[ROM] CM 6.1.1 Tweaked and with Extras
This is based on the Best of both Worlds FreeX10 and CM 1.2 (Trip) mix i just added other Theme and some Tweaks
included in this Rom:
MIUI Camera (Photo and Video working)
[for Video select low instead of high, still looks great!]
MIUI Keyboard
MIUI Status Bar Icons
MIUI Animations
Galaxy S Theme modified with some of SE 2.1 Styles
HW Led working
LED Flashlight working
latest Gapps already included
[Not newest Market, log in to the included Market first then you can flash the newest]
Sysctl Tweaks
[My Battery Life and Speed of Phone improved alot]
Build.prop Tweaks
[Tweaks + working 2.2 Fingerprint]
Works on newest Kernel and Baseband
[if you dont have it already then Update, its alot smoother then the old!]
FlashPlayer and File Explorer included
Instructions:
1. Go to Xrecovery and make a Backup of your current ROM (optional but i suggest it)
2. Do a Factory Reset and Wipe Dalvik Cache for best Performance (optional)
3. Install Custom Zip and choose CM6.1.1GS.zip
4. At first start it asks for some Action use SetupWizard (dont know why this is, but its no Problem)
5. When its booted go to your Programms and choose preinstalled Sysctl and make sure it is enabled (only enable it you dont need to change something)
6. Copy the CMTheme Folder [from attachement] in the Root of your SD Card
7. Go to CM Settings and then UI Settings or Style Settings
8. Choose Extra Tweaks and then select Color Theme and choose cmparts.ui
9. Reboot
10. Enjoy :-)
Credits:
All Credits go to Devs for these great Roms! And off course to the creater of the Galaxy S Theme!
So please donate to them its all their Work, i just mixed it and put it all in one zip. I will delete it if its not ok for the Devs!
Download:
CM6.1.1GS.zip -
http://hotfile.com/dl/102715697/e80dc61/CM6.1.1GS.zip.html
CMTheme.rar
[extract CMTheme Folder to Root of SD-Card] -
http://hotfile.com/dl/102709797/f25bc62/CMTheme.rar.html
Newest Market -
http://files.rzn.se/Android/m0d/release/NewMarket.zip [thanks to th4r]
Gingerbread In Call Screen
flash with Xrecovery
http://hotfile.com/dl/102722064/ca07d6f/GBInCall.zip.html
Dont forget:
Maybe at first it can be slow its becouse all is loading it depends on how much
Music,Photos etc. you have so like in all other ROMs wait a little bit it should be very fast and smooth when its done.
Optional Tweaks:
I would suggest you to use LauncherPro or ADW Launcher EX instead of the
stock, i use LauncherPro Plus but i cant attach it, Warez are not allowed.
Heapsize
It depends on how you use your X10 i have 26 on my 2.1 ROM but i set it to 36
in this ROM, i dont know if it works good with 36 for others, you need to test yourself what is best for you.
I would recommend using 26,32,40 or 48 when 36 is not good for your X10.
Modifié par eroye
Ok pas de soucis ;) Je dis ça c'est parce que je vois déjà gros comme une maison qu'une dizaine de membre va se plaindre en disant ne pas comprendre l'anglais :P
Je viens apporter ma petite contribution en expliquant pas à pas comment j'ai fait pour installer cette ROM
1ère étape:
Faire une sauvegarde de votre ROM et tout contact, sms etc etc.. !
Je ne suis en aucun cas responsable de mon anglais rouillé et des actions que vous allez faire, alors si vous ne savez pas
ce que vous faites attendez une vrai traduction.. !! je ne serai en aucun cas responsable de vos faits et gestes
2nde étape:
Pour le test de cette ROM j'ai juste DL CM6.1.1gs.zip et CMTheme.rar..
-> Créer un dossier "CM 6.1.1 Tweaked" et mettre CM6.1.1GS.zip et CMTheme.rar dedans puis la mettre à la racine
de votre SD card.
3ème étape:
Rebooté votre téléphone en recovery.
-> Instal custom zip
--> Choose custom zip from sdcard
---> Choisissez le dossier " CM 6.1.1 Tweaked "
-----> Puis Choisissez " CM6.1.1GS.zip "
Patientez que l'installation se fasse jusqu'à ce qu'il y à de marqué : " Install from sdcard complete "
Faites touches RETOUR puis Reboot du recovery
4ème étape:
-> Au premier démarrage, choisissez " SETUP WIZARD "
--> Choisissez " Choose Language ouis Français " (pour ma part)
---> Cliké sur le perso Android pour démarrer.
(( Choisissez l'option Begin ou Skip à votre guise, par la suite, vous pourrez configurer ultérieurement ))
Vous devez arrivez sur l'acceuil MAIS ce n'est pas fini
5ème étape:
-> Maintenant cliké sur le bouton du millieu en bas de votre écran puis choisissez l'application " Sysctl Config"
--> Autoriser les droits Super Utilisateur
Et activer juste Sysctl Support en cochant la case Aucun réglage à faire !!
puis touche Retour.
6ème étape:
-> Parametre
--> CyanogenMod
---> Interface Utilisateur
----> Tweaks supplémentaires
-----> Choisir un thème
------> CMTheme
Et touche OK puis rebooter le tel.
7ème étape : Enjoy ;)
PS: Pour ma part je n'ai eu aucune utilité d'utilisé le "New Market" et "Gingerbread In Call Screen"
pour ceux qui voudront ces dernière attendez une âme charitable qui vous expliquera comment procéder comme je n'ai aucune idée de comment procéder :P
Pour la demi-heure que je l'ai utilisé je l'ai trouvé fluide et plein d'option Cyanogen que je n'ai jamais testé..
Si vous aimez la personnalisation je pense que vous allez être heureux..
Je pense avoir été très clair puisque je l'ai fait pas à pas en même temps que je l'installais, si vous avez un problème...
C'est que vous avez fait une erreur alors reprenez depuis le début.
C'est bizarre, dans les options de CyanogenMod, je vois pas CMTheme.rar pour installer ... ><
Oui, bon en faite résolu <_<
Bon, je vois pas de différence en appliquant le CMTheme ... Normal ?
Encore une chose, impossible de prendre des photos ou vidéo, il me dit cannot connect to camera en lançant l'application appareil photo ...
Modifié par kritis
Merci pour la traduction de l'installation de la rom, Styleur79 ;).
Gingerbread In Call Screen: A flasher via le x-recovery.
New Market: Fichier à dézziper et à installer sur sa carte sd (si je ne me trompe pas).
CMTheme.rar: Dézzipez et copiez le dossier de CMTheme à la racine de votre carte sd.
Merci pour vos retour Styleur79 et kritis.
Je vais la tester pour voir.
Modifié par eroye
Je l'ai testé une journée. Que dire, elle est fluide, belle, mais, un gros MAIS : mon téléphone chargé au max est passé de 100% à 25% en même pas 5 heures d'utilisations, seulement en écoutant la musique 2 heures ! Et mon téléphone il chauffe dans la poche, j'ai senti une grosse chaleur que je touche la coque alors qu'il était en mode musique, donc écran en veille !
Sa fais maintenant que je l'ai utilisé. Je vais mettre une autre ROM...
Points positifs :
. très fluide
. belle interface
. un score quadrant de 1 100 pour moi
Points négatifs :
. chauffe dans la poche, la batterie se vide... pourtant, fait presque que écouter de la musique via merdiian, par exemple, j'ai senti mon portable chauffer dans ma poche chauffer je regarder la batterie, ben elle était à 70% en seulement 2h...
. le wifi ne se connecte pas automatique, il se désactive tout seul du coup, obliger d'aller l'activer manuellement à chaque fois
Voilà pour ma part, mais vraiment dommage pour ces deux points négatifs, surtout quand il chauffe dans la poche c'est très désagréable :
La 3.1 est pas mal du tout, avec le patch pour l'ancien dialer. J'ai pas testé les précédentes, mais après 24h d'utilisation je préfère à l'autre rom CM. Le wifi est beaucoup plus rapide et ne plante pas, la 3G aussi. Les icônes dans les paramètres sont beaucoup plus agréables. Ensuite il suffit de rajouter ce thème et c'est parfait
http://forum.xda-developers.com/showthread.php?t=948701
La 3.2 viens de sortir, mais aparement le changelog ne concerne que quelques sont et retouches graphiques du thème. Le sysctl est un poil optimisé. En gros c'est minime comme changement.
Bref, ma préférée en CM pour le moment :)
  • 3 weeks later...
