[ROM] [TUTO] Installer Cyanogenmod 7 pour HTC Desire HD
  • Réponses 1,6k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Name Last Modified Size Type
Parent Directory/ - Directory
cm_ace_full-1.zip 2011-Feb-19 11:17:02 80.8M application/zip
cm_ace_full-1.zip.md5sum.txt 2011-Feb-19 11:17:02 0.1K text/plain
cm_ace_full-11.zip 2011-Mar-02 00:02:19 82.3M application/zip
cm_ace_full-11.zip.md5sum.txt 2011-Mar-02 00:02:20 0.1K text/plain
cm_ace_full-12.zip 2011-Mar-02 18:38:05 82.3M application/zip
cm_ace_full-12.zip.md5sum.txt 2011-Mar-15 07:13:49 0.1K text/plain
cm_ace_full-13.zip 2011-Mar-06 21:54:41 82.9M application/zip
cm_ace_full-13.zip.md5sum.txt 2011-Mar-06 21:54:42 0.1K text/plain
cm_ace_full-14.zip 2011-Mar-07 22:37:46 82.9M application/zip
cm_ace_full-14.zip.md5sum.txt 2011-Mar-07 22:37:46 0.1K text/plain
cm_ace_full-15.zip 2011-Mar-08 22:00:52 83.0M application/zip
cm_ace_full-15.zip.md5sum.txt 2011-Mar-08 22:00:52 0.1K text/plain
cm_ace_full-17.zip 2011-Mar-11 18:52:09 83.0M application/zip
cm_ace_full-17.zip.md5sum.txt 2011-Mar-15 07:15:04 0.1K text/plain
cm_ace_full-18.zip 2011-Mar-12 21:56:22 83.0M application/zip
cm_ace_full-18.zip.md5sum.txt 2011-Mar-15 07:15:19 0.1K text/plain
cm_ace_full-19.zip 2011-Mar-15 07:02:37 83.0M application/zip
cm_ace_full-19.zip.md5sum.txt 2011-Mar-15 07:02:37 0.1K text/plain
cm_ace_full-2.zip 2011-Feb-19 20:02:54 80.9M application/zip
cm_ace_full-2.zip.md5sum.txt 2011-Feb-19 20:02:54 0.1K text/plain
cm_ace_full-20.zip 2011-Mar-15 22:00:21 83.0M application/zip
cm_ace_full-20.zip.md5sum.txt 2011-Mar-15 22:00:21 0.1K text/plain
cm_ace_full-21.zip 2011-Mar-16 00:03:19 83.0M application/zip
cm_ace_full-21.zip.md5sum.txt 2011-Mar-16 00:03:20 0.1K text/plain
cm_ace_full-22.zip 2011-Mar-16 22:02:19 83.0M application/zip
cm_ace_full-22.zip.md5sum.txt 2011-Mar-16 22:02:19 0.1K text/plain
cm_ace_full-23.zip 2011-Mar-18 00:01:57 83.0M application/zip
cm_ace_full-23.zip.md5sum.txt 2011-Mar-18 00:01:57 0.1K text/plain
cm_ace_full-24.zip 2011-Mar-18 20:01:46 83.0M application/zip
cm_ace_full-24.zip.md5sum.txt 2011-Mar-18 20:01:46 0.1K text/plain
cm_ace_full-25.zip 2011-Mar-18 22:02:22 83.0M application/zip
cm_ace_full-25.zip.md5sum.txt 2011-Mar-18 22:02:23 0.1K text/plain
cm_ace_full-26.zip 2011-Mar-19 20:01:49 83.0M application/zip
cm_ace_full-26.zip.md5sum.txt 2011-Mar-19 20:01:50 0.1K text/plain
cm_ace_full-28.zip 2011-Mar-21 00:02:53 83.0M application/zip
cm_ace_full-28.zip.md5sum.txt 2011-Mar-21 00:02:54 0.1K text/plain
cm_ace_full-29.zip 2011-Mar-22 00:09:46 83.0M application/zip
cm_ace_full-29.zip.md5sum.txt 2011-Mar-22 00:09:46 0.1K text/plain
cm_ace_full-30.zip 2011-Mar-23 06:02:41 84.1M application/zip
cm_ace_full-30.zip.md5sum.txt 2011-Mar-23 06:02:42 0.1K text/plain
cm_ace_full-31.zip 2011-Mar-26 12:04:20 81.6M application/zip
cm_ace_full-31.zip.md5sum.txt 2011-Mar-26 12:04:20 0.1K text/plain
cm_ace_full-32.zip 2011-Mar-28 10:27:43 81.7M application/zip
cm_ace_full-32.zip.md5sum.txt 2011-Mar-28 10:27:43 0.1K text/plain
cm_ace_full-34.zip 2011-Apr-02 18:58:15 82.4M application/zip
cm_ace_full-34.zip.md5sum.txt 2011-Apr-02 18:58:15 0.1K text/plain
cm_ace_full-35.zip 2011-Apr-03 23:03:27 82.4M application/zip
cm_ace_full-35.zip.md5sum.txt 2011-Apr-03 23:03:27 0.1K text/plain
cm_ace_full-36.zip 2011-Apr-05 19:04:15 82.4M application/zip
cm_ace_full-36.zip.md5sum.txt 2011-Apr-05 19:04:15 0.1K text/plain
cm_ace_full-37.zip 2011-Apr-08 13:02:58 83.0M application/zip
cm_ace_full-37.zip.md5sum.txt 2011-Apr-08 13:02:58 0.1K text/plain
cm_ace_full-38.zip 2011-Apr-10 00:03:34 83.1M application/zip
cm_ace_full-38.zip.md5sum.txt 2011-Apr-10 00:03:35 0.1K text/plain
cm_ace_full-39.zip 2011-Apr-12 20:03:37 83.1M application/zip
cm_ace_full-39.zip.md5sum.txt 2011-Apr-12 20:03:37 0.1K text/plain
cm_ace_full-4.zip 2011-Feb-22 00:02:16 80.9M application/zip
cm_ace_full-4.zip.md5sum.txt 2011-Feb-22 00:02:16 0.1K text/plain
cm_ace_full-40.zip 2011-Apr-16 23:03:42 84.3M application/zip
cm_ace_full-40.zip.md5sum.txt 2011-Apr-16 23:03:43 0.1K text/plain
cm_ace_full-41.zip 2011-Apr-18 10:04:01 84.3M application/zip
cm_ace_full-41.zip.md5sum.txt 2011-Apr-18 10:04:01 0.1K text/plain
cm_ace_full-42.zip 2011-Apr-22 12:03:00 85.0M application/zip
cm_ace_full-42.zip.md5sum.txt 2011-Apr-22 12:03:01 0.1K text/plain
cm_ace_full-6.zip 2011-Feb-23 22:02:32 80.9M application/zip
cm_ace_full-6.zip.md5sum.txt 2011-Feb-23 22:02:32 0.1K text/plain
cm_ace_full-7.zip 2011-Feb-25 02:01:11 80.9M application/zip
cm_ace_full-7.zip.md5sum.txt 2011-Feb-25 02:01:12 0.1K text/plain
cm_ace_full-8.zip 2011-Feb-26 20:02:30 80.9M application/zip
cm_ace_full-8.zip.md5sum.txt 2011-Feb-26 20:02:30 0.1K text/plain
tdud_ace_full-33.zip 2011-Apr-01 14:08:50 84.0M application/zip
tdud_ace_full-33.zip.md5sum.txt 2011-Apr-01 14:08:50 0.1K text/plain
Pas de #50
Hummm.... Disponible au téléchargement maintenant, personnellement je vais attendre avant de l'installer. Il n'y a pas eu de retour encore des Devs.
Sauf que là c'est plus tous les jours, mais plusieurs fois par jour... Difficile à suivre... Et puis ces bonds dans les versions... Je comprends pas. Jusque la 42, pas de soucis, puis la 50, 51 et 55...
