johndoe Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 (modifié) source : http://www.modaco.com j'viens de test sans wipe sur le galaxy et voila :D merci a paul encore une fois pour ses roms customs I'm pleased to present my MoDaCo Custom ROM for the Samsung i7500!This ROM is based on the Samsung XXIH8 release, the latest at the time of writing, together with my own optimisations for the best possible performance! I have tried to keep the ROM as 'stock' feeling as possible. My key motivation for creating this ROM was firstly to enable root but secondly to provide a custom kernel with swap support, due to the limited RAM on the Galaxy. Features - Rooted with 'adb remount' permission and superuser APK - Custom kernel based on Samsung source with swap enabled (install 'swapper' from the market, I recommend a SD swap partition), netfilter enabled (working on wifi tether fix), cramfs + squashfs and much much more - Latest build of busybox included with relevant links, also other utils such as sqlite and parted in ROM. - Added terminfo and settings to boot.img - Deleted Maps application - install from the Android Market to always stay up to date - Removed files wasting space in system directory Download link: http://content.modaco.net/i7500/1.1-update...mrom-signed.zip ENSURE YOU DO A NANDROID BACKUP SO YOU CAN 'ROLL BACK' IF REQUIRED! This ROM includes the XXIH8 radio, but I am not 100% sure whether the script is installing it properly (I was already on XXIH8 radio)... any feedback would be appreciated. The ROM is in an update.zip format for installation via the custom recovery image. For the complete newbies, these are the steps you need to take with a 'virgin' i7500: - Download the patched recovery image linked above and install as detailed in that post - Download this custom ROM, and copy it to the '/sdcard' directory on the phone (actually the internal 8GB) - Enter the recovery image (if you're not in it already) by pressing and holding 'Volume Down', then 'Green' then 'Red' - Select 'nandroid backup' from the menu to do a backup - If you copied the custom rom as update.zip, select 'apply sdcard:update.zip', else select the option below. - all done Feedback / feature requests welcome! smile.gif Finally, if you like the MoDaCo Custom ROMs, consider supporting MoDaCo by visiting the subscriptions page and upgrading your account. P Modifié 22 septembre 2009 par johndoe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 22 septembre 2009 Auteur Share Posté(e) 22 septembre 2009 Changelog1.1 Fixed module versions (wifi issue resolved) 1.0 Initial Release Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 22 septembre 2009 Auteur Share Posté(e) 22 septembre 2009 j'ai remonter le probleme du market, il a mis le fingerprint en 83 au lieu de 12 comme d'hab :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bertrand Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 Bonjour, je n'étais pas encore tenté par les custom firmware mais ca fait maintenant 15 jours que j'ai le tel et j'ai envie d'un coup de boost car je le trouve un peu mou. Ce firmware apporte t'il vraiment un gain significatif ? Merci pour vos retours d'XP Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franckinou Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 johndoe : alors ? c'est mieux ? ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Anaethelion Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 (modifié) Oui oui c'est mieux, mais y'a plein d'optimisations qui n'en sont pas, et son idée du swap est assez contraignante. Néanmoins si on fait les choses dans l'ordre ça booste pas mal le téléphone oui, mais rien que d'autre n'ont déjà programmé de release... (hum xD) Et sinon c'est juste une rom de base, y'a rien de transcendant. Modifié 22 septembre 2009 par Anaethelion Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akex Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 Disons que c'est une bonne base. Mais la rom de Drakaz est déjà un niveau au dessus ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gils Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 @akek Drakaz au dessus de Modaco? Huh t'as des photos pour annoncé des rumeurs comme ça ? Hum !!! lol Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 22 septembre 2009 Auteur Share Posté(e) 22 septembre 2009 (modifié) Oui oui c'est mieux, mais y'a plein d'optimisations qui n'en sont pas, et son idée du swap est assez contraignante. le swap n'est pas obligatoire vu qu'il necessite swapper simplement quand j'vois comment tourne mon hero avec les roms modaco et les galere que samsung produit pour update j'prefere tout basculer sur du concret de plus contrairement a la rom "officielle" avec odin j'ai pas eu a wipe la j'vous ferais des retours d'utilisation ce soir vu que j'peux enfin adb sous seven avec :D Modifié 22 septembre 2009 par johndoe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akex Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 @akekDrakaz au dessus de Modaco? Huh t'as des photos pour annoncé des rumeurs comme ça ? Hum !!! lol Je ne vois pas en quoi des photos apporteraient une preuve. En revanche, la Rom de drakaz a déjà été plus testée que celle de Modaco ... C'est un fait ... Suffit de regarder les dates ... Pour les améliorations apportées par Modaco, je ne constate pas de réelles amélioration par rapport à ma H7 stock. Autre chose, modaco propose le recovery.img de Drakaz en direct link sur leur site ... Est-ce normal ? Je n'ai vu aucune mention du nom de Drakaz dans le post concerné ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
drakaz Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 (modifié) Pas de pb pour moi Modifié 22 septembre 2009 par drakaz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
akex Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 oui j'ai vu, mais bon sait-on jamais ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nhova Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 @akekDrakaz au dessus de Modaco? Huh t'as des photos pour annoncé des rumeurs comme ça ? Hum !!! lol Je ne vois pas en quoi des photos apporteraient une preuve. . Je crois que c'était un calembourd à caractère sessuelle :o :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Anaethelion Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 (modifié) Moi je ne peux que plussoyer, même si j'ai toujours pas mit la main sur la nouvelle build de drakaz je sais déjà qu'elle a comment dire...un je ne sais quoi de fonctionnalités en plus. :P Oui oui c'est mieux, mais y'a plein d'optimisations qui n'en sont pas, et son idée du swap est assez contraignante. le swap n'est pas obligatoire vu qu'il necessite swapper simplement quand j'vois comment tourne mon hero avec les roms modaco et les galere que samsung produit pour update j'prefere tout basculer sur du concret de plus contrairement a la rom "officielle" avec odin j'ai pas eu a wipe la j'vous ferais des retours d'utilisation ce soir vu que j'peux enfin adb sous seven avec :D Je vois pas où tu veux en venir, et non y'a pas forcément besoin de swapper, si on a une partition swap d'origine le kernel la prends en compte, mais c'est pour tout les autres qui n'ont pas de partition et qui ne savent pas la faire, que ça va devenir drôle. Et le swap c'est pas obligatoire mais c'est quand même un gros plus sur le galaxy. Modifié 22 septembre 2009 par Anaethelion Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 22 septembre 2009 Auteur Share Posté(e) 22 septembre 2009 disons surtout que j'irais tjrs du coté du plus simple sur le galaxy de ma copine si drakaz sort du mieux et que j'ai pas a galerer j'y passerait direct le probleme est surtout que j'ai pas envie de wipe/restore a chaque fois :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Makime Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 Drakaz avais parler de faire la swape sur la SD interne. Apres j'ai pas suivi l'histoire donc je ne sais pas ou cela en ai. La ROM de Modaco, ah une Swape sur la interne ? la Externe ? je comprend pas trop ce que vous racontez la dessus :\ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Anaethelion Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 La rom de modaco propose d'utiliser swapper qui est une app dispo sur le market qui permet divers trucs niveau swap. Elle permet d'utiliser une partition de swap ou encore d'utiliser un fichier de swap (par défaut) et donc de créer un swap sur la mémoire interne du galaxy, mais moi je trouve ça assez crade. Sans compter que ma carte mémoire va plus vite que la mémoire interne donc j'ai tout intérêt à utiliser la carte. Après chacun sa religion et ses prefs. Pour le petit détail, si vous utiliser swapper et voulez utiliser une partition swap sur la SD externe c'est /dev/block/mmcblk1px ou x est le numéro de votre partition partant de 1. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gils Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 @Nhova :D @autres... Je pensais que la carte interne était plus rapide qu'une SD ext en général (Sauf peut être la sd à 50€ le GO) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Anaethelion Posté(e) 22 septembre 2009 Share Posté(e) 22 septembre 2009 A 50 € ? Pas besoin d'aller si loin pour trouver mieux que la mémoire interne du téléphone, la première classe 6 8 go a 25-30 € fait du 6-7 Mo/s contre du 3-4 pour la mémoire interne du galaxy. La mémoire interne du galaxy c'est au mieux du classe 2 en sdcard. Après effectivement y'a les classe 10 de 10Mo/s et plus mais on en trouve pas beaucoup même si elles sont pas si chères. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 13 octobre 2009 Auteur Share Posté(e) 13 octobre 2009 (modifié) la rom 1.2 est dispo http://content.modaco.net/i7500/1.2-update-i7500-modacocustomrom-signed.zip Features- Rooted with 'adb remount' permission and superuser APK - Custom kernel based on Samsung source with swap enabled (install 'swapper' from the market, I recommend a SD swap partition), netfilter enabled (working on wifi tether fix), cramfs + squashfs and much much more - Latest build of busybox included with relevant links, also other utils such as sqlite and parted in ROM. - Added terminfo and settings to boot.img - Added JBed Java - Removed files wasting space in system directory 1.2 Added Java Based on XXII5 Updated Busybox + utils New kernel et voila installé sans wipe je sais beaucoup diront que les roms de drakaz sont plus complete mais ça suffira a ma copine pour le moment Modifié 13 octobre 2009 par johndoe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cikatrice Posté(e) 13 octobre 2009 Share Posté(e) 13 octobre 2009 moi je vais rester fidèle à drakaz :D c'est lui qu'a la plus grosse rom de toute la galaxy i7500, c'est connu :o (petite dédicace à Gils pour son humour incompris :p) ça aura pas duré longtemps en tout cas l'aventure des roms Modaco sur le galaxy dit donc, il arrête déjà :o Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gils Posté(e) 13 octobre 2009 Share Posté(e) 13 octobre 2009 Pas si incompris que ça... et hop un petit +1 pour la cassdedi !!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
