TecKnologikS Posté(e) 26 février 2011 Share Posté(e) 26 février 2011 Donc voila ma base de donée se presente comme ca : 3 colones: id A B 3 ligne 1 2 3 pour charger j'ai ca: Classes: DBAdaptater: package fr.tecknologiks.sexydes; import java.io.FileOutputStream; import java.io.IOException; import java.io.InputStream; import java.io.OutputStream; import java.lang.reflect.Array; import java.util.ArrayList; import java.util.List; import android.content.ContentValues; import android.content.Context; import android.database.Cursor; import android.database.SQLException; import android.database.sqlite.SQLiteDatabase; import android.database.sqlite.SQLiteException; import android.database.sqlite.SQLiteOpenHelper; public class DBAdapter extends SQLiteOpenHelper { private static String DB_PATH = ""; private static final String DB_NAME = "desplus.sqlite"; private SQLiteDatabase myDataBase; private final Context myContext; private static DBAdapter mDBConnection; /** * Constructor * Takes and keeps a reference of the passed context in order to access to the application assets and resources. * @param context */ private DBAdapter(Context context) { super(context, DB_NAME, null, 1); this.myContext = context; DB_PATH = "/data/data/" + context.getApplicationContext().getPackageName() + "/databases/"; // The Android's default system path of your application database is // "/data/data/mypackagename/databases/" } /** * getting Instance * @param context * @return DBAdapter */ public static synchronized DBAdapter getDBAdapterInstance(Context context) { if (mDBConnection == null) { mDBConnection = new DBAdapter(context); } return mDBConnection; } /** * Creates an empty database on the system and rewrites it with your own database. **/ public void createDataBase() throws IOException { boolean dbExist = checkDataBase(); if (dbExist) { } else { // By calling following method // 1) an empty database will be created into the default system path of your application // 2) than we overwrite that database with our database. this.getReadableDatabase(); try { copyDataBase(); } catch (IOException e) { throw new Error("Error copying database"); } } } /** * Check if the database already exist to avoid re-copying the file each time you open the application. * @return true if it exists, false if it doesn't */ private boolean checkDataBase() { SQLiteDatabase checkDB = null; try { String myPath = DB_PATH + DB_NAME; checkDB = SQLiteDatabase.openDatabase(myPath, null, SQLiteDatabase.OPEN_READONLY); } catch (SQLiteException e) { // database does't exist yet. } if (checkDB != null) { checkDB.close(); } return checkDB != null ? true : false; } /** * Copies your database from your local assets-folder to the just created * empty database in the system folder, from where it can be accessed and * handled. This is done by transfering bytestream. * */ private void copyDataBase() throws IOException { // Open your local db as the input stream InputStream myInput = myContext.getAssets().open(DB_NAME); // Path to the just created empty db String outFileName = DB_PATH + DB_NAME; // Open the empty db as the output stream OutputStream myOutput = new FileOutputStream(outFileName); // transfer bytes from the inputfile to the outputfile byte[] buffer = new byte[1024]; int length; while ((length = myInput.read(buffer)) > 0) { myOutput.write(buffer, 0, length); } // Close the streams myOutput.flush(); myOutput.close(); myInput.close(); } /** * Open the database * @throws SQLException */ public void openDataBase() throws SQLException { String myPath = DB_PATH + DB_NAME; myDataBase = SQLiteDatabase.openDatabase(myPath, null, SQLiteDatabase.OPEN_READWRITE); } /** * Close the database if exist */ @Override public synchronized void close() { if (myDataBase != null) myDataBase.close(); super.close(); } /** * Call on creating data base for example for creating tables at run time */ @Override public void onCreate(SQLiteDatabase db) { } /** * can used for drop tables then call onCreate(db) function to create tables again - upgrade */ @Override public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) { } // ----------------------- CRUD Functions ------------------------------ /** * This function used to select the records from DB. * @param tableName * @param tableColumns * @param whereClase * @param whereArgs * @param groupBy * @param having * @param orderBy * @return A Cursor object, which is positioned before the first entry. */ public Cursor selectRecordsFromDB(String tableName, String[] tableColumns, String whereClase, String whereArgs[], String groupBy, String having, String orderBy) { return myDataBase.query(tableName, tableColumns, whereClase, whereArgs, groupBy, having, orderBy); } /** * select records from db and return in list * @param tableName * @param tableColumns * @param whereClase * @param whereArgs * @param groupBy * @param having * @param orderBy * @return ArrayList<ArrayList<String>> */ public ArrayList<ArrayList<String>> selectRecordsFromDBList(String tableName, String[] tableColumns, String whereClase, String whereArgs[], String groupBy, String having, String orderBy) { ArrayList<ArrayList<String>> retList = new ArrayList<ArrayList<String>>(); ArrayList<String> list = new ArrayList<String>(); Cursor cursor = myDataBase.query(tableName, tableColumns, whereClase, whereArgs, groupBy, having, orderBy); if (cursor.moveToFirst()) { do { list = new ArrayList<String>(); for(int i=0; i<cursor.getColumnCount(); i++){ list.add( cursor.getString(i) ); } retList.add(list); } while (cursor.moveToNext()); } if (cursor != null && !cursor.isClosed()) { cursor.close(); } return retList; } /** * This function used to insert the Record in DB. * @param tableName * @param nullColumnHack * @param initialValues * @return the row ID of the newly inserted row, or -1 if an error occurred */ public long insertRecordsInDB(String tableName, String nullColumnHack, ContentValues initialValues) { return myDataBase.insert(tableName, nullColumnHack, initialValues); } /** * This function used to update the Record in DB. * @param tableName * @param initialValues * @param whereClause * @param whereArgs * @return true / false on updating one or more records */ public boolean updateRecordInDB(String tableName, ContentValues initialValues, String whereClause, String whereArgs[]) { return myDataBase.update(tableName, initialValues, whereClause, whereArgs) > 0; } /** * This function used to update the Record in DB. * @param tableName * @param initialValues * @param whereClause * @param whereArgs * @return 0 in case of failure otherwise return no of row(s) are updated */ public int updateRecordsInDB(String tableName, ContentValues initialValues, String whereClause, String whereArgs[]) { return myDataBase.update(tableName, initialValues, whereClause, whereArgs); } /** * This function used to delete the Record in DB. * @param tableName * @param whereClause * @param whereArgs * @return 0 in case of failure otherwise return no of row(s) are deleted. */ public int deleteRecordInDB(String tableName, String whereClause, String[] whereArgs) { return myDataBase.delete(tableName, whereClause, whereArgs); } // --------------------- Select Raw Query Functions --------------------- /** * apply raw Query * @param query * @param selectionArgs * @return Cursor */ public Cursor selectRecordsFromDB(String query, String[] selectionArgs) { return myDataBase.rawQuery(query, selectionArgs); } /** * apply raw query and return result in list * @param query * @param selectionArgs * @return ArrayList<ArrayList<String>> */ public ArrayList<ArrayList<String>> selectRecordsFromDBList(String query, String[] selectionArgs) { ArrayList<ArrayList<String>> retList = new ArrayList<ArrayList<String>>(); ArrayList<String> list = new ArrayList<String>(); Cursor cursor = myDataBase.rawQuery(query, selectionArgs); if (cursor.moveToFirst()) { do { list = new ArrayList<String>(); for(int i=0; i<cursor.getColumnCount(); i++){ list.add( cursor.getString(i) ); } retList.add(list); } while (cursor.moveToNext()); } if (cursor != null && !cursor.isClosed()) { cursor.close(); } return retList; } } UserBO: package fr.tecknologiks.sexydes; public class UserBO { int id; public int getId() { return id; } public void setId(int id) { this.id = id; } //Action public String getA() { return A; } public void setA(String A) { this.A = A; } public long getB(){ return B; } public void setB(long B) { this.B = B; } String A; String B; } et le code qui utilise tout Main.java: ArrayList<UserBO> listUsers1 = getUsers(2); UserBO user1 = listUsers1.get(0); id = Integer.parseInt(user1.getId()); A = Long.parseLong(user1.getA()); B = Long.parseLong(user1.getB()); [....] public ArrayList<UserBO> getUsers(int id){ DBAdapter dbAdapter=DBAdapter.getDBAdapterInstance(this); try { dbAdapter.createDataBase(); } catch (IOException e) { Log.i("*** select ",e.getMessage()); } dbAdapter.openDataBase(); String query="SELECT * FROM user where id = "+id+";"; ArrayList<ArrayList<String>> stringList = dbAdapter.selectRecordsFromDBList(query, null); dbAdapter.close(); ArrayList<UserBO> usersList = new ArrayList<UserBO>(); for(int i=0; i<stringList.size(); i++){ ArrayList<String> list = stringList.get(i); UserBO user = new UserBO(); user.id = Integer.parseInt( list.get(0) ); user.A = Long.parseLong( list.get(1) ); user.B = Long.parseLong( list.get(2) ); usersList.add(user); } return usersList; } donc voila comment faire pour changer de ligne ? je change id avant array list(ca ne change pas les donner A et B)? ou je refait une array list.? si quelqu'un a le courage je met mon code en chantier a disposition si on me le demande par mail... mais attention au yeux... ici c'est plus clair Lien vers le commentaire Partager sur d’autres sites More sharing options...
chpil Posté(e) 28 février 2011 Share Posté(e) 28 février 2011 je change id avant array list(ca ne change pas les donner A et B )? Je dirais 'oui' (si je comprends bien la question...) Lien vers le commentaire Partager sur d’autres sites More sharing options...
TecKnologikS Posté(e) 28 février 2011 Auteur Share Posté(e) 28 février 2011 justement ca change pas les donnée... il semble rester sur le meme id de ligne Lien vers le commentaire Partager sur d’autres sites More sharing options...
chpil Posté(e) 1 mars 2011 Share Posté(e) 1 mars 2011 En es-tu sûr ? Tu as les bonnes données ? ou pas ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
TecKnologikS Posté(e) 2 mars 2011 Auteur Share Posté(e) 2 mars 2011 non ce ne sont pas les bonnes... mais je vais essayer soit de stocker tout dans différentes variables soit sans passer par une variable faire directement un if Long.parseLong(user1.getA()) = 0 ... enfin je vais m'arranger... je posterai la réponse si ca marche ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
TecKnologikS Posté(e) 8 mars 2011 Auteur Share Posté(e) 8 mars 2011 resultat : une mauvaise gestion des get user... en revoyant j'ai trouver les erreur.. donc ce que tu m'a dit etait bon.. la gestion de la base etait bonne c'etait la gestion des fonctions qui faisait tout raté ! Merci Lien vers le commentaire Partager sur d’autres sites More sharing options...
