[TUTO] Rom Kyrillos avec thème de Gingerbread
Je demande ça car sur le tuto c'est ecris que "Ce lagfix n'est destiné que aux personnes ayant installé la version 2.2 NORMAL de Kyrilos." et comme la c'est la version 3.0 j'ai pas envie de faire une bétise sur le tel de ma femme ^^
Modifié par fabiodelaplazia
  • Réponses 1,9k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Quelqu'un est allé voir le thread de Kyrillos? allez, je quote un peu...
Kyrillos' rom v3.0 Extreme Edition (Based on XXJPM) [There is no ETA, suggestions are welcomed]
Normal Version [beta] => http://www.multiupload.com/T5W9K2KIB0 [JPF]
Completely reworked the whole rom! [Less bugs] (done)
Updated Market [v2.3.4] (done)
Updated QuickPic [v0.9.9] (done)
Updated Gingerbread Keyboard [v1.0.13] (done)
Added Nexus S audio [alarms, notifications & ringtones sounds] (done)
Added Google Maps [v5.20]
Fixed the downloading color bug [When you were downloading something from market you weren't able to see what you were downloading] (done)
Gps Fix [edited gps.conf, faster gps] (done)
New Bootanimation [bootscreen] (done)
Tweaked Framework [gps & bluetooth icons are now green, new notification popup] (done)
Tweaked TwFramework [New notification bar dropdown] (done)
Tweaked Clock [Gingerbread themed] (done)
Tweaked SMS [Gingerbread themed] (done)
Tweaked Settings [Gingerbread themed] (done)
Tweaked Dialer [Honeycomb themed, Thanks to aantdesign] (done)
Patched Malware Exploit for all pre-Gingerbread phones [more information here] (done)
Fixed ScreenCaptureService [it is working like a charm] (done)
Fixed Contacts back button bug [Download the new fixed theme for launcher pro] (done)
FuguTweaks [smoother & faster phone] (done)
Extended Power Menu [Reboot, Download & Recovery] (in progress...)
5 Lockscreen to choose from settings [AOSP / Samsung / Puzzle / Epic / Rotary] (in progress...)
JIT Compiler (testing)
Ext4 Support (done)
All partitions converted to ext4 [system, data & cache] (done)
And many more...
Bon, surtout pour le fait qu'il se basera sur la JPM contrairement à ses plans de départ qui disaient qu'il resterait sur le JPF... Au passage, son développement avance bien avec de plus en plus d'éléments "done" ^^
A mon avis pas avant ce week-end...
Kyrillo souhaitait faire quelque chose d'énorme, mais force est de constater que face à la recrudescence de customs basées sur la JPL, il se devait d'accélérer le mouvement et de se mettre au même niveau, d'où, à mon sens, son changement de rom de base.
Mais bon, ne l'attendons pas trop vite, il nous fait déjà tenir avec une bêta, donc la versions finale, je ne pense pas avant ce week-end. Enfin, j'espère me tromper...
Je viens d'avoir ma réponse sur un autre poste. En fait c'est la Màj officielle sortie en Allemagne et comme ici (en France) elle n'est toujours pas sortie (c'est bien ça ?) on ne sait pas encore son nom, mais apparemment en France ça sera JPM et non JPL comme en Allemagne.
C'est bien ça ?
La JPL a été distribué le 24 février par kies en Allemegne et retirée par la suite... ou un truc dans le genre.
Mon allemand est basique et ces infos provenant de forums allemand je ne m'avance pas trop !
La JPM est la rom officiel qui devrait être distribuée. Cependant j'ai remarqué que les 2 (JPL et JPM) était très très proche
Ah ok, tout est rentré dans l'ordre..!! :D
Donc la JPL (froyo officiel) est sortie puis retirée de Kies fin février... Et finalement le froyo officiel ressort chez les allemands sous le nom de JPM.
Et donc en conclusion la JPL est sensiblement égale à la JPM ?
On va dire en gros c'est sa ...
Une question mon tel n'est pas reconnu par kies le "log" , et je voudrais savoir si il est possible de se connecter a internet via le cable wifi , je suis en v3.0 beta et je n'ai pas reussi a télécharger des applis à mon bahut , pourtant je pouvais naviguer correctement...
Autre question en rapport est-il normal que les point wifi créer sur windows seven (hadoc) ne sont pas detecter par la wifi du téléphone ? y a t-il des paramètres a faire pour se connecter depuis son téléphone ?
