Posté(e) 26 janvier 201115 a Bonjour, J’ai un problème avec les mises à jour si je modifié la Database (j’ajoute des nouvelles Tables, ou des nouveaux colonnes) Chez des utilisateurs ils on un CF comme ce dernier : java.lang.RuntimeException: Unable to start activity ComponentInfo{dz.algerie.android.information/dz.algerie.android.information.Bienvenue}: android.database.sqlite.SQLiteException: no such table: Bienvenue: , while compiling: SELECT _id, Bienvenue_FR, Bienvenue_EN FROM Bienvenue WHERE (_id=?) ORDER BY _id at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2833) at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2854) at android.app.ActivityThread.access$2300(ActivityThread.java:136) at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2179) at android.os.Handler.dispatchMessage(Handler.java:99) at android.os.Looper.loop(Looper.java:143) at android.app.ActivityThread.main(ActivityThread.java:5068) at java.lang.reflect.Method.invokeNative(Native Method) at java.lang.reflect.Method.invoke(Method.java:521) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:858) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:616) at dalvik.system.NativeStart.main(Native Method) Caused by: android.database.sqlite.SQLiteException: no such table: Bienvenue: , while compiling: SELECT _id, Bienvenue_FR, Bienvenue_EN FROM Bienvenue WHERE (_id=?) ORDER BY _id at android.database.sqlite.SQLiteCompiledSql.native_compile(Native Method) at android.database.sqlite.SQLiteCompiledSql.compile(SQLiteCompiledSql.java:91) at android.database.sqlite.SQLiteCompiledSql.<init>(SQLiteCompiledSql.java:64) at android.database.sqlite.SQLiteProgram.<init>(SQLiteProgram.java:80) at android.database.sqlite.SQLiteQuery.<init>(SQLiteQuery.java:46) at android.database.sqlite.SQLiteDirectCursorDriver.query(SQLiteDirectCursorDriver.java:53) at android.database.sqlite.SQLiteDatabase.rawQueryWithFactory(SQLiteDatabase.java:1417) at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:351) at android.database.sqlite.SQLiteQueryBuilder.query(SQLiteQueryBuilder.java:301) at dz.algerie.android.information.Provider.query(Provider.java:428) at android.content.ContentProvider$Transport.query(ContentProvider.java:169) at android.content.ContentResolver.query(ContentResolver.java:245) at android.app.Activity.managedQuery(Activity.java:1559) at dz.algerie.android.information.Bienvenue.onCreate(Bienvenue.java:31) at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1066) at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2797) ... 11 more Cette table Bienvenue (qu’est indiqué dans le message d’erreur), existe dans la nouvelle Database, mais il n’est pas disponible dans l'ancien Database. voila l'ancien version de Database : voila la nouvelle version de Database : Je pense que dans la mise à jour il ne recopier pas les nouvelles tables. J’attends votre aide. Merci d’avance. Bonne journée. a+
Posté(e) 27 janvier 201115 a Bonjour, N'aurais tu pas oublier de modifier la version de ta base ? Cordialement
Posté(e) 27 janvier 201115 a Auteur Bonjour, N'aurais tu pas oublier de modifier la version de ta base ? Cordialement Bonjour, merci, pour la réponse, oui j'ai jamais modifie la version de la base, je donne un numéro par exemples 2 ou 3 ... bonne journée a+
Posté(e) 27 janvier 201115 a Auteur Bonjour, N'aurais tu pas oublier de modifier la version de ta base ? Cordialement Bonjour, merci pour l'aide, j'ai change la version et je veux confirmé, j'ai change Schema Version, et User Version. les Anciens valeur : les Nouveau valeur : bonne journée a+
Posté(e) 23 février 201115 a Auteur Bonjour, N'aurais tu pas oublier de modifier la version de ta base ? Cordialement Bonjour, j'ai modifié la version de la base, mais j'ai toujours le même probleme, je trouve toujours ces messages d'erreurs dans le log d'erreur sur : http://www.flurry.com class java.lang.RuntimeException Unable to start activity ComponentInfo{dz.algerie.android.information/dz.algerie.android.information.PrincipauxSites} android.database.sqlite.SQLiteException: no such table: PrincipauxSites while compiling: SELECT Descriptif_FR _id Image Reference j'attende votre aide merci d'avance bonne journée a+
