[TUTORIAL] Création/modification de thèmes pour le X10 - màj 17/12/10
  • Réponses 52
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Sans avoir touché aux fichier xml il me met plein d'erreur avec les fichier xml >.>
MAJ : Tain sa me soule, sa vient d'où cette erreur ? J'ai juste modifier les images dans mon framework >.<
/home/mathieu/out/./res/values/public.xml:3129: error: Public symbol drawable/tab_indicator declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3130: error: Public symbol drawable/tab_indicator_v4 declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4167: error: Public symbol drawable/tab_press declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4168: error: Public symbol drawable/tab_press_bar_left declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4169: error: Public symbol drawable/tab_press_bar_right declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4170: error: Public symbol drawable/tab_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4171: error: Public symbol drawable/tab_selected_bar_left declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4172: error: Public symbol drawable/tab_selected_bar_left_v4 declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4173: error: Public symbol drawable/tab_selected_bar_right declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4174: error: Public symbol drawable/tab_selected_bar_right_v4 declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4175: error: Public symbol drawable/tab_selected_v4 declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4176: error: Public symbol drawable/tab_unselected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4177: error: Public symbol drawable/tab_unselected_v4 declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4178: error: Public symbol drawable/textfield_default declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4179: error: Public symbol drawable/textfield_disabled declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4180: error: Public symbol drawable/textfield_disabled_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4181: error: Public symbol drawable/textfield_pressed declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3131: error: Public symbol drawable/textfield_search declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4182: error: Public symbol drawable/textfield_search_default declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4183: error: Public symbol drawable/textfield_search_pressed declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4184: error: Public symbol drawable/textfield_search_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4185: error: Public symbol drawable/textfield_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3132: error: Public symbol drawable/timepicker_down_btn declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4186: error: Public symbol drawable/timepicker_down_disabled declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4187: error: Public symbol drawable/timepicker_down_disabled_focused declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4188: error: Public symbol drawable/timepicker_down_normal declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4189: error: Public symbol drawable/timepicker_down_pressed declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4190: error: Public symbol drawable/timepicker_down_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3133: error: Public symbol drawable/timepicker_input declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4191: error: Public symbol drawable/timepicker_input_disabled declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4192: error: Public symbol drawable/timepicker_input_normal declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4193: error: Public symbol drawable/timepicker_input_pressed declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4194: error: Public symbol drawable/timepicker_input_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3134: error: Public symbol drawable/timepicker_up_btn declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4195: error: Public symbol drawable/timepicker_up_disabled declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4196: error: Public symbol drawable/timepicker_up_disabled_focused declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4197: error: Public symbol drawable/timepicker_up_normal declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4198: error: Public symbol drawable/timepicker_up_pressed declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4199: error: Public symbol drawable/timepicker_up_selected declared here is not defined.
/home/mathieu/out/./res/values/public.xml:2992: error: Public symbol drawable/title_bar declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4200: error: Public symbol drawable/title_bar_medium declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4201: error: Public symbol drawable/title_bar_portrait declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4202: error: Public symbol drawable/title_bar_shadow declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3269: error: Public symbol drawable/title_bar_tall declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3258: error: Public symbol drawable/toast_frame declared here is not defined.
/home/mathieu/out/./res/values/public.xml:4203: error: Public symbol drawable/unknown_image declared here is not defined.
/home/mathieu/out/./res/values/public.xml:3259: error: Public symbol drawable/zoom_plate declared here is not defined.
Si quelqu'un à la motive de me le compiler =333
Voilà l'archive qui contient le framework et le dossier res avec les images modifié.
Modifié par freedent
Je vais tester ce soir, mais en faites j'ai modifié mes images afin d'avoir un thème rose. Là il me reste juste à recompiler mon application.
OUlala j'avais demandé ta question de recompiler un apk à frandroid personne ne m'a répondu.
Il te faut un convertisseur.
la 1ere manipulation est de décompresser et c'est est facile car un apk est un zip (modifié apk par zip). Ensuite si tu modifies il faut signer et recompiler.
Il y a des outils sur xda mais il ne fonctionne pas ou beug
Voilà freedent :
j'avais le meme probleme que toi en décembre 2010 mais j'ai pas eu de réponse ici (d'ailleur je ne pense pas que tu trouveras faudra te débrouiller comme moi : seul lol)
Bon le prochain c'est qui ? Hollywood ?
1er Malabar
2eme freedent
3eme ????? Hollywood ??
Boulboul ton liens ne fonctionne pas =(
Puis [color=red][b]sa[/b][/color] m'avance pas trop =(
Il faut que je modifie un fichier xml ? Mais pourquoi faire alors, j'ai juste modifier les images existante sans modifier leur format
Alors, docteur malabarth arrive!!
tatatatatata, roulement de tambour.... tatatatatatata
Il te manque ces images, elles ont des extensions en .9.png, tu parie qu'elles n'ont plus le .9? :D
Si elles l'ont, alors je retourne ma veste, et repart bosser mon Data2SD!!! :P
Hihi merci, un noob à réussi à avoir un pro, mais c'est bon ça =P
Heu sinon il y a d'un côté l'apk d'origine et de l'autre le dossier avec les images modifier.
J'ai modifié les images de trois dossier, un qui contenait 5/6 images , le deuxième avait sensiblement les même images. Et enfin le troisième qui avait la totale en image, une bonne centaine.
Finalement ce thème bleu est parfait =3
Il y a tellement d'images que le terminale ne peu tous m'afficher xDD
Dommage j'avais pas viré les trais noir ='(
Merci quand même ^^'
Bon j'essaye déjà de faire un simple copier collé dans draw9patch mais sa pas l'air d'être gagner >.>
Le pire, c'est que quand je compar l'image originale et la mienne il y a juste la couleur qui change =X
Et même le noir est bien noir, il a bien la valeur html 00000
Alors copié collé comment que l'on fait xD
EDIT : Malabarth je t'aime !!!!
Enfin j'ai juste essayé avec deux trois images sa fonctionne, bref je ouvre mes images modifié et je les enregistres avec draw9patch et sa fonctionne.
Heu à mon avis il y a pas que les images .9.png qui sont la cause de toute ces erreurs... les png aussi =(
Mais bon sa avance je fais le tris ^^
Je conseille cette video / tuto pour compiler et décompiler
Heu au passage Malabarth, dis moi si sa technique est bonne, parce que son framework d'environ 10 Mo retombe à 5 Mo lui aussi. Normale ou pas ?
MAJ : mouai, j'ai signé mon application après l'avoir compilé et sa nefonctionne pas, je suis sûr qu'il manque une étape >.>
Help :'O
Finalement je m'en suis sortie, suffit de renomer son apk d'origine en .zip modifier les fichier remettre en .apk et un petit coup ./zipalign -v 4 ... et le tour est joué
  • 5 weeks later...
Bonsoir, désolé de reprendre ce sujet maintenant mais comment fait-on pour recompiler car lorque j'exécute le build, sa me met plein de message d'erreur.
Malgré les questions dans ce topic, je n'ai toujours pas compris.
Pouvez-vous m'expliquez s'il vous plait merci.
Message d'erreur:
s\public.xml:3739: error: Public symbol drawable/tab_selected_bar_right_v4 decla
C:\Users\Catherine et Dimitri\VRAI ROM FRAMEWORK\working\framework-res\res\value
s\public.xml:3740: error: Public symbol drawable/tab_selected_v4 declared here i
s not defined.
s\public.xml:3741: error: Public symbol drawable/tab_unselected declared here is
not defined.
s\public.xml:3742: error: Public symbol drawable/tab_unselected_v4 declared here
is not defined.
s\public.xml:3743: error: Public symbol drawable/textfield_default declared here
is not defined.
s\public.xml:3744: error: Public symbol drawable/textfield_disabled declared her
e is not defined.
s\public.xml:3745: error: Public symbol drawable/textfield_disabled_selected dec
s\public.xml:3746: error: Public symbol drawable/textfield_pressed declared here
is not defined.
s\public.xml:2924: error: Public symbol drawable/textfield_search declared here
is not defined.
s\public.xml:3747: error: Public symbol drawable/textfield_search_default declar
s\public.xml:2925: error: Public symbol drawable/textfield_search_empty declared
s\public.xml:3748: error: Public symbol drawable/textfield_search_empty_default
s\public.xml:3749: error: Public symbol drawable/textfield_search_empty_pressed
s\public.xml:3750: error: Public symbol drawable/textfield_search_empty_selected
s\public.xml:3751: error: Public symbol drawable/textfield_search_pressed declar
s\public.xml:3752: error: Public symbol drawable/textfield_search_selected decla
s\public.xml:3753: error: Public symbol drawable/textfield_selected declared her
e is not defined.
s\public.xml:2926: error: Public symbol drawable/timepicker_down_btn declared he
re is not defined.
s\public.xml:3754: error: Public symbol drawable/timepicker_down_disabled declar
s\public.xml:3755: error: Public symbol drawable/timepicker_down_disabled_focuse
s\public.xml:3756: error: Public symbol drawable/timepicker_down_normal declared
s\public.xml:3757: error: Public symbol drawable/timepicker_down_pressed declare
s\public.xml:3758: error: Public symbol drawable/timepicker_down_selected declar
s\public.xml:2927: error: Public symbol drawable/timepicker_input declared here
is not defined.
s\public.xml:3759: error: Public symbol drawable/timepicker_input_disabled decla
s\public.xml:3760: error: Public symbol drawable/timepicker_input_normal declare
s\public.xml:3761: error: Public symbol drawable/timepicker_input_pressed declar
s\public.xml:3762: error: Public symbol drawable/timepicker_input_selected decla
s\public.xml:2928: error: Public symbol drawable/timepicker_up_btn declared here
is not defined.
s\public.xml:3763: error: Public symbol drawable/timepicker_up_disabled declared
s\public.xml:3764: error: Public symbol drawable/timepicker_up_disabled_focused
s\public.xml:3765: error: Public symbol drawable/timepicker_up_normal declared h
ere is not defined.
s\public.xml:3766: error: Public symbol drawable/timepicker_up_pressed declared
s\public.xml:3767: error: Public symbol drawable/timepicker_up_selected declared
s\public.xml:2779: error: Public symbol drawable/title_bar declared here is not
defined.
s\public.xml:3768: error: Public symbol drawable/title_bar_medium declared here
is not defined.
s\public.xml:3769: error: Public symbol drawable/title_bar_portrait declared her
e is not defined.
s\public.xml:3770: error: Public symbol drawable/title_bar_shadow declared here
is not defined.
s\public.xml:3129: error: Public symbol drawable/title_bar_tall declared here is
not defined.
s\public.xml:3119: error: Public symbol drawable/toast_frame declared here is no
t defined.
s\public.xml:3771: error: Public symbol drawable/unknown_image declared here is
not defined.
s\public.xml:3772: error: Public symbol drawable/usb_android declared here is no
t defined.
s\public.xml:3773: error: Public symbol drawable/usb_android_connected declared
s\public.xml:3120: error: Public symbol drawable/zoom_plate declared here is not
defined.
s\public.xml:3774: error: Public symbol drawable/zz_ic_dialog_simcard declared h
ere is not defined.
s\public.xml:2929: error: Public symbol drawable/zz_moto_batt_temp_alert_dialog_
icon declared here is not defined.
s\public.xml:2930: error: Public symbol drawable/zz_moto_batt_temp_ok_dialog_ico
s\public.xml:2931: error: Public symbol drawable/zz_moto_btn_delete declared her
e is not defined.
s\public.xml:2932: error: Public symbol drawable/zz_moto_btn_delete_focus declar
s\public.xml:2933: error: Public symbol drawable/zz_moto_btn_delete_normal decla
s\public.xml:2934: error: Public symbol drawable/zz_moto_btn_delete_normal_disab
le declared here is not defined.
s\public.xml:2935: error: Public symbol drawable/zz_moto_btn_delete_normal_disab
le_focused declared here is not defined.
s\public.xml:2936: error: Public symbol drawable/zz_moto_btn_delete_pressed decl
s\public.xml:2937: error: Public symbol drawable/zz_moto_btn_delete_selected dec
s\public.xml:2938: error: Public symbol drawable/zz_moto_btn_keypad declared her
e is not defined.
s\public.xml:2939: error: Public symbol drawable/zz_moto_cursor_halo declared he
re is not defined.
s\public.xml:2940: error: Public symbol drawable/zz_moto_dialpad_bg declared her
e is not defined.
s\public.xml:2941: error: Public symbol drawable/zz_moto_dialpad_divider_h decla
s\public.xml:2942: error: Public symbol drawable/zz_moto_dialpad_divider_v decla
s\public.xml:2943: error: Public symbol drawable/zz_moto_dialpad_highlight decla
s\public.xml:2944: error: Public symbol drawable/zz_moto_dialpad_normal declared
s\public.xml:2962: error: Public symbol drawable/zz_moto_ic_btn_next declared he
re is not defined.
s\public.xml:2965: error: Public symbol drawable/zz_moto_ic_control_clear declar
s\public.xml:2966: error: Public symbol drawable/zz_moto_ic_control_enter declar
s\public.xml:2967: error: Public symbol drawable/zz_moto_ic_control_remove decla
s\public.xml:2968: error: Public symbol drawable/zz_moto_ic_control_retry declar
s\public.xml:2969: error: Public symbol drawable/zz_moto_ic_dialog_batt_temp_cou
ntdown declared here is not defined.
s\public.xml:2970: error: Public symbol drawable/zz_moto_ic_list_reorder declare
s\public.xml:2972: error: Public symbol drawable/zz_moto_jog_tab_bar_down_begin
s\public.xml:2973: error: Public symbol drawable/zz_moto_jog_tab_bar_down_end de
s\public.xml:2974: error: Public symbol drawable/zz_moto_jog_tab_bar_down_mute_b
egin declared here is not defined.
s\public.xml:2975: error: Public symbol drawable/zz_moto_jog_tab_bar_down_vibe_b
s\public.xml:2976: error: Public symbol drawable/zz_moto_jog_tab_bar_left_begin
s\public.xml:2977: error: Public symbol drawable/zz_moto_jog_tab_bar_left_end de
s\public.xml:2978: error: Public symbol drawable/zz_moto_jog_tab_bar_right_begin
s\public.xml:2979: error: Public symbol drawable/zz_moto_jog_tab_bar_right_end d
s\public.xml:2980: error: Public symbol drawable/zz_moto_jog_tab_bar_right_mute_
begin declared here is not defined.
s\public.xml:2981: error: Public symbol drawable/zz_moto_jog_tab_bar_right_vibe_
s\public.xml:2982: error: Public symbol drawable/zz_moto_jog_tab_bar_up_begin de
s\public.xml:2983: error: Public symbol drawable/zz_moto_jog_tab_bar_up_end decl
s\public.xml:2984: error: Public symbol drawable/zz_moto_jog_tab_bar_vibrate_dow
n_begin declared here is not defined.
s\public.xml:2985: error: Public symbol drawable/zz_moto_jog_tab_bar_vibrate_rig
ht_begin declared here is not defined.
s\public.xml:2986: error: Public symbol drawable/zz_moto_pin_unlock_background d
s\public.xml:2987: error: Public symbol drawable/zz_moto_slpressed declared here
is not defined.
s\public.xml:2988: error: Public symbol drawable/zz_moto_text_overlay_background
s\public.xml:3775: error: Public symbol drawable/zz_stat_sys_battery_5 declared
s\public.xml:3776: error: Public symbol drawable/zz_stat_sys_battery_charge_anim
6 declared here is not defined.
s\public.xml:3777: error: Public symbol drawable/zz_stat_sys_r_signal_5 declared
s\public.xml:3778: error: Public symbol drawable/zz_stat_sys_signal_5 declared h
ere is not defined.
s\public.xml:3779: error: Public symbol drawable/zz_stat_sys_signal_5_cdma decla
s\public.xml:3782: error: Public symbol drawable/zz_vzw_stat_sys_roaming_cdma_cu
stom3 declared here is not defined.
s\public.xml:2993: error: Public symbol drawable/zz_vzw_stat_sys_roaming_cdma_cu
stom3_flash declared here is not defined.
s\public.xml:3783: error: Public symbol drawable/zz_vzw_stat_sys_roaming_cdma_fl
ash_custom3_anim1 declared here is not defined.
Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutExce
ption: could not exec command: [aapt, p, -F, C:\Users\CATHER~1\AppData\Local\Tem
p\APKTOOL7920915133280000743.tmp, -x, -S, C:\Users\Catherine et Dimitri\VRAI ROM
FRAMEWORK\working\framework-res\res, -M, C:\Users\Catherine et Dimitri\VRAI ROM
FRAMEWORK\working\framework-res\AndroidManifest.xml]
       at brut.androlib.res.AndrolibResources.aaptPackage(Unknown Source)
       at brut.androlib.Androlib.buildResourcesFull(Unknown Source)
       at brut.androlib.Androlib.buildResources(Unknown Source)
       at brut.androlib.Androlib.build(Unknown Source)
       at brut.apktool.Main.cmdBuild(Unknown Source)
       at brut.apktool.Main.main(Unknown Source)
Caused by: brut.common.BrutException: could not exec command: [aapt, p, -F, C:\U
sers\CATHER~1\AppData\Local\Temp\APKTOOL7920915133280000743.tmp, -x, -S, C:\User
s\Catherine et Dimitri\VRAI ROM FRAMEWORK\working\framework-res\res, -M, C:\User
s\Catherine et Dimitri\VRAI ROM FRAMEWORK\working\framework-res\AndroidManifest.
xml]
       at brut.util.OS.exec(Unknown Source)
       ... 7 more
C:\Users\Catherine et Dimitri\VRAI ROM FRAMEWORK>pause
Appuyez sur une touche pour continuer...
Désolé pour le délai de réponse, je traine moins par ici car + de boulot et surtout... je suis passé au Desire :emo_im_angel:
Bref, si c'est toujours d'actualité: à priori ton problème ne me dit rien, mais visiblement tu as un problème avec l'exécution d'aapt.exe.
Je vois qu'il y a des espaces dans les noms de tes répertoires, essaye de travailler dans un répertoire à la racine de ton disque dur (avec un nom sans espace), on ne sait jamais.
Sinon, tu peux relancer ce post où l'auteur a eu le même genre de souci
Edit:
Il peut y avoir des soucis quand les identifiants de ressources ne sont pas standards, cf un post sur Xda et un commentaire du développeur d'apktool :
- Post Xda
- Commentaire du développeur
Modifié par Bartleby
  • 9 months later...
En cas de souci
Ce post regroupe des astuces au cas où votre téléphone ne booterait pas suite à un changement de thème (Si ça ne vous est jamais arrivé, c'est que vous n'avez pas bien essayé! :P )
Dans ce post::
Purquoi vous téléphone ne boote pas
- les images ne sont pas correctement stockées, leur format n'est pas le bon, pas la bonne taille, ..
- votre apk n'a pas été correctement décompressée ou recompressée
- vous avez signé l'apk avant de l'envoyer vers le téléphone - à moins que vous ne sachiez exactement ce que vous faites, suivez les instructions de ce topic et ça devrait foncitonner.
- vous avez envoyé l'apk au mauvais endroit
Si le téléphone reste bloqué sur le bootscreen, replacer votre sauveagrde du framework-res.apk sur le téléphone.
Petite question, comment faire pour remplacer la sauvegarde justement si on reste bloqué sur le bootscreen ?
adb devices ne me donne rien...
