Ajouter du texte sur un marqueur android
frAydjwe
Je dispose de cette classe (récupéré sur la doc android) :
package com.android.webtrack;
import java.util.ArrayList;
import android.app.AlertDialog;
import android.content.Context;
import android.graphics.drawable.Drawable;
import com.google.android.maps.ItemizedOverlay;
import com.google.android.maps.OverlayItem;
public class HelloItemizedOverlay extends ItemizedOverlay<OverlayItem> {
private ArrayList<OverlayItem> mOverlays = new ArrayList<OverlayItem>();
Context mContext;
public HelloItemizedOverlay(Drawable defaultMarker) {
// Now define the HelloItemizedOverlay constructors.
//The constructor must define the default marker for each of the OverlayItems.
//In order for the Drawable to actually get drawn, it must have its bounds defined.
//Most commonly, you want the center-point at the bottom of the image to be the point at which it's attached to the map coordinates.
//This is handled for you with the boundCenterBottom() method. Wrap this around our defaultMarker, so the super constructor call looks like this:
super(boundCenterBottom(defaultMarker));
// TODO Auto-generated constructor stub
// new class constructor
public HelloItemizedOverlay(Drawable defaultMarker, Context context) {
mContext = context;
@Override
protected OverlayItem createItem(int i) {
return mOverlays.get(i);
@Override
public int size() {
return mOverlays.size();
public void addOverlay(OverlayItem overlay) {
mOverlays.add(overlay);
populate();
@Override
protected boolean onTap(int index) {
OverlayItem item = mOverlays.get(index);
AlertDialog.Builder dialog = new AlertDialog.Builder(mContext);
dialog.setTitle(item.getTitle());
dialog.setMessage(item.getSnippet());
dialog.show();
return true;
J'aimerais ajouter une zone de texte dessus le marqueur android, et pas avec OnTap comme dans cette classe. Comment faire ?? Je vous remercie !
