plusieurs tables BDD SQlite
J'ai repris rapidement ton code et chez moi ça marche par d'erreur de compile ni d’exception.
J'ai tout mis dans une seul classe (database et helper ) :
package fr.debug;
import android.content.Context;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteOpenHelper;
import android.database.sqlite.SQLiteStatement;
public class GestionBDDMsgPredef extends SQLiteOpenHelper {
private static final String DATABASE_NAME = "msgpredef.db";
private static final int DATABASE_VERSION = 1;
private static final String TABLE_NAME_MSG_PREDEF = "msg01";
private static final String TABLE_NAME = "table1";
public SQLiteDatabase db;
private SQLiteStatement insertStmt;
private SQLiteStatement insertStmtmsgpredef;
private static final String INSERT = "insert into " + TABLE_NAME + " (name) values (?)";
private static final String INSERTMSGPREDEF = "insert into " + TABLE_NAME_MSG_PREDEF + " (msg) values (?)";
public GestionBDDMsgPredef(Context context) {
  super(context, DATABASE_NAME, null, DATABASE_VERSION);
public long insert(String name) {
       this.insertStmt.bindString(1, name);
       return this.insertStmt.executeInsert();
public long insert_msg_predef(String msg) {
     this.insertStmtmsgpredef.bindString(1, msg);
     return this.insertStmtmsgpredef.executeInsert();
@Override
public void onCreate(SQLiteDatabase db) {
db.execSQL("CREATE TABLE " + TABLE_NAME + " (_id INTEGER PRIMARY KEY, name TEXT)");
db.execSQL("CREATE TABLE " + TABLE_NAME_MSG_PREDEF + " (_id INTEGER PRIMARY KEY, msg TEXT)");
@Override
public void onUpgrade(SQLiteDatabase arg0, int arg1, int arg2) {
// TODO Auto-generated method stub
public void openDatabase() {
   db = this.getWritableDatabase();
   this.db = this.getWritableDatabase();
   this.insertStmt = this.db.compileStatement(INSERT);
   this.insertStmtmsgpredef = this.db.compileStatement(INSERTMSGPREDEF);
 public void closeDatabase() {
   db.close();
le hello world qui fait les 2 insert
package fr.debug;
import android.app.Activity;
import android.os.Bundle;
public class HelloDebug extends Activity {
 GestionBDDMsgPredef gestionBDDMsgPredef;
   /** Called when the activity is first created. */
   @Override
   public void onCreate(Bundle savedInstanceState) {
       super.onCreate(savedInstanceState);
       setContentView(R.layout.main);
       gestionBDDMsgPredef = new GestionBDDMsgPredef(this);
       gestionBDDMsgPredef.openDatabase();
       gestionBDDMsgPredef.insert("un nom");
       gestionBDDMsgPredef.insert_msg_predef("un message");
   @Override
   protected void onDestroy() {
   	super.onDestroy();
   	gestionBDDMsgPredef.closeDatabase();
