[How to] remplacer le bouton "personnaliser"
seandk
  • Réponses 59
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
ah ok lol, merci beaucoup !!! :D
Bon bah ça marche pas, j'ai fait ce qui est marquer, pour info j'ai ça dans mon cmd :
C:\>cd c:/androidsdk/tools
c:\androidSDK\tools>adb shell rm /system/app/Rosie.apk
adb server is out of date. killing...
* daemon started successfully *
c:\androidSDK\tools>adb push c:/androidsdk/tools/Rosie_market.apk
Android Debug Bridge version 1.0.26
-d - directs command to the only connected USB devic
e
returns an error if more than one USB device is
present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is r
unning.
-s <serial number> - directs command to the USB device or emulator w
ith
the given serial number. Overrides ANDROID_SERI
AL
environment variable.
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices - list all connected devices
connect <host>[:<port>] - connect to a device via TCP/IP
Port 5555 is used by default if no port number
is specified.
disconnect [<host>[:<port>]] - disconnect from a TCP/IP device.
is specified.
Using this ocmmand with no additional arguments
will disconnect from all connected TCP/IP devic
es.
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> [<local>] - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(-l means list but don't copy)
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] <file> - push this package file to the device and i
nstall it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data
('-s' means install on SD card instead of inter
nal storage)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories
adb bugreport - return all information from the device
that should be included in a bug report.
adb help - show this help message
adb version - show version num
DATAOPTS:
(no option) - don't touch the data partition
-w - wipe the data partition
-d - flash the data partition
scripting:
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-serialno - prints: <serial-number>
adb status-window - continuously print device status for a specifie
d device
adb remount - remounts the /system partition on the device re
ad-write
adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
tloader or recovery program
adb reboot-bootloader - reboots the device into the bootloader
adb root - restarts the adbd daemon with root permissions
adb usb - restarts the adbd daemon listening on USB
adb tcpip <port> - restarts the adbd daemon listening on TCP on th
e specified port
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PPP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be u
pdated.
- If it is "system" or "data", only the corresponding partition
is updated.
environmental variables:
ADB_TRACE - Print debug information. A comma separated list
of the following values
1 or all, adb, sockets, packets, rwx, usb, sync
, sysdeps, transport, jdwp
ANDROID_SERIAL - The serial number to connect to. -s takes prior
ity over this if given.
ANDROID_LOG_TAGS - When used with the logcat option, only these de
bug tags are printed.
et j'ai rallumé mon portable (je suis sous leedroid) et je n'ai plus sense, je suis sous l'autre home... Que dois-je faire?
PS: j'ai enlever la batterie mais rien non plus...
EDIT: C'est bon!, j'avais oublié un bout de la ligne de commande LOL ^^
Par contre, est ce que c'est normal que j'ai perdu mon bureau d'origine? Enfin je veux dire par la que je dois le re-personnaliser
Modifié par hadescedric
  • 4 weeks later...
  • 1 month later...
je suis sur Android Revolution HD 3.2
l'étape 5, parfait
l'étape 6 (puis : adb push [emplacement dossier tools]\Rosie_xxxxx.apk /system/app/Rosie.apk), l'invite de commande m'ouvre l'explorateur windows car il n'arrivait soit disant pas à lire le fichier "Rosie_contacts.apk"
mon erreur vient peut être de "[emplacement dossier tools]"... ne sachant pas trop j'ai mis "c:\android-sdk-windows\tools ce qui me semble le plus logique
-edit- je viens de refaire toutes les étapes, je viens de récupérer le launcher HTC d'origine (cool !), mais le bouton droit est inutilisable! en cliquant dessus, il ne se passe rien
Modifié par Arestas
