Hero79 Posté(e) 31 janvier 2011 Posté(e) 31 janvier 2011 (modifié) Tout conseils et toutes aides sont les bienvenus ! Hi guys,Here is a another release for the Hero fixing most of the annoyances created in the last build. This will be probably the last release for the Hero based on Gingerbread. Depending on the bug reports reported by you. I hope you can enjoy this release as much as possible and hopefully see you back in ICS. I want to thank everyone that has supported me on Cronos. Cronos Ginger X 2.4.0 - Android 2.3.7 Topic officiel: http://www.cronosproject.org/index.php?page=Thread&threadID=1981 Évolution de la ROM: 06 Nov 2011 | Cronos Ginger X 2.4.0 Fixed Wifi Tethering support. Fixed sqlite WAL Bug. Made some changes to libcamera. Made some changes to liblights. Improved speed to system. Fully integrated OC Daemon. Fixed Call hang up Delay. Fixed application support. Improved net speed 3G/H/WiFi 27 Oct 2011 | Cronos Ginger X 2.3.9 Fully Updated to Android 2.3.7 Browser battery draining fixed. Calling battery draining fixed. Cronos X Settings FC's fixed. Separate OC Daemon Patch. Tweaked low memory. Cleaner vendor libs.This Will remove Full Cronos X CPU Memory Hog.This means the CPU over clocking in X Settings will be fully removed giving you more memory to spare in your system. Over clocking will be done with a oc daemon. You can find its CPU OC configurations in /system/etc/cronos directory. [*]This OC daemon will make your phone a bit faster with switching frequencies. 31 Aug 2011 | Cronos Ginger X 2.3.6 Update Patch: Updated Cronos governor. Tweaked Freq stepping. Fixed lag. Library updates. This is an update patch only. No wipes! 24 Aug 2011 | Cronos Ginger X 2.3.5: Updated to latest source code. New kernel compile based on a testing config. Updated Cronos governor sensitivity. Optimized Android 2.3.5 Speed. Fixed Bluetooth. Improved EGL speed. Fixed pre-release CGX 2.3.4 long boot issue. Improved Camera Speed 31 July 2011 | Cronos Ginger X 2.3.3: Fixed Cronos X FC's. Fixed X Powerwidget (For real) Updated to latest Android Sourcecode. 27 July 2011 | Cronos Ginger X 2.3.2: Updated to Android 2.3.5 Cronos X PowerWidget fixed. Cronos X Settings still android 2.3.4 code. Will update soon. Bug: I broke screen on/off animations? 20 July 2011 | Cronos Ginger X 2.3.1: Please recalibrate your battery. Please fully charge the battery to 100%. X Settings updated to version 0.0.3 Font sizing will stay permanent. Fixed: ScreenStatus Scaling. Fixed CRT ON/OFF Lagg. Fixed 30tweak file, thanks bleep42. System should be a bit snappier. Added a new version string for X Settings Mod itself. Volume rocker wakeup port by ComputerFreak Enable/disable CRT on/off animationport by Feeyo/Computerfreak Added option to change the indicator color in the notification widget port by ComputerFreak Fixed some checkboxed incorrectly checked by default by ComputerFreak Fixed some incorrect text when selecting brightness mode by ComputerFreak 13 july 2011 | Cronos Ginger X 2.3.0: First release of Cronos X. Settings have extended options. Font size options ported by ComputerFreak. Battery Percentage option added. Battery Percentage Bug, fixed by ComputerFreak. widget button FC on MDPI devices fixed by ComputeFreak. Improved Danish Translations by ComputerFreak. Extra animation option ported by ComputerFreak. small GUI changes by ComputerFreak. A few tweaks used with flags. Fully Removed CM Extra. Sources have been updated to latest AOSP. Source for external and hardware support updated to latest CM. libSqlite improvement. Added Call Delay tweak by jyxent. lowmemorykiller improvement (Again) Added a few tweaks from Juwe11. BatteryWipe on flash by Seo. And of course all the Cronos speed imrpovements Adde 08 June 2011 | Cronos Ginger 2.2.4 Updated CM Extra to latest. Updated to latest Sources. (AOSP + CM). Added DSPManager. Added ThemeChooser. Added Notification Bar Widgets back. Added WiFi Boost. DeOdexed Compile. 04 June 2011 | Cronos Ginger 2.2.3_P1 Support for Vector Maps. Fixed corrupted boot animation. This is an update Patch ONLY (No wipes needed!) 03 June 2011 | Cronos Ginger 2.2.3 Fixed JNI Bug. Cleaned a Bogus htc core framework permissions entry. 02 June 2011 | Cronos Ginger 2.2.2 Fixed libwebcore exception. Updated to latest Android 2.3.4 Sources. Tweaked Build Environment. Added new EVO kernel, compiled with my private optimized toolchain. Changed kernel configuration to drain less battery. Fixed SDCARD issue: Corrupting Filesystems. Enabled Screen On and Off. 23 May 2011 | Cronos Ginger 2.2.1 Tweak audio APIs for better compatibility. Fixed draw texture when loadTexture() is called. Performance of toHex() improved. sdcard improve insertion notification on Gingerbread. Ninepatch tweaks for better interop Switch to SkSafeUnref for better portability Fixed Bogus WiFi Garbage in xml's from an old patch of mine. Updated to latest AOSP Sources. Better Bluetooth Support. Lock home in mem included. Full release notes: http://www.cronospro...lease-notes.txt Problèmes connus: *Aucun ROM: Cronos Ginger X 2.4.0 http://cronos.bertol.de/download.php?HCGX-2.4.0_.zip MD5SUM: on download link system. Google APPS: http://cmw.22aaf3.com/gapps/gapps-gb-20110828-signed.zip Modifié 7 novembre 2011 par Hero79 Citer
Guiluge Posté(e) 31 janvier 2011 Posté(e) 31 janvier 2011 Coucou, Ok, je suis de près cette ROM donc je peux d'ores et déjà te dire qu'il y a un petit souci : les animations standard Android ne fonctionnent plus. Pas forcément gênant, mais c'est vrai que ça faisait chouette :) Feeyo est au courant, et bosse dessus. Guiluge. Citer
Mephisto Posté(e) 31 janvier 2011 Posté(e) 31 janvier 2011 (modifié) Je vais attendre la version finalisé mais cool d avoir refait un post suite au depart de philo64. Quelqu un connait l'utilité du patch : Gingerbread Launcher ? De la déco ? De l'optimisation au démarrage ? Modifié 31 janvier 2011 par Mephisto Citer
Hero79 Posté(e) 31 janvier 2011 Auteur Posté(e) 31 janvier 2011 (modifié) Ok,merci de ton témoignage,je vais mettre a jour le post 1 pour les problèmes connus.Vu que c'est mon premier topic ce rapportant à une ROM ,plus il y aura de monde pour participer , mieux ce sera ! Pour le launcher gingerbread,je ne l'ai pas essayé,je flash ce soir mais logiquement c'est juste le launcher officiel gingerbread. Modifié 31 janvier 2011 par Hero79 Citer
armand78990 Posté(e) 31 janvier 2011 Posté(e) 31 janvier 2011 bonjour, merci pour la tenue des differents treads. une petite question, j'ai actuement la derniere vesion 0.09 faut il que je fasse un full Wip et me retaper l' instal de toutes mes aplications ou simplement une instal de la 1.0.1 et reboot? salutations Citer
steells Posté(e) 31 janvier 2011 Posté(e) 31 janvier 2011 Processus d'installation: Full wipe Flash Cronos Ginger 1.0.1 ... Bon après tu peux toujours tester sans wipe :) Mais ca peut soit ne pas marcher du tout soit être instable. Pour ma part que ce soit pour une MAJ ou un changement de ROM, je full wipe toujours, c'est plus propre. Citer
Hero79 Posté(e) 31 janvier 2011 Auteur Posté(e) 31 janvier 2011 Fais une sauvegarde nandroid et wipe juste Dalvik/cache.Si tu rencontres des problèmes,fais un Full Wipe et reFlash la 1.0.1. Citer
kevisann Posté(e) 31 janvier 2011 Posté(e) 31 janvier 2011 Tu m'a bien devancé pour ce topic Hero79, t'as eu raison d'ailleurs ;) Bon, je vais tester cette petite ROM ^^ :se_forte_les_mains: Citer
philos64 Posté(e) 1 février 2011 Posté(e) 1 février 2011 Bonne reprise et bonne continuation avec cette version de la Cronos Ginger. Enjoy good time ;) Citer
Guiluge Posté(e) 1 février 2011 Posté(e) 1 février 2011 Thanks mister Philos, Perso, je vais pas tarder à changer de téléphone non plus, car la hausse de la TVA va me permettre de me casser de chez Orange (ouf), mais bon, je suivrai toujours de prêt mon petit héros :) En attendant, oui, je profite bien de la Ginger et du boulot monstrueux de Feeyo. Guiluge. Citer
loupio Posté(e) 1 février 2011 Posté(e) 1 février 2011 (modifié) Bonjour à tous, j'ai installé cette rom depuis hier j'ai pas mal bidouillé dessus et je dois dire qu'elle est excellente. J'ai pas eu de bug pour le moment, elle est très stable et rapide. Je vais attendre la version finalisé mais cool d avoir refait un post suite au depart de philo64. Quelqu un connait l'utilité du patch : Gingerbread Launcher ? De la déco ? De l'optimisation au démarrage ? Pour répondre à ta question, c'est juste le launcher normal de Gingerbread car la rom viens avec Launcher pro. bonjour, merci pour la tenue des differents treads. une petite question, j'ai actuement la derniere vesion 0.09 faut il que je fasse un full Wip et me retaper l' instal de toutes mes aplications ou simplement une instal de la 1.0.1 et reboot? salutations Pour moi j'ai juste fais un wipe dalvik cache et R.A.S pour le moment Modifié 1 février 2011 par loupio Citer
armand78990 Posté(e) 1 février 2011 Posté(e) 1 février 2011 Pour moi j'ai juste fais un wipe dalvik cache et R.A.S pour le moment merci pour l'info, Quelle est l' action du Wipe dalvik cache? Que vais'j perdre comme configuration ? je viens de finir le parametrage de mon tel (j'ai comme fait une sauve garde avec Titanium) Cela m'embête un peu de devoir tous refaire a chaque MAJ ...( Ok je suis un peu fénéant). et je sais que l' ont n'a rien sans rien, mais bon .... Armand Citer
Shuu Posté(e) 1 février 2011 Posté(e) 1 février 2011 (modifié) Il s'agit d'un dossier système qui contient des fichiers visants à accélérer le fonctionnement d'Android. Lorsque le système démarre, le DalvikVM (partie du système qui gère le cache) regarde à travers l'ensemble des applications (.apk), et construit une base. C'est pourquoi lorsque vous installez une nouvelle ROM, il faut parfois attendre longtemps avant qu'Android ne démarre. Le cache est mis à jour en direct, au fur et à mesure des modifications d'applications. Il est possible d'effacer ce cache (on fait alors un Dalvik-Cache wipe, à l'aide d'un bootloader modifié, ou bien manuellement, à l'aide d'un explorateur de fichiers qui permer l'accés root, en supprimant les fichiers contenus dans le dossier /system/dalvik-cache ), et la base est automatiquement recréée, supprimant au passage les éventuelles erreurs. Que Titanium Backup soit loué ! Tu n'aura normalement rien à re-paramétrer si tu a tout sauvegardé. (et puisque tu viens de la 0.09 normalement pas de mise a jour de des programmes fondamentaux, donc tu dois tout pouvoir restaurer) Edit: je sais pas si tu a vu mais je cite le wiki de Frandroid http://wiki.frandroid.com/wiki/Accueil qui m'a appris plein de truc! et comme c'est en français c'est agréable a lire (plus que les versions anglaise dans lesquels il y a parfois un paquet de jargon incompréhensible) Modifié 1 février 2011 par Shuu Citer
armand78990 Posté(e) 1 février 2011 Posté(e) 1 février 2011 Merci pour le cours Shuu, Je me coucherai moin bete se soir bien cordialement Armand Citer
Catman Posté(e) 1 février 2011 Posté(e) 1 février 2011 Je crois que je vais me laisser tenter, si elle marche aussi bien que la Cronos Froyo... B) Quand vous parlez d'animations Android, vous parlez de quoi exactement? Besoin de formater la carte SD pour passer de 2.2 à 2.3 au fait? Je pense que non mais bon... Citer
Hero79 Posté(e) 1 février 2011 Auteur Posté(e) 1 février 2011 (modifié) Les animations,ce sont les petites animations quand on passe d'une fenêtre a l'autre par exemple.Ex: Quand on clique sur Menu>Paramètres,on a un effet d'agrandissement de rétrécissement,voila c'est ca normalement. Modifié 1 février 2011 par Hero79 Citer
Catman Posté(e) 1 février 2011 Posté(e) 1 février 2011 (modifié) Ah ok, c'est bien ce qu'il me semblait, c'est vrai que c'est plutôt classe mais bon ,ils arriveront bien à le récupérer. Par contre, je rectifie, c'est un effet de rétrécissement. :P Modifié 1 février 2011 par Catman Citer
Mephisto Posté(e) 2 février 2011 Posté(e) 2 février 2011 J ai installé la Rom Hier soir. Je n ai pas encore eu le temps de faire la synthése dessus. Si j écris ce post c est plus pour une ptite question par rapport au Home. Existe t il un problème entre la Rom et Launcher pro ? Ou Launcher n est il pas compatible avec la 2.3 ? Je dis ca car quand j installe Launcher pro, j obtiens un Force Close du Home alors qu'avec ADW je n ai pas ce soucis. Et cela m embete car je préfére Launcher pro, j ai mes ptit paramétre a moi ;-) Merci d avance Citer
Hero79 Posté(e) 2 février 2011 Auteur Posté(e) 2 février 2011 Pour ma part,je n'ai aucun problème avec launcher pro,pas de force close.Launcher pro est compatible avec Gingerbread.Essaye de le désinstaller et réinstaller si tu ne l'a pas déjà fait. Citer
broc4910 Posté(e) 2 février 2011 Posté(e) 2 février 2011 (modifié) Salut, Il arrive parfois que lors d'un redémarrage, laucher pro provoque un force close. Quand ca arrive, je le force a ce fermer et il redémarre alors sans problème. Au passage je remercie Hero79 d'avoir repris la flambeau. Modifié 2 février 2011 par broc4910 Citer
Mephisto Posté(e) 2 février 2011 Posté(e) 2 février 2011 (modifié) Ben j ai essayé plusieurs fois de le relancer, 2 réinstalle et toujours le même soucis. C est a ce moment la que j ai essayé avec ADW et cela fonctionné correctement. ==> Peut etre l'installation de la Rom qui a mal fonctionné. Pour le moment je suis repassé sur mon Back Up Cronos Froyo. Modifié 2 février 2011 par Mephisto Citer
Hero79 Posté(e) 2 février 2011 Auteur Posté(e) 2 février 2011 Launcher pro est-il installé sur ta carte sd ? Si c'est ca,c'est normal,la cronos ginger ne gère pas 100% des apps installés sur la carte sd.Sinon tu as bien fait un Full Wipe avant de flashé ? Citer
QuentinZmiro Posté(e) 2 février 2011 Posté(e) 2 février 2011 (modifié) Bonjour, mon apareil photo fonctionne mal... One voit pas le texte de loin ni de pres. Est-ce normal ? Avec Sense c'etait nickel mais la bof bof :emo_im_undecided: Merci d'avance ! PS : Je n'arrive pas a acceder aux forum Cronos, il me demande un mot de passe. Normal :( ? EDIT : Le site est en maintenance ^^ Modifié 2 février 2011 par Marsou77 Citer
Hero79 Posté(e) 2 février 2011 Auteur Posté(e) 2 février 2011 (modifié) Je n'ai aucun problème avec l'appareil photo,tu as bien flashé la ROM avec un full wipe au préalable ? Modifié 2 février 2011 par Hero79 Citer
