database disk image is malformed
J’ai un problème voila le message que j'ai chez des utilisateurs ils on un CF comme ce dernier :
android.database.sqlite.SQLiteDatabaseCorruptException: database disk image is malformed
at android.database.sqlite.SQLiteQuery.native_fill_window(Native Method)
at android.database.sqlite.SQLiteQuery.fillWindow(SQLiteQuery.java:73)
at android.database.sqlite.SQLiteCursor.fillWindow(SQLiteCursor.java:287)
at android.database.sqlite.SQLiteCursor.getCount(SQLiteCursor.java:268)
at android.content.ContentResolver.query(ContentResolver.java:268)
at android.app.Activity.managedQuery(Activity.java:1550)
at dz.algerie.android.information.InfoWilayaAlgerie.AffichePresentation(InfoWilayaAlgerie.java:545)
at dz.algerie.android.information.InfoWilayaAlgerie.access$2(InfoWilayaAlgerie.java:529)
at dz.algerie.android.information.InfoWilayaAlgerie$1.onTabChanged(InfoWilayaAlgerie.java:147)
at android.widget.TabHost.invokeOnTabChangeListener(TabHost.java:359)
at android.widget.TabHost.setCurrentTab(TabHost.java:344)
at android.widget.TabHost$2.onTabSelectionChanged(TabHost.java:132)
at android.widget.TabWidget$TabClickListener.onClick(TabWidget.java:456)
at android.view.View.performClick(View.java:2485)
at android.view.View$PerformClick.run(View.java:9080)
at android.os.Handler.handleCallback(Handler.java:587)
at android.os.Handler.dispatchMessage(Handler.java:92)
at android.os.Looper.loop(Looper.java:123)
at android.app.ActivityThread.main(ActivityThread.java:3683)
at java.lang.reflect.Method.invokeNative(Native Method)
at java.lang.reflect.Method.invoke(Method.java:507)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:839)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:597)
at dalvik.system.NativeStart.main(Native Method)
J’attends votre aide.
Merci d’avance.
Bonne journée.
a+
  • 3 weeks later...
