authentification a un server distant
diengkals
bonjour , je doit me connecter a un server webphsere pour récupérer mes données pour cela je doit d abord m authenfier(j arrive a recuperer à partir d un web service les données accessible sans authentification mais mon problème se pose au niveau d authentification ) . j ai cherché quelque chose sur le net mais toujours sans succes . je vous met mon code voir si j ai pas fait des erreur de code . merci d avance
public class Authentification extends Activity {
       /** Called when the activity is first created. */
       String response;
       final String username = "19851985";
       String result;
       final String password = "android85";
       HttpResponse httpresponse;
       InputStream chaine;
       final String proxyHost = "localhost";
       final int proxyPort = 80;
       String url = "http://10.0.2.2/webapp/wcs/stores/servlet/AddressBookForm?storeId=10101&catalogId=10101&langId=-2";
       HttpEntity entity;
       @Override
       public void onCreate(Bundle savedInstanceState) {
               super.onCreate(savedInstanceState);
               setContentView(R.layout.main);
               DefaultHttpClient client = new DefaultHttpClient();
               AuthScope authScope = new AuthScope(null,-1, AuthScope.ANY_REALM);
               Credentials credential = new UsernamePasswordCredentials(username, password);
               client.getCredentialsProvider().setCredentials(authScope, credential);
               HttpGet httpGet = new HttpGet(url);
               httpGet.addHeader("User-Agent", "Android");
               HttpConnectionParams.setConnectionTimeout(client.getParams(), 15000);
                       httpresponse = client.execute(httpGet);
               entity = httpresponse.getEntity();
                       chaine = entity.getContent();
                       result = stream2String(chaine);
               JSONArray jsonOrdArray =  new JSONArray(result);;
               for (int i = 0; i < jsonOrdArray.length(); i++) {
                       Order order = new Order();
                       JSONObject commande =  jsonOrdArray.getJSONObject(i);;
                               order.reference = commande.getString("reference");
       private String stream2String(InputStream stream)
                       throws UnsupportedEncodingException {
               String charSet = "iso-8859-1";
               InputStreamReader reader = new InputStreamReader(stream, charSet);
               BufferedReader buffer = new BufferedReader(reader);
               StringBuilder sb = new StringBuilder();
               try {
                       String cur;
                       while ((cur = buffer.readLine()) != null) {
                               sb.append(cur);
               } catch (IOException e) {
                       e.printStackTrace();
               try {
                       stream.close();
               return sb.toString();
merci pour votre reponse au fait j ai reverifier mon code et j ai trouvé que les erreurs venaient de la requete https . au fait je travaille sur un serveur qui utilise des requete https et le certificat fournit n est pas confiant je voulais savoir comment contouner la requete pour pouvoir ce connecter comme on le fait sur navigateur
voici les erreur que ça me genere
06-14 17:09:19.977: WARN/PackageManager(69): Code path for pkg : com.connexion changing from /data/app/com.connexion-1.apk to /data/app/com.connexion-2.apk
06-14 17:09:19.977: WARN/PackageManager(69): Resource path for pkg : com.connexion changing from /data/app/com.connexion-1.apk to /data/app/com.connexion-2.apk
06-14 17:09:21.367: WARN/RecognitionManagerService(69): no available voice recognition services found
06-14 17:09:26.648: WARN/System.err(724): javax.net.ssl.SSLException: Not trusted server certificate
06-14 17:09:26.648: WARN/System.err(724):     at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.startHandshake(OpenSSLSocketImpl.java:371)
06-14 17:09:26.648: WARN/System.err(724):     at org.apache.http.conn.ssl.AbstractVerifier.verify(AbstractVerifier.java:92)
06-14 17:09:26.659: WARN/System.err(724):     at org.apache.http.conn.ssl.SSLSocketFactory.createSocket(SSLSocketFactory.java:381)
06-14 17:09:26.669: WARN/System.err(724):     at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:164)
06-14 17:09:26.690: WARN/System.err(724):     at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:164)
06-14 17:09:26.690: WARN/System.err(724):     at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:119)
06-14 17:09:26.690: WARN/System.err(724):     at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:348)
06-14 17:09:26.708: WARN/System.err(724):     at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:555)
06-14 17:09:26.708: WARN/System.err(724):     at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:487)
06-14 17:09:26.708: WARN/System.err(724):     at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:465)
06-14 17:09:26.727: WARN/System.err(724):     at com.connexion.Authentification$1.run(Authentification.java:86)
06-14 17:09:26.727: WARN/System.err(724): Caused by: java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: TrustAnchor for CertPath not found.
06-14 17:09:26.758: WARN/System.err(724):     at org.apache.harmony.xnet.provider.jsse.TrustManagerImpl.checkServerTrusted(TrustManagerImpl.java:168)
06-14 17:09:26.758: WARN/System.err(724):     at org.apache.harmony.xnet.provider.jsse.OpenSSLSocketImpl.startHandshake(OpenSSLSocketImpl.java:366)
06-14 17:09:26.803: WARN/System.err(724):     ... 10 more
06-14 17:09:26.813: WARN/System.err(724): Caused by: java.security.cert.CertPathValidatorException: TrustAnchor for CertPath not found.
06-14 17:09:26.820: WARN/System.err(724):     at org.bouncycastle.jce.provider.PKIXCertPathValidatorSpi.engineValidate(PKIXCertPathValidatorSpi.java:149)
06-14 17:09:26.828: WARN/System.err(724):     at java.security.cert.CertPathValidator.validate(CertPathValidator.java:202)
06-14 17:09:26.828: WARN/System.err(724):     at org.apache.harmony.xnet.provider.jsse.TrustManagerImpl.checkServerTrusted(TrustManagerImpl.java:164)
06-14 17:09:26.839: WARN/System.err(724):     ... 11 more
Modifié par AndroidRim
Etant en vacances jai pas acces a mes codes mais en gros sur internet mais en gros cherche un peu avec google. En gros la plus simple des solutions est decrire un connecteur (surcharge) qui check pas le certificat [color=red]qd[/color] tu es en hhtps. Javais trouver ca sur un blog.
Si jamais tu trouves pas dici mon retour de conge jte copierai mon bout de code ici
jok
Je viens de rentrer de congé ^^
Tu trouvera deux types de solution :
1 - Accepter tous les types de certificats
http://stackoverflow.com/questions/995514/https-connection-android/1000205
http://stackoverflow.com/questions/2899079/custom-ssl-handling-stopped-working-on-android-2-2-froyo
2 - Accepter uniquement ton certificat autosigné
http://blog.antoine.li/index.php/2010/10/android-trusting-ssl-certificates/
Voilà,
Jok
Voilà,
Jok
merci bien Jok , maintenant j arrive a acceder au serveur via les requte https mais j ai un autre probleme qui est l authentification(login/password) . au fait j accède au ressources qui ne demande pas l'autorisation d’authentification(login/password) mais j arrive pas à accéder au ressources qui demande l'authentification(login/password ) et pourtant je pense avoir bien codé même le code de connexion me retourne 200 mais si je regarde au font qu'il ne récupère rien (il me retourne un tableau ) j ai testé avec mon navigateur web j ai trouvé si je m'authentifie les données sont retournées et si je m authentifie pas il me retourne un tableau null donc je conclu que l'authentification ne c est pas bien passé
voici comment je l ai codé
SchemeRegistry  registre= new SchemeRegistry();
	   registre.register(new Scheme("http", PlainSocketFactory.getSocketFactory(), 8002));
	   registre.register(new Scheme("https", new EasySSLSocketFactory(), 443));
	   params = new BasicHttpParams();
	   params.setParameter(ConnManagerPNames.MAX_TOTAL_CONNECTIONS,1);
	   params.setParameter(ConnManagerPNames.MAX_CONNECTIONS_PER_ROUTE, new  ConnPerRouteBean(1));
	   params.setParameter(HttpProtocolParams.USE_EXPECT_CONTINUE, false);
	   HttpProtocolParams.setVersion(params,HttpVersion.HTTP_1_1 );
	   HttpProtocolParams.setContentCharset(params,"utf8");
 [b] CredentialsProvider  credentialsProvider  = new BasicCredentialsProvider();
	  credentialsProvider.setCredentials( new AuthScope ("urlslogin",443),
		     new  UsernamePasswordCredentials(username, password));
	[/b]
		   context  = new BasicHttpContext();
		  context.setAttribute("http.auth.credentials-provider",credentialsProvider );
		   clienConnectionManager = new ThreadSafeClientConnManager(params,registre);
		 client = new  DefaultHttpClient(clienConnectionManager, params);
			  client.getCredentialsProvider();
j ai mis en gras la partie qui concerne l authentification
merci de votre aide
Hello,
Je ne vois pas ou tu utilise ton context dans le code ^^
Je ne te vois pas non plus setter ton provider ^^
Jète un oeil sur google (stackOverFlow) il y a pas mal d'exemple.
Faut également voir coté serveur ? c'est bien du basic du digest ?
Bon courage
Jok
Hello,
Bon courage
Jok
merci bien c vrai j ai pas mis tout le code ce qui du serveur j ai pas vrai accès ce qui fatigue c est serveur wcs(WebSphere Commerce Server ) . pouvez vous me donner plus d explication de l'utilisation de CredentialsProvider et basic du digest je comrpend pas bien
voici comment j utilise le context et provider
	   registre.register(new Scheme("http", PlainSocketFactory.getSocketFactory(), 80));
		[b]  context.setAttribute("http.auth.credentials-provider",credentialsProvider );[/b]
      [b]    		httpResponse = client.execute(get,context);[/b]
le provider je le met dans le context
et merci de votre aide
