Mise à jour Froyo 2.0.71
bgibout
Une mise à jour pour la gen8 est dispo sur le site d'Archos
Version 2.0.71 - December 16th, 2010
Wi-Fi: fix Wi-Fi stuck after a while when using WPA2/AES encryption mode
Wi-Fi: fix cannot connect on channels above 11 due to wrong default regulation domain
Power management: for A43/A70/A101 add a setting in about device to allow 3 levels of power management. Overdrive that allows CPU max frequency to be 1GHz with ondemand governor, optimal that brings CPU max frequency to 800MHz with ondemand governor and powersave that set CPU max frequency to 800MHz with conservative governor
Indexing: faster rescan is now achieved at USB disconnect
Storage: SDCard now supports NTFS (read only) and EXT3
Storage: fix sdcard not recognized sometimes when swapping different cards brands
Video: fix subtitles on A101
Network shares: enhance scanning speed
Network shares: handle the case where a server shares are not visible if not authenticated
Network shares: allow in wireless settings to define manually a server authentication details
Network shares: reload samba and UPnP services when switching between access points without disconnecting
Audio: a silent mode (Global Mute) has been enabled in the power button menu. It will impact all streams except alarms in case one select alarms sound always on in alarm settings
Application: appslib is now reinstalled after an Android device reset
Application: fix quadrant CPU benchmark
Power: fix shutdown sometimes happening on short power button press
Internationalization: support for Korean codepage tags and subtitles
Multimedia: use smaller memory footprint for decoding H264 SD
Memory management: achieve more progressive kill in low memory situation
Boot: fix deadlock happening sometimes preventing device to complete boot
J'ai sauté dessus dès que je l'ai vue.
Installée sans soucis très rapidement depuis la 2.0.54.
Les sous-titres marchent enfin. pour le reste, je n'ai pas encore eu le temps de voir de changement notable.
Réglage performance "overdrive", quadrant = 1647. Mieux que mon nexus one...
J'ai enfin la tablette sous froyo à 1GHz que j'ai acheté.
Moi content (enfin!)
A voir dans les prochains jours...
Modifié par Zerrac
