moritan Posté(e) 20 octobre 2010 Share Posté(e) 20 octobre 2010 Bonjour. Dans mon code, j'utilise un ImageGetter pour récupérer des images pour ensuite les afficher dans un TextView. Html.fromHtml(bbcode(description), new ImageGetter() { return Html.fromHtml(bbcode(description), new ImageGetter() { final static String CACHE_DIR = "/sdcard/DIC/image_cache/"; @Override public Drawable getDrawable(String url) { try { // get name of image String name = url.substring(url.lastIndexOf("/") + 1); File f = new File(CACHE_DIR + name + ".png"); if (!f.exists()) downloadImage(url, f); Drawable d = Drawable.createFromPath(f.getAbsolutePath()); if (d != null) d.setBounds(0, 0, 150, 150);// make it the size of the // image return d; } catch (Exception e) { e.printStackTrace(); } return null; } private void downloadImage(String url, File f) throws IOException { // createParent(f); URL myFileUrl = new URL(url); HttpURLConnection conn = (HttpURLConnection) myFileUrl .openConnection(); conn.setDoInput(true); conn.connect(); InputStream is = conn.getInputStream(); Bitmap bm = BitmapFactory.decodeStream(is); f.getParentFile().mkdirs(); f.createNewFile(); FileOutputStream out = new FileOutputStream(f); bm.compress(Bitmap.CompressFormat.PNG, 90, out); out.flush(); out.close(); } }, null); } Le problème c'est que à chaque fois que mon code réagit à une image, j'ai un FC sur Appoke. 10-20 11:43:57.180: ERROR/AndroidRuntime(3355): Uncaught handler: thread main exiting due to uncaught exception 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): java.lang.NullPointerException 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at com.appoke.store.imageloader.c.a(ImageLoader.java:173) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at com.appoke.store.services.AppokeService.onLowMemory(AppokeService.java:164) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at android.app.ActivityThread.handleLowMemory(ActivityThread.java:3716) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1877) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at android.os.Handler.dispatchMessage(Handler.java:99) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at android.os.Looper.loop(Looper.java:123) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at android.app.ActivityThread.main(ActivityThread.java:4203) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at java.lang.reflect.Method.invokeNative(Native Method) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at java.lang.reflect.Method.invoke(Method.java:521) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:791) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:549) 10-20 11:43:57.420: ERROR/AndroidRuntime(3355): at dalvik.system.NativeStart.main(Native Method) Est-ce lié a mon code, à Appoke ou aux lutins voleurs de slip ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
guerwan Posté(e) 20 octobre 2010 Share Posté(e) 20 octobre 2010 Bonjour, Merci pour l'info sur le plantage d'Appoke ;) Le Nullpointer vient bien de l'application Appoke, ça sera corrigé dans la prochaine version. Par contre tu dois utiliser beaucoup de mémoire dans ton code, parce que Appoke passe dans la méthode onLowMemory qui est appelée quand le système a besoin de mémoire. Lien vers le commentaire Partager sur d’autres sites More sharing options...
moritan Posté(e) 20 octobre 2010 Auteur Share Posté(e) 20 octobre 2010 Effectivement j'ai constaté aussi ce message quand je fais d'autres actions sur mon tel comme ouvrir le navigateur ou envoyer un SMS. La mémoire en carton de mon Magic commence à être sérieusement limite, surtout que je ne fait que réduire une image. Lien vers le commentaire Partager sur d’autres sites More sharing options...
