florent38 Posté(e) 26 mai 2011 Share Posté(e) 26 mai 2011 (modifié) -- Source XDA -- ------ [TWlauncher4]Ultima 4 Fastest Froyo [New freeKernel mod 3.5#1] http://www.imageurlhost.com/images/2val88v8j6m8rnk14hb1.png ROM INFORMATION: - Release 25-05-2011 - Froyo 2.2.1 - 8.1MP HD-Ready Camera - LG Optimas 2x Keyboard [Ported] - New Miui movistar Animation - super fast kernel [Thanks to trip and Z] - New very nice theme - Nice Dialer [thanks to go3asy] - Very Smooth - Needs baseband .52 - Build.prop Tweaks - Sysctl Tweaks - Undervolted CPU - K11 Kernel Changelog : Ultima 4 1.Camcorder fix 2.new kernel 3.battery charging problem fix 4.low battery reboot fix. 5.new font 6.more smoth Ultima 3 1.K11 kernel is now default. 2.720p cam. 3.camcorder working. 4.added Z,s Cam app. Ultima 2 1.lots of new battery twicks 2.black ststus bar 3.apps2sd working 4.unvisible menu item problem fixed 5.camcoder fixed. AppBugs: need to report Installation: 1: Flash baseband 52 2:Factory reset, Wipe Cache Partition, Format Cache ,Wipe Dalvik Cache from Xrecovery. 3:Flash Ultima 4 as a Custom Zip and Reboot. 4:Wait for signal.. 5.go to cm setting and change the clock colour. 6:Enjoy. Battery drain fix I have fix the popular custom kernel battery drain just do this 1. Go to dev tool and crash the system server. 2. go to setting/wirless and network/mobile network and silect the network manually. 3. Restart. Now may be you have deep sleep working Download : with Wifi and market fix Ultima 4 http://www.mediafire.com/?7u7qhncvfrno12x Update:flash as a custom zip http://www.mediafire.com/?r65rd3m51p4uec3 Galaxy s 2 theme: put this file into your sd and goto launcher /preferences/themes/install theme. install it and then chose it from same menu. http://www.mediafire.com/?73hi5yp2cro69m6 Modifié 28 juin 2011 par florent38 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 26 mai 2011 Auteur Share Posté(e) 26 mai 2011 Hello , qui est tester cette dernier avec un kernel Ultima Speed Mod !!!! oulala !!!!! ça doit speedé !!!LOL :lol: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
napster23 Posté(e) 26 mai 2011 Share Posté(e) 26 mai 2011 Mon Phone est out pour le moment xD (la SD est coincé dans le lecteur) Ce qui est sur, cette Rom est pour Moi ^^ Le GPS fonctionne ?, manque plus que L'App2SD est c'est bon pour les Custom Kernel. Cordialement napster23. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jon08 Posté(e) 26 mai 2011 Share Posté(e) 26 mai 2011 Prends une pince à épiler pour la sortir :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AdrienDegremont Posté(e) 26 mai 2011 Share Posté(e) 26 mai 2011 des rom des rom toujours belle.il commence a avoir pas mal de choix^^.je ne c'est plus ou donner de la tete lol.mais cette rom a l'aire interessante quand meme.je verais ce soir en rentrant du boulot. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 26 mai 2011 Auteur Share Posté(e) 26 mai 2011 cool , moi j'ai vraiment pas le tps de la tester ! mon fils est à l'hosto , ma fille malade voila de quoi m'occuper !!!! tenez nous au jus Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jon08 Posté(e) 26 mai 2011 Share Posté(e) 26 mai 2011 Hé beh Florent, t'en as de la chance :rolleyes: J'espère qu'il n'y a rien de grave et que tout va vite rentrer dans l'ordre ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 26 mai 2011 Auteur Share Posté(e) 26 mai 2011 Merci, jon08 oui on l’espère !! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alexi Posté(e) 26 mai 2011 Share Posté(e) 26 mai 2011 Rom fraîchement installée . personnellement je trouve les animations assez moche mais vus que je les enlèves c'est pas un soucis. Sans le custom kernel je trouve sa assez lent Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 30 mai 2011 Share Posté(e) 30 mai 2011 Alors lui, il s'est un peu enflammé avec sa rom... Benchmarks dignes d'une 2.1, animations casses couil... en plus impossible de changer la couleur de l horloge en noir sur... un peu moins noir... Bref, le temps de tester 5mn et elle a dégagée aussi sec :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 30 mai 2011 Auteur Share Posté(e) 30 mai 2011 nouvelle rom avec le k11 !! + 1500 sous qudrant qui test ???? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 30 mai 2011 Share Posté(e) 30 mai 2011 nouvelle rom avec le k11 !! + 1500 sous qudrant qui test ???? c est celle la que j ai test hier :P mais il n y a pas le menu CM comme il le dit donc impossible de changer la couleur de l heure et meme si l on change directement le theme, il y a des bugs sur l affichage..., et meme avec le k11 je trouve la Trip 2.2 plus performante et fluide.... grosse déception pour ma part... :mad: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ledave37 Posté(e) 30 mai 2011 Share Posté(e) 30 mai 2011 nouvelle rom avec le k11 !! + 1500 sous qudrant qui test ???? j'aimerais vraiment savoir qu'elle est l’intérêt et ce que représente un de très gros score sous quadrant, lorsqu'en pratique on s’aperçoit que la rom n'est ni fluide ni plus performante qu'une autre (je demande ça sans la moindre ironie) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jon08 Posté(e) 30 mai 2011 Share Posté(e) 30 mai 2011 Bah c'est à titre indicatif c'est tout. Ça va chercher la limite du téléphone, mais en utilisation normale, tu ne vas jamais le faire tourner à son maximum ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
lilyum Posté(e) 30 mai 2011 Share Posté(e) 30 mai 2011 j'aimerais vraiment savoir qu'elle est l’intérêt et ce que représente un de très gros score sous quadrant, lorsqu'en pratique on s’aperçoit que la rom n'est ni fluide ni plus performante qu'une autre (je demande ça sans la moindre ironie) c est tout simplement, l indice de performance, le truc, c est que la rom peut etre optimisée pour certaines taches plus que d'autre... ce qui fait que meme si elle cartonne niveau cpu / memoire, si les performance graphiques ne suivent pas, la fluidité sera impactée... Il est clair que plus le résultat est gros, plus il y a de chance que la rom soit "performante". si je compare le quadrant de mon htc diamond et mon x10 sans parler du sgs de ma femme...les résultats sont bien representatif des perfs du telephone. je prend pour exemple les 2.2 de Trip et Wolf: sur celle de wolf, je monte a 1600 et sur celle de Trip, je peine a dépasser les 1400... par contre la fluidité de celle de trip est largement superieur a celle de Wolf... je pense que l interet de quadrant est surtout interressant, pour voir l evolution d'une rom plutot que d en comparer de differentes... j ai fait les testes sur le tuto que j ai créé pour augmenter les performances de la sd: avant et apres les résultats sont visibles... j espere avoir répondu correctement a ta question :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 30 mai 2011 Auteur Share Posté(e) 30 mai 2011 bien dit !!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 17 juin 2011 Auteur Share Posté(e) 17 juin 2011 j'ai installé cette rom , et ben c de la balle , super simple et plus rapide que toute les autres et stable. voiloo. :emo_im_angel: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ledave37 Posté(e) 17 juin 2011 Share Posté(e) 17 juin 2011 c est tout simplement, l indice de performance, le truc, c est que la rom peut etre optimisée pour certaines taches plus que d'autre... ce qui fait que meme si elle cartonne niveau cpu / memoire, si les performance graphiques ne suivent pas, la fluidité sera impactée... Il est clair que plus le résultat est gros, plus il y a de chance que la rom soit "performante". si je compare le quadrant de mon htc diamond et mon x10 sans parler du sgs de ma femme...les résultats sont bien representatif des perfs du telephone. je prend pour exemple les 2.2 de Trip et Wolf: sur celle de wolf, je monte a 1600 et sur celle de Trip, je peine a dépasser les 1400... par contre la fluidité de celle de trip est largement superieur a celle de Wolf... je pense que l interet de quadrant est surtout interressant, pour voir l evolution d'une rom plutot que d en comparer de differentes... j ai fait les testes sur le tuto que j ai créé pour augmenter les performances de la sd: avant et apres les résultats sont visibles... j espere avoir répondu correctement a ta question :P merci pour ta réponse Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ledave37 Posté(e) 17 juin 2011 Share Posté(e) 17 juin 2011 j'ai installé cette rom , et ben c de la balle , super simple et plus rapide que toute les autres et stable. voiloo. :emo_im_angel: tu trouves que cette rom est mieux que celle de trip et de wolf ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 17 juin 2011 Auteur Share Posté(e) 17 juin 2011 tu trouves que cette rom est mieux que celle de trip et de wolf ? mieux , pour moi oui, elle est simple rapide et tous marche du 1er coup. j'en ai un peu marre d'installer les patchs fix etc !!!! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jon08 Posté(e) 17 juin 2011 Share Posté(e) 17 juin 2011 Bah excuse-moi mais la CM 6.1.3, tu l'installes, tu mets le fix directement (donc ça ne te prends que 10 secondes de plus de ta misérable vie :P ) et c'est bon, tout fonctionne du premier coup! Idem pour la 007 j'imagine, le fix en moins ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
florent38 Posté(e) 17 juin 2011 Auteur Share Posté(e) 17 juin 2011 ben pas moi , wifi en erreur !! 1000 sous quadrant , la 1380 du 1er coup super fluide et tous fonctionne Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jon08 Posté(e) 17 juin 2011 Share Posté(e) 17 juin 2011 Parfois la première installation fait des siennes ;) Je suis près à parier que si tu retentes le coup, tu ne seras pas déçu :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zztop80 Posté(e) 20 juin 2011 Share Posté(e) 20 juin 2011 Pas mal comme rom ^^ bon le wifi fonctionne mais impossible d avoir du reseau telephone pas d apn de parametre ou de demande de code pin dommage je restore la 2.1 original :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Ajael44 Posté(e) 20 juin 2011 Share Posté(e) 20 juin 2011 On peut voir des screenshots svp ? Enjoy ! ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
