Bug de programmation, sur android studio
je ne suis pas sur d'etre sur le bon forum
J'ai un message d'erreur lors du lancement de l'émulateur. je travail sur Android studio.
voici le message,
E/AndroidRuntime: FATAL EXCEPTION: main
    Process: xxxxx.fr.bouxxxxxteur, PID: 22717
    java.lang.RuntimeException: Unable to start activity ComponentInfo{xxxx.fr.bouxxxxxxteur/xxxx.fr.bouxxxxxteur.MainActivity}: java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2913)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3048)
        at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:78)
        at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:108)
        at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:68)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1808)
        at android.os.Handler.dispatchMessage(Handler.java:106)
        at android.os.Looper.loop(Looper.java:193)
        at android.app.ActivityThread.main(ActivityThread.java:6669)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
     Caused by: java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
        at java.util.ArrayList.get(ArrayList.java:437)
        at roumezin.fr.boucheriesimulateur.outils.Minuterie.chargeDate(Minuterie.kt:25)
        at roumezin.fr.boucheriesimulateur.MainActivity.onCreate(MainActivity.kt:48)
        at android.app.Activity.performCreate(Activity.java:7136)
        at android.app.Activity.performCreate(Activity.java:7127)
        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1271)
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2893)
Merci a vous de votre aide
Manu
