Casio Posté(e) 15 janvier 2018 Share Posté(e) 15 janvier 2018 Salutations, Je suis en train de désinstaller certains bloatwares sur un HTC (Beuark...), et je me demandais ce que voulait dire les options de la commande ADB Shell Uninstall ? pm uninstall -k --user 0 <MonPackagePourri> -k : Ca doit vouloir dire "Keep" la cache ou un truc du genre... --user 0 : Utilisateur 0 ? Merci de votre aide... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Casio Posté(e) 15 janvier 2018 Auteur Share Posté(e) 15 janvier 2018 J'ai trouvé : Citation usage: pm list packages [-f] [-d] [-e] [-s] [-3] [-i] [-u] [--user USER_ID] [FILTER] pm list permission-groups pm list permissions [-g] [-f] [-d] [-u] [GROUP] pm list instrumentation [-f] [TARGET-PACKAGE] pm list features pm list libraries pm list users pm path PACKAGE pm dump PACKAGE pm install [-lrtsfd] [-i PACKAGE] [--user USER_ID] [PATH] pm install-create [-lrtsfdp] [-i PACKAGE] [-S BYTES] [--install-location 0/1/2] [--force-uuid internal|UUID] pm install-write [-S BYTES] SESSION_ID SPLIT_NAME [PATH] pm install-commit SESSION_ID pm install-abandon SESSION_ID pm uninstall [-k] [--user USER_ID] PACKAGE pm set-installer PACKAGE INSTALLER pm move-package PACKAGE [internal|UUID] pm move-primary-storage [internal|UUID] pm clear [--user USER_ID] PACKAGE pm enable [--user USER_ID] PACKAGE_OR_COMPONENT pm disable [--user USER_ID] PACKAGE_OR_COMPONENT pm disable-user [--user USER_ID] PACKAGE_OR_COMPONENT pm disable-until-used [--user USER_ID] PACKAGE_OR_COMPONENT pm hide [--user USER_ID] PACKAGE_OR_COMPONENT pm unhide [--user USER_ID] PACKAGE_OR_COMPONENT pm grant [--user USER_ID] PACKAGE PERMISSION pm revoke [--user USER_ID] PACKAGE PERMISSION pm reset-permissions pm set-app-link [--user USER_ID] PACKAGE {always|ask|never|undefined} pm get-app-link [--user USER_ID] PACKAGE pm set-install-location [0/auto] [1/internal] [2/external] pm get-install-location pm set-permission-enforced PERMISSION [true|false] pm trim-caches DESIRED_FREE_SPACE [internal|UUID] pm create-user [--profileOf USER_ID] [--managed] USER_NAME pm remove-user USER_ID pm get-max-users pm list packages: prints all packages, optionally only those whose package name contains the text in FILTER. Options: -f: see their associated file. -d: filter to only show disbled packages. -e: filter to only show enabled packages. -s: filter to only show system packages. -3: filter to only show third party packages. -i: see the installer for the packages. -u: also include uninstalled packages. pm list permission-groups: prints all known permission groups. pm list permissions: prints all known permissions, optionally only those in GROUP. Options: -g: organize by group. -f: print all information. -s: short summary. -d: only list dangerous permissions. -u: list only the permissions users will see. pm list instrumentation: use to list all test packages; optionally supply <TARGET-PACKAGE> to list the test packages for a particular application. Options: -f: list the .apk file for the test package. pm list features: prints all features of the system. pm list users: prints all users on the system. pm path: print the path to the .apk of the given PACKAGE. pm dump: print system state associated with the given PACKAGE. pm install: install a single legacy package pm install-create: create an install session -l: forward lock application -r: replace existing application -t: allow test packages -i: specify the installer package name -s: install application on sdcard -f: install application on internal flash -d: allow version code downgrade -p: partial application install -g: grant all runtime permissions -S: size in bytes of entire session pm install-write: write a package into existing session; path may be '-' to read from stdin -S: size in bytes of package, required for stdin pm install-commit: perform install of fully staged session pm install-abandon: abandon session pm set-installer: set installer package name pm uninstall: removes a package from the system. Options: -k: keep the data and cache directories around after package removal. pm clear: deletes all data associated with a package. pm enable, disable, disable-user, disable-until-used: these commands change the enabled state of a given package or component (written as "package/class"). pm grant, revoke: these commands either grant or revoke permissions to apps. The permissions must be declared as used in the app's manifest, be runtime permissions (protection level dangerous), and the app targeting SDK greater than Lollipop MR1. pm reset-permissions: revert all runtime permissions to their default state. pm get-install-location: returns the current install location. 0 [auto]: Let system decide the best location 1 [internal]: Install on internal device storage 2 [external]: Install on external media pm set-install-location: changes the default install location. NOTE: this is only intended for debugging; using this can cause applications to break and other undersireable behavior. 0 [auto]: Let system decide the best location 1 [internal]: Install on internal device storage 2 [external]: Install on external media pm trim-caches: trim cache files to reach the given free space. pm create-user: create a new user with the given USER_NAME, printing the new user identifier of the user. pm remove-user: remove the user with the given USER_IDENTIFIER, deleting all data associated with that user Merci ;-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
