Connexion serveur Mysql
Bonsoir à tous!
Lorsque j'inclus le fichier .jar du connector permettant d'établir une liaison avec le serveur Mysql, j'ai pleins de message d'erreurs:
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dx.util.ExceptionWithContext
[2010-11-13 18:59:17 - 2] at com.android.dx.util.ExceptionWithContext.withContext(ExceptionWithContext.java:46)
[2010-11-13 18:59:17 - 2] at com.android.dx.dex.cf.CfTranslator.processMethods(CfTranslator.java:340)
[2010-11-13 18:59:17 - 2] at com.android.dx.dex.cf.CfTranslator.translate0(CfTranslator.java:131)
[2010-11-13 18:59:17 - 2] at com.android.dx.dex.cf.CfTranslator.translate(CfTranslator.java:85)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main.processClass(Main.java:299)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main.processFileBytes(Main.java:278)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main.access$100(Main.java:56)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main$1.processFileBytes(Main.java:229)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:244)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:130)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:108)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main.processOne(Main.java:247)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main.processAllFiles(Main.java:183)
[2010-11-13 18:59:17 - 2] at com.android.dx.command.dexer.Main.run(Main.java:139)
[2010-11-13 18:59:17 - 2] at sun.reflect.GeneratedMethodAccessor11.invoke(Unknown Source)
[2010-11-13 18:59:17 - 2] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[2010-11-13 18:59:17 - 2] at java.lang.reflect.Method.invoke(Method.java:616)
[2010-11-13 18:59:17 - 2] at com.android.ide.eclipse.adt.internal.sdk.DexWrapper.run(Unknown Source)
[2010-11-13 18:59:17 - 2] at com.android.ide.eclipse.adt.internal.build.PostCompilerHelper.executeDx(Unknown Source)
[2010-11-13 18:59:17 - 2] at com.android.ide.eclipse.adt.internal.build.PostCompilerBuilder.build(Unknown Source)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:627)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:309)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:341)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:238)
[2010-11-13 18:59:17 - 2] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
[2010-11-13 18:59:17 - 2] Caused by: java.lang.NullPointerException
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper$SubroutineInliner.involvedInSubroutine(Ropper.java:1509)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper$SubroutineInliner.mapOrAllocateLabel(Ropper.java:1530)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper$SubroutineInliner.copyBlock(Ropper.java:1448)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper$SubroutineInliner.inlineSubroutineCalledFrom(Ropper.java:1404)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper.inlineSubroutines(Ropper.java:1278)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper.doit(Ropper.java:646)
[2010-11-13 18:59:17 - 2] at com.android.dx.cf.code.Ropper.convert(Ropper.java:250)
[2010-11-13 18:59:17 - 2] at com.android.dx.dex.cf.CfTranslator.processMethods(CfTranslator.java:252)
[2010-11-13 18:59:17 - 2] ... 30 more
...while processing reuseAndReadPacket (Lcom/mysql/jdbc/Buffer;I)Lcom/mysql/jdbc/Buffer;
...while processing com/mysql/jdbc/MysqlIO.class
[2010-11-13 18:59:17 - 2] 1 error; aborting
[2010-11-13 18:59:17 - 2] Conversion to Dalvik format failed with error 1
Merci de votre aide!
