themadcow Posté(e) 31 janvier 2017 Share Posté(e) 31 janvier 2017 (modifié) Merci à @Vache traduction de son post sur XDA. LineageOS is a free, community built, aftermarket firmware distribution of Android 7.1 (Nougat), which is designed to increase performance and reliability over stock Android for your device. Citation #include <std_disclaimer.h> /* * Your warranty is now void. * * I am not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at me for messing up your device, I will laugh at you. LineageOS is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. You will need to provide your own Google Applications package (gapps). LineageOS does still include various hardware-specific code, which is also slowly being open-sourced anyway. Base source code is available in the LineageOS Github repo. And if you would like to contribute to the project, please visit our Gerrit Code Review. Your changelog is whatever was merged into gerrit. Testé sur : XT1650-03 (version vendue en France) Download : lineage-14.1-20170130-UNOFFICIAL-griffin.zip Installation : Rebootez en recovery Formatez les partitions /system, /data et /cache Flashez le zip LineageOS [option] Flashez un pack de Google Apps (Open GApps est hautement recommandé [option] Installez l'addon "su" pour être root Problèmes connus : Si vous voulez rapporter un bug, merci de fournir des logs. Impossible de régler le volume pendant un appel Mode ralenti de la camera ne fonctionne pas Sources: Device: https://github.com/boulzordev/android_device_motorola_griffin Kernel: https://github.com/boulzordev/android_kernel_motorola_msm8996 Modifié 31 janvier 2017 par themadcow Ajout de la section problèmes connus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
themadcow Posté(e) 31 janvier 2017 Auteur Share Posté(e) 31 janvier 2017 Réservé Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
