFO - Loaded 91 devices
26/026/2016 18:26:04 - INFO - Starting phone detection
26/026/2016 18:26:08 - INFO - Device disconnected
26/027/2016 18:27:06 - INFO - Decrypt canceled
26/028/2016 18:28:45 - INFO - Flash canceled
26/032/2016 18:32:52 - INFO - Device connected with USB debugging off
26/032/2016 18:32:52 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/034/2016 18:34:05 - INFO - Flash canceled
26/035/2016 18:35:35 - INFO - Flash canceled
26/036/2016 18:36:05 - INFO - Device disconnected
26/036/2016 18:36:06 - INFO - Device connected with USB debugging off
26/036/2016 18:36:06 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/036/2016 18:36:44 - INFO - Device disconnected
26/036/2016 18:36:47 - INFO - Device connected with USB debugging off
26/036/2016 18:36:47 - INFO - For 2011 devices line, be sure you are not in MTP mode
26/037/2016 18:37:00 - INFO - Device connected with USB debugging on
26/037/2016 18:37:01 - INFO - Connected device : Sony Xperia Z5
26/037/2016 18:37:01 - INFO - Installed version of busybox : N/A
26/037/2016 18:37:01 - INFO - Android version : 6.0.1 / kernel version : 3.10.84-perf-gf1cfa5f / Build number : 32.2.A.0.253
26/037/2016 18:37:01 - INFO - Root access denied
26/037/2016 18:37:31 - INFO - Flash canceled
26/044/2016 18:44:05 - INFO - <- This level is successfully initialized
tu as deja la .253, c'est la dernière MAJ
Mais tu peut quand meme tenter de passer a la version 9.22 de flashtool, et surtout verifie le lieu de stockage de ta ROM téléchargé (ta ROM doit se voir dans le cadre apres le choix de flashmode)
un peu d'aide ici: http://www.androidpit.fr/forum/503668/tuto-comment-installer-un-firmware-rom-en-utilisant-flastool-androxyde-sur-un-mobile-sony-sony-ericsson
ou la: http://https://www.google.fr/search?q=flashtool+tuto&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&ei=JqCXV662LcyA8QfCnYGIAQ#q=tuto+flashtool+xperia+z3+compact  et suite le 1er lien
Modifié par adjudantc
