Hero79 Posté(e) 9 mai 2011 Share Posté(e) 9 mai 2011 (modifié) Il existait déjà une Rom avec sense 2.1 et android 2.3.3(Celle-ci)Elle a changé de dev et a été repris par arnoslag seulement il aide maintenant erasmux a développer la HeroLatte. HeroLatte 0.9 TAfter the dust settled with all the excitement of the new Sense Gingerbread, I revisited this port, and IMHO this one has real potential. It seems fast and stable and I am hoping to get everything working in the near future, well at least everything except the camera. Additionally, I am in parallel working on a method to add proper RTL support (Hebrew, Arabic) to closed source ROMs, and this ROM will incorporate this as well. Changelog Version 0.9 - Camera fixed (although no click sound ) - Notifications fixed + trackball notification for missed calls - Autobacklight dim bug fixed - Replaced dalvik implementation and enabled JIT - UI tweaks - Recent apps removed from status bar - Menu key no longer unlocks boot screen - OpenGL 1.1 - Updated google apps - Low memory and scheduler params tweaked - Added translations from the Wildfire Froyo Sense, there could be some places which are still missing translations because this ROM originally only has english. Version 0.5 - Espresso Sense tweaked to look a bit better - Thanks ArnoSlag - GPS fixed - BT audio fixed (I think) - Light fixed (but not trackball) - Gyros fixed (at least partially) - Audio gliches fixes - Added reboot menu - ROM Cleanup a bit - Full Hebrew and Arabic support (except for Arabic support in browser) Version 0.2 (Herosso) - Initial version base on T-Mobile myTouch 3G Slide update 2.15.531.3. - App2SD - Basic hardware support Instructions: - Full wipe and flash from recovery - First load will take a while ROM: HeroLatte 0.9(Androd RTK) HeroLatte 0.9(Multiupload) Problèmes connus: - I was experiencing some bad lags while doing the initial setup with this version (0.9), much more than I thought there would be. Still after it rested for a bit, it seems ok now. Please share your experiences about the lag on this version. - Graphical glitch on incoming call lockscreen with default theme - Graphical problems with Russian dialpad - It's highly non trivial to change Lock screen wallpaper, let me know if you succeed :P - Camera, not sure if its possible to have a working hero camera on Sense 2.2 ROMs - Camera does not make click sound. - This is a port of a T-Mobile ROM (USA) so the Sense UI does not have the translations for European languages. - Translation to other languages might not be perfect as I took them from the Wildfire ROM. - Wifi hotspot does not work (I believe we don't have kernel support for this) - Trackball notification does not work (WIP) - Menu key unlocks lock screen?! - When the screen dims just before it times out, touching the screen will prevent the timeout but when using auto-brightness will result in very low brightness either until the screen is turned off and on or until there is a change in ambient light (causing a recalculation of the auto-brightness). Not much I can do about this HTC bug as they didn't give me the sources ;(. - Arabic reshaping is not supported in the web browser (and other "small" Arabic problem support problem like the crazy cursor movement, which at least currently also exist in CM7). - Anything else? Screenshots: Modifié 26 juin 2011 par Hero79 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Hero79 Posté(e) 26 juin 2011 Auteur Share Posté(e) 26 juin 2011 (modifié) Version 0.9 sortie,la caméra marche !!! Modifié 26 juin 2011 par Hero79 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
averroes42 Posté(e) 4 août 2011 Share Posté(e) 4 août 2011 Alors le retour sur cette rom?? On n'en entend pas parler... ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
